6 Foot Telemaster Electro
Maiden flight -- 6 to 8 mph winds - Power 25BL/40A ESC 12X6E Prop/3S 4200 Batt.
Not good - Weather-vaned on take off...cut power glide to smooth landing.
Maiden Flight2 -- 3 to 5 mph winds - same equipment - Immediate tail stand on take off gained altitude but could not control the elevation... cut power and glide to landing in tall grass -- Damage; lost undercarriage from plane (5 min epoxy fixed it)....found elevator control horn separated from elevator.
Suspected CG wrong....Book says 4.25 to 5" behind leading edge. Was set to 4.5......moved to 4"
Re maiden #3 -- Zero wind... Beautiful flight though seemed slugish...Great landing.
Flight #2 (after successful maiden) 3 to 5 mph winds.... Great flight and Landing though had to fight the wind constantly. It wanted to be carried away. It seems as if I just did not have enough power,
Book says it was test flown with a 750 watt motor so I checked mine and came out to 330 watts. Only 60 watts per pound... not enough power to fight a slight breeze considering the huge wing area.
I have ordered the following for this AXI 2826/12 (same as reviewer)/60A ESC/ 14.7 props/ 2-4S batteries.
I'll update the next flight with the new equipment.
Great plane.....Love it......Flaps help for short field landings....it will float even without power in winds...as the main wing stalls the tail lifts forcing the plane nose down to gain airspeed providing lift on the main wing again. you must deliberately land to control the float.
I am using a Scorpion 3026-12 on my 6ft Telemaster with 2 3s2100 ProLite TPs in parallel, with a 13x6.5 prop. The planes has more than enough power. Remember, a telemaster is not supposed to be a rocket. My take offs are quick, and my flights a lazy. I love it. It does have enough power for rolls, loops, and inverted flight (Which is funny to see).
Before you give up on the Power 25, try it on 3 cells with a 14x7 prop. You should get a lot better performance. You can also run it on 4s with a 12x6 prop.
The 750 Watt AXI will be going in at 4S with the 14X7
Well it's not considered scale (or any of the other available categories), it is a trainer and pretty much flies in circles (pattern), I didn't see a topic for "Trainers" so felt this would be the best place...sorry:o if I'm wrong the mods can place it where it should go.
Ray,
I have suggested the creation of a forum for Trainer aircraft.
floridawen,
As I outlined in that post, while it definately fits in the beginner section, I felt that Trainer aircraft deserve their own section, especially for those of us somewhat experienced pilots who are no longer "beginners" per se, but still enjoy the relaxing style of flying these aircraft evoke.
floridawen,
Ray,
floridawen,
floridawen,
Have a GREAT HOLIDAY today !!
Not to worry, It was just my attempt at being humorous.
I have the AXI in the plane now with the 4S batt and 14X7 prop. Boy what an extreme difference in sheer power. Can't wait to put it back in the air. A combination of winds/road construction and just plain time off have kept me from the field. Also took the nimh RX batt out and added a UBEC w/2S lipo for the the RX Power.
Also the tail wheel steering sucks....so made a modification to that to really make it work as it should.
I'll try to get some pic's up soon.
It's not!!! But it is a ic/electric conversion. This is nott a pattern forum any way. You must be in the wrong place.
I and several friends fly the Telemaster 40 electric. It's called the 40 because it was the glo 40 before the conversions. We use the A123 4s2p and fly all day with that. It needs the weight. The original Telemaster (96" wing span)is a work plane used to pull lines accross the valleys in the european mountains, then the lines are used to pull up power cables for electric power. Also as a camera plane.
Many uses besides just "plane" fun, pun intended.
I never liked the stock tail wheel on the Telemaster, so I replaced mine with a Sullivan tail wheel assy. Works great. Mine is the SR Telemaster and I love it, even if I am no longer a beginner. It's a very relaxing plane to fly and I'll have mine back up again as soon as I fix the hole my dog dug in the wing. Just ripped the covering, but I have been lazy lately.
Ed
Ed
Ed
Ed
Ray, I just came across this thread.
What brand control horns are you using?
The Du Bro ones I have, the 2-56 bolts go through the horn and screw into a retainer on the other side.
If I screwed the bolt into the horn, it wouldn't grab all that securely.
Just wondering.
Paul
Just wondering.
Paul
That's what caused my first maiden to fail. The screws (and back plate) came out of the elevator horn. Luckily I was able to "float" it to a decent landing using only rudder and ailerons) Look at the pic's and you will see I used a different rudder horn (Dubro) and for the elevator I used longer screws (also used 3mm instead of 2-56). I may still change this one out to the same as the rudder.
I used a split elevator on mine with two servos and some GOOD horns. I don't remember who made them, but they were not the ones that came in the kit. I also use flaperons on mine and drop them on final and use rudder to steer it from there. Ailerons don't seem to work to good with flaps down. One of these days I am going to split my flaps and ailerons and have real flaps. By the way, that is one good looking Sr Telemaster. Mine is still stock Yellow and I kind of like it, but I will recover it one of these days.
Ed
Ed
