setting servo for tail on blade 400
Old 04-06-2008, 04:56 PM
neilg.
Default setting servo for tail on blade 400
i know these little buggers break from the posts. but seems they also strip and when they do, in my case, i do not know where to set the tail rotor onto the new servo. is it hit or miss?
ty
neilg. is offline
Old 04-06-2008, 06:29 PM
Heli Jim
Grandpa, Golfer, Pilot
Heli Jim's Avatar
If you lower the gain for the gyro to rate mode (below 50% gain) and power it up. That will allow the servo to center and then center the arm or wheel on the servo. For the tail, the lever should be in the middle of the travel. If you are just replacing the servo with another of the same model, then the pushrod length should line everything up for you. Then switch the gain back to where it was (above 50%) to get back into heading hold. I changed the setting for position 1 on the switch so I didn't mess with the HH setting for position 0
Heli Jim is offline
Old 04-06-2008, 07:52 PM
neilg.
i will see the gain for the servo in the settings on my spektrum?
does that go for all servos also if they are replaced or just power up servos and place lever back on so it is at 90 degrees which should make the swashplate level?
lets say there is an indestructable servo, where does one find them?
ty
neilg. is offline
Lymph
E-Flite Helicopters
16
04-23-2011 04:20 PM
Lymph
E-Flite Helicopters
11
07-07-2010 06:21 PM
fateemagee
E-Flite Helicopters
04-16-2008 05:16 AM
cellsitegod
01-14-2008 08:49 PM
usherwdp
Beginners - Helis
02-12-2007 02:26 AM
Quick Reply: setting servo for tail on blade 400
Page generated in 0.07838 seconds with 13 queries
