Are there any alternatives to the stock Mini Ultra Stick landing gear? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 07-07-2008, 11:52 PM
d&mrc
d&mrc's Avatar
Default Are there any alternatives to the stock Mini Ultra Stick landing gear?
I am looking for something a bit sturdier (the axle the wheels spin on have bent on mine), and cheaper. I found these, but they were originally intended for the slow stick, so I am hesitant to buy them.
d&mrc is offline
Old 07-08-2008, 12:22 AM
Old Fart
Lost at LAX
Old Fart's Avatar
Are you running nylon bolts to the fuse? I've managed to shear those off (once), but can't imagine landing hard enough to bend an axle
Old Fart is offline
Old 07-08-2008, 02:24 AM
d&mrc
d&mrc's Avatar
I really haven't had any very hard landings. Lately I have become quite proud of my ability to land this plane smoothly. The problem just developed over time......
d&mrc is offline
Old 07-08-2008, 03:53 AM
pd1
Still Learning
pd1's Avatar
You can swap out the supplied bolts with Allen head type bolts.
Allen bolts are much harder than run of the mill bolts.
Paul
pd1 is offline
Old 07-08-2008, 06:24 AM
d&mrc
d&mrc's Avatar
Paul
I am not talking about the bolts, I am talking about the gear.
d&mrc is offline
Old 07-08-2008, 11:58 AM
smokejohnson
smokejohnson's Avatar
Are you talking about something like this?
http://www.allerc.com/product_info.php?products_id=1816
smokejohnson is offline
Old 07-08-2008, 12:13 PM
pd1
Still Learning
pd1's Avatar
I misunderstood. I thought you wanted axles that wouldn't bend.
Some gears use bolts for the axles.
If all you want is to change the axles, Du Bro hardened steel axles that bolt on to aluminum gear legs.
http://www.shopatron.com/product/par...161.5171.0.0.0
If you want to change the whole gear James gave you a good link.
If you want to fabricate a wire gear, I can get you information on that.
Paul
pd1 is offline
Old 07-08-2008, 10:12 PM
d&mrc
d&mrc's Avatar
Does anyone know anything about the landing gear I referred to in my original post? They look pretty cool in my opinion. I am considering the suggestions you guys have given me. PD1, do you happen to know what size of those axles I would need for the MUS landing gear? Or even for the gear smokejohnson linked to?
d&mrc is offline
Old 07-08-2008, 10:55 PM
Hostile
flying Cajun
Hostile's Avatar
The landing gear you linked to is for a stick type fuselage. Without major modding it won't fit. The landing gear on the MUS is pretty tough. Tougher than the plane itself. If it is only the axles that have bent, then pd1 has given you the best way IMO. As far as the size, I would have to measure them tonight when I get home. Maybe someone else knows, and will post it up for you.
edit: The bolts pd1 referred to were to make new axles out of, ......not to bolt on the gear. They mean for you to use a harder bolt not the soft bolts that e-flite used for axles.
Hostile is offline
Old 07-08-2008, 11:00 PM
Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
I have the gear you posted on, they're on my SSX. Nice gear. You can adjust toe in/out on them, and mine came with both a stick fuselage adapter and one for a flat bottom plane.
I like em, they seem very sturdy and were easy to assemble.
Email James at Millennium, he can more then likely answer any questions you have oth what the gear will or won't do.
Glacier Girl is offline
Old 07-09-2008, 12:50 AM
pd1
Still Learning
pd1's Avatar
The link takes you to the page and the one selected is the 1 1/4 inch long by 1/8 diameter axel.
That is a tough axle, that size should work.
Paul
Thanks Hostile.
pd1 is offline
Remy
01-17-2008 11:43 PM
Sam_K
12-31-2007 06:37 AM
pairadocs
ParkFlyers
8
12-21-2006 01:16 PM
kc10boom
ParkFlyers
11
04-30-2006 09:53 PM
3D Flying
09-19-2005 03:08 AM
Quick Reply: Are there any alternatives to the stock Mini Ultra Stick landing gear?
Page generated in 0.06241 seconds with 10 queries
