Blade CX2 - difficult to maintain altitude
Old 08-21-2007, 04:25 PM
Laszlo
Default Blade CX2 - difficult to maintain altitude
Anyone else has problems to maintain altitude flying a Blade CX2? I find that when applying rudder, however gently, my bird either takes off towards the ceiling or loosing altitude. I learned to compensate for this quite well still, I find it impossible to keep the CX2 hovering at the same height for more than a few seconds at a time. ??
Also when I am trying to land on four coasters on the basement floor (approx 8"x 8") to test/stretch my landing skills (to imitate real helis) this bird is very slippery. Sliding left right front and back - all over the target. I keep flying around the 'landing zone' over and over until - well i almost make it. Is this because of the 'ground effect'? Is this behavior the result the light weight of the CX2? How do real helis behave?
Laszlo is offline
Old 08-22-2007, 07:32 AM
singingperry
The cx2 is a light bird and the turbulence it makes for itself (especially in small enclosed areas) really moves it around a lot when close to the walls or the floor. It flies best a few feet above the floor and in the middle of the room away from objects. Too close to the wall and it will actually suck itself into it, too close to the floor and it will float around till you cut the throttle. The cx's tail moves around by changing the speed of one of the motors, if the tail moves around the other way then the other motor is changing speed, this is how it turns without a tail rotor. Unfortunately, this also affects altitude. When I hot dog the heli around my kitchen I tend to bounce the heli off the floor a lot which is why I always have spare landing skids handy.(And spare blades).
singingperry is offline
Old 08-22-2007, 04:46 PM
Laszlo
Thanks for your note. I kind of figured that this is the case with small coax helis.
Try to get a set of 'indistructable extreme' landing skids - they work! www.bladecx2.com or www.cx2parts.com
Laszlo is offline
Old 08-23-2007, 06:53 AM
Rabbitcreekok
Rabbitcreekok's Avatar
Remember that the left stick also controls the throttle. When you are applying rudder, you are unintentionally moving the throttle up or down. This just takes practice to overcome.
Rabbitcreekok is offline
Old 08-23-2007, 07:42 AM
phupper
Flyin' Phup
phupper's Avatar
There's a theory that the notches that make the "clicks" in the throttle stick can be 1/2 click off, making it hard to hit the perfect setting. There's a mod out there for filing off the notches.
phupper is offline
Old 08-23-2007, 07:45 AM
brnyrbbl
Powered by Visa
brnyrbbl's Avatar
No filing necessary. Just pull the back cover off and "flip" the metal tab. Smooth throttle just the way a heli TX should be.
brnyrbbl is offline
Old 08-31-2007, 10:01 PM
Dave R
I put a little piece of silicone fuel tubing on the spring under the throttle "gear". No filing and I still have nice friction that holds the stick in place. Easy to reverse if I ever decide to although I can't imagine doing so.
Dave R is offline
Old 08-31-2007, 10:44 PM
phupper
Flyin' Phup
phupper's Avatar
Ok, ok, I get it, no filing...sheesh!
phupper is offline
Old 08-31-2007, 11:06 PM
brnyrbbl
Powered by Visa
brnyrbbl's Avatar
Where in So Cal are you located phupper? I'm close to San Diego (about an hour away)
brnyrbbl is offline
Old 09-01-2007, 12:35 AM
phupper
Flyin' Phup
phupper's Avatar
Im in San Diego, just north of beautiful Mission Bay.
An hour away you say? Would that be the Camp Pendleton area (if it's north)?
phupper is offline
Old 09-01-2007, 01:34 AM
brnyrbbl
Powered by Visa
brnyrbbl's Avatar
Further North than Pendleton. Do you know where Lake Elsinore is?
brnyrbbl is offline
Old 09-01-2007, 01:41 AM
phupper
Flyin' Phup
phupper's Avatar
I know the name, but never actually been there. You have lots of open flying space up there I imagine.
phupper is offline
Old 09-01-2007, 01:46 AM
brnyrbbl
Powered by Visa
brnyrbbl's Avatar
We have a few left but they are building like crazy
brnyrbbl is offline
Lymph
E-Flite Helicopters
33
08-12-2009 02:06 PM
CRZYFLY
Beginners - Helis
12
04-08-2009 06:05 AM
Dagger Thrasher
03-09-2008 12:39 AM
Shadow
Beginners - Helis
09-11-2007 09:04 PM
Testosterone
General RC E-Heli Talk
05-13-2007 09:32 PM
Quick Reply: Blade CX2 - difficult to maintain altitude
Page generated in 0.11712 seconds with 13 queries
