esc for 400
Old 12-19-2005, 08:50 PM
Pietdriver
Default esc for 400
I have Pic pro with a 400 moter in it. Is a 5 amp speed controller adequte, what sort of amperage can a 400 put out?
Pietdriver is offline
Old 12-20-2005, 01:37 AM
Twmaster
Registered User
Twmaster's Avatar
No you will roast a 5A control on a SP400 motor. The smallest I'd recommend is a 12A.
Twmaster is offline
Old 12-20-2005, 04:03 AM
Pietdriver
Will the speed controller restrict the output of the moter? how many amps is safe to run the 400 at?
Old 12-20-2005, 04:10 AM
obiewanben
Old Doggie
I use the JETI 10 for 400s and do not have a problem.
obiewanben is offline
Old 12-20-2005, 10:26 AM
slipstick
Deleted - double post
slipstick is offline
slipstick
No, the combination of the motor and prop controls how much current (amps) is flowing. The speed control is likely to burn up if the motor tries to pull too much current. BTW technically a motor doesn't "put out" amps, the battery puts out the current and the motor uses it.
S400s run well at up to 12A so I'd agree with Twmaster's recommendation of a 12A ESC.
Old 12-21-2005, 02:32 AM
Pietdriver
Thanks guys I have been getting away with that 5 amp esc for a while now however I was using a mild set-set and am now going to a 3-D set-up that requires more pitch and of course more power. I'll get another esc, either a 12 or 15 amp unit and that should let me push the 400 a little harder.
Lymph
E-Flite Helicopters
05-22-2008 01:35 AM
tallflyer
03-27-2008 10:49 PM
Trackhappy
10
11-19-2007 10:17 AM
Toker41
04-02-2007 11:07 PM
N3CLI
11-05-2005 08:40 PM
Quick Reply: esc for 400
Page generated in 0.08728 seconds with 12 queries
