Phase 3 F-16 build thread. - Page 24 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 07-25-2009, 02:33 PM
  #576
Ghostmaker1970
Ghostmaker1970's Avatar
Exclamation Wake up before you fly ! Oops !
The weather here has just been awful and chances to fly have been limited. I got a call from my neighbor/flying buddy who works nights and he said I am flying when I get home if you want to come, let me know !. So I called him and said I would go and asked him for a wake up call half an hour before he was ready to leave. Five Minuit's before he is ready I get a call saying come on I am all loaded and ready to go. So.... I rush round grab my ef16 and wonder over to his with all the bits I need. By the time we got to the field I was still a bit groggy from sleep and should have given myself a while to wake up properly but I did not = Over did the aileron turned toward the ground full throttle tried to pull out of the dive inverted and hit the ground full throttle !!! Hit the ground with tail and cockpit, Tore both wings off and tail and both aileron mounts have given way. also smashed the cockpit up too. Verdict Pilot error, result smashed my first ducted fan plane, Damage level medium, Special thanks to EPP and UHU POR, She will live horay!!! She is in intensive care right now having a UHU transfusion but should be back in the air soon yay!!!.
Ghostmaker1970 is offline
Old 07-26-2009, 01:07 AM
  #577
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
fix her back up ghost!!!!!
iflyrc1012 is offline
Old 07-26-2009, 03:33 AM
  #578
Ghostmaker1970
Unhappy
Might need a new air frame the taileron carriers took it hard I am going to try a transplant but it does not look good. I wish I could get an air frame only in the uk for this.
Old 07-26-2009, 09:39 PM
  #579
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
use Popsicle sticks or tongue depressors for added strength on the tailerons!!
Old 07-29-2009, 09:01 PM
  #580
AlexinFlight
AlexinFlight's Avatar
I got side tracked with my build some few months back. Anyway I am on it again and just read all 24 pages of this thread. Should I do the tail mod like Grasshopper did on page 10? Pics of my paint coming soon.
AlexinFlight is offline
Old 07-29-2009, 11:50 PM
  #581
crxmanpat's Avatar
Yes, do the tail mod. Even on the stock plane it's necessary. Don't ask how I know. :o
crxmanpat is offline
Old 07-30-2009, 01:13 AM
  #582
AlexinFlight
Wasn't there another mod...someone put CF rods in the front of the lower foam piece?
Old 07-30-2009, 01:17 AM
  #583
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
the tail mod is not optional even for a stock airplane and a tame pilot. DO ITTTTT!!!!
lol!!
Old 07-30-2009, 01:21 AM
  #584
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
the c/f is optional .. . keep the airframe light. . . it will only last 40 or so flights under the best conditions anyway. then buy another one.
Old 07-30-2009, 06:12 PM
  #585
AlexinFlight
I will do the tail mod, for sure. Thanks for the input!
MOD done! Paint next.
Alex
Old 08-01-2009, 03:28 PM
  #586
AlexinFlight
F-16 is just about done. Mounted fan as per the instructions at 1.5" back from where the stock mount is, as I will be using a 3s 2250 lipo, 181 gr. Any tips before I throw her in the air would be appreciated. This is my first EDF and I am not quite sure how to set my DX6i. Anyone else using a DX6i? How did you set it?
Alex
Old 08-01-2009, 04:56 PM
  #587
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
make sure the balance is correct. the wrong c/g WILL KILL the plane!! balance it as per the instructions!! the launch toss should be full throttle, and at a slightly upward angle, into the wind.
Old 08-01-2009, 04:58 PM
  #588
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
and don't forget to post pics of your freshly flown viper!!!!
Old 08-01-2009, 06:11 PM
  #589
AlexinFlight
Here is where she's at right now. Needs a lil' touch up in the front where the gray over spray occurred. Need a lil' gray on the underside pylon. You can see my pylon mod here too. Lightweight 3/32 basswood secured with epoxy. Decals on the way.
Old 08-02-2009, 02:56 AM
  #590
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
the tail mod looks perfect. and at 80 m.p.h. nobody can see that little grey overspray!! LOL!!
Old 08-02-2009, 03:06 AM
  #591
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
alex,
set the tailerons up so neutral is with the front edge of the tails even with the bottom of the pylon. this looks like you have up elevator set in but its not... this will make your first hand launches easier. i fly mine on a dx5e. no frills but a good solid radio. also a pic of my tail mod.
ID:	106550   Click image for larger version
Name:	9 tail reinforced top.jpg
Old 08-02-2009, 06:50 AM
  #592
AlexinFlight
iflyrc1012, Thanks for your help also. Should be ready for a maiden this week.
Alex
Old 08-02-2009, 06:10 PM
  #593
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
alex,
remember, fly this bird smoothly. . no abrupt movements on the sticks, carve your turns wide and flat. and don't be afraid to fly half throttle, this bird can fly very slowly. almost high alpha if you manage throttle and elevator well enough. also she handles 10 mph or higher winds very well, in fact better than alot of much higher priced e.d.f. jets do. Also when landing, just a split second before touchdown, release the up elevator or the tailerons will catch in the grass or weeds and rip off. (ask me how i know that) otherwise just enjoy the whine of the fan buzzing by at 80 or so mph!!!!!
Old 08-03-2009, 05:25 AM
  #594
USMC_VTOL_Mech
I guess mine on it's 140th flight didn't count or what?
(I am up to 172 now BTW)
USMC_VTOL_Mech is offline
Old 08-03-2009, 07:55 AM
  #595
hillbille
hillbille's Avatar
Alex
Before you "toss" it you might want to read this:
http://www.rcgroups.com/forums/showp...2&postcount=35
It is a procedural fix for the taileron operation known to give problems in a DX6i. The "programmed" flaperon and taileron sekections in the DX6i functions menu are NOT programmed correctly and give more throw one way than the other causing goofy taileron action in some cases. A lot of people just deal with it but it is serious and CAN be corrected following the simple setup this guy suggests. There is quite a thread on this over on the "other" forum. Good reading but the link above is to the fix. Try the fix and see if it is better than the pre-programmed selection for YOU. I found quite a difference with mine and will never use the pre-programmed taileron selection in the DX6i again but like I said everybody is different and you may be happy with it the way it is.
Just a suggestion.
Also before the first flight the tailerons should be set with a bit of "UP" to them as it is far easier to put down elevator in to stop a climb than it is to try to put a lot of up in to stop a dive especially at low speed and no altitude launches!! LOL!! I don'r mind ask me how I know!!
Hillbille
Hillbille
hillbille is offline
Old 08-03-2009, 04:43 PM
  #596
AlexinFlight
Thanks hillbille and thanks timocharis, that helped tons. Anyone using a DX6i, here is the info hillbille directed me to,written by screen name timocharis or Dave:
It is slightly complicated but just take your time and follow along, it worked perfect for me and I can now control the amount of travel and they are balanced!!!!.
Fix For Elevon Routines with DX6i
Found a fix for the Elevon problems (fixes them all, I think).
This is slightly complicated, but bear with me. In the end, you get everything working plus a bonus feature at the cost of only one mix.
First, plug your right servo into the aileron plug and your left servo into Aux 1 (the Flap plug). I've only tried this on one plane, so I don't know if those might be reversed in some setups.
Then set your Wing Type to Dual Ailerons. Now check your aileron control -- it should work normally for an elevon plane (elevator is not yet working). If it doesn't, you'll probably end up having to reverse your plugs to make things work right.
Next, go to Mix 1 and set Elev -> Flap with both rates (D & U) at 100%. In my case that was -100%, but you may have to use +100 percent in your setup. Check function; at this point it should look like an Elevon plane with a boatload of travel. Don't fret about that -- the extra travel will "fix" your trim buttons! And don't forget to set "Trim" to ACT in the lower right corner of this screen.
Now, if you want differential it should work perfectly. If it goes in the wrong direction, you'll have to back up and reverse the plugs (move the servo in Ail to Aux and vice-versa) and redo the other settings to reverse them. Ultimately it means you'll have all the function back at the cost of a single mix.
But you get some payback for that mix: your Flap switch will now work! Probably the best use for it on an elevon plane is adjusting the elevons to max glide duration in case you want to do some thermals and don't want to try and see what the little bugger is doing at 400 feet...
Undoubtedly your elevon travel will now be too great. If you go to Dual Rates and reduce your top rate down at least to 80% of full, your trim buttons will now be completely safe to use -- the endpoint travel will not be greater than your allowed travel, so the weird "button effects" go away.
As far as I can tell, this is a complete fix. Would be delighted to hear if anyone hits a snag... also this leaves the option of another mix open (if you're using rudder and want a mix, or wish to do a throttle -> "flap" mix to get the torque roll out, for example).
Here is the thread if anyone wants to read it: http://www.rcgroups.com/forums/showthread.php?t=940867
Old 08-03-2009, 08:40 PM
  #597
AlexinFlight
Just wanted to say thanks all of you that have helped me with my 1st EDF plane. Here she is with paint complete, everything installed and working perfectly. She is stock, but I figure a great starting point for me. I went with bright colors so my 51 year old eyes can see it in the sky, and I have always liked invasion stripes. Taileron pylons are reinforced, right taileron leading edge is set at the lower edge of the pylon with the left taileron is 1/8" higher, as was suggested. I am expecting a custom tail decal to arrive shortly, but here she is done minus the tail art.
Alex
Old 08-04-2009, 12:53 AM
  #598
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
well.... toss it already!!! LOL!!
Old 08-04-2009, 01:07 AM
  #599
AlexinFlight
It will get tossed soon!!!! LOL!!!! The tail art just showed up:
Old 08-04-2009, 03:11 AM
  #600
Ribcracker
Flight Junkie
Ribcracker's Avatar
That is very cool!!! Where did you get the artwork?
Ribcracker is offline
Quick Reply: Phase 3 F-16 build thread.
Page generated in 0.10679 seconds with 16 queries
