Precision Aerobatics Electric Shock NEW PLANE!!!!
Guys I just found out that Precision Aerobatics added a new plane to their website, it is called the Electric Shock. Here is what the website says
http://www.precisionaerobatics.com/p...px?prodID=1081
Precision Aerobatics bring you another top quality model, which takes small profile park flyers to a whole new level.
Enjoy both worlds – PA Electric Shock is a high performance 3D aircraft, at a budget price, but without compromising on PA high quality standards.
This model is unlike any other in the same category. Rather than focusing being as cheap as possible, the Electric Shock sports many unique features:
Two piece removable wings with carbon fiber wing tube, makes the model extremely strong. It is also very easy for transportation and storage, and Yes! You got that right – no hassle of gluing or installing the wings to the fuselage: simply slide in the carbon tube and fasten the wing bolts. As simple as that!
Sophisticated structure engineering and clever use of carbon fiber gives the Electric shock its excellent crash resistance and it’s lightweight.
The Electric Shock features extensive use of carbon fiber throughout the aircraft and when we say EXTENSIVE - we mean it!
Carbon fiber leading edge
Carbon fiber trailing edges
Double carbon fiber main spar
Carbon fiber elevator leading edge
Carbon fiber wing tube
Carbon fiber wing sleeve
Carbon fiber anti-rotation wing pins
Carbon fiber pushrods
Carbon fiber control horns
Carbon fiber motor mount
The Electric Shock is a real ARF and can be built in a couple of hours. The hinges are pre-installed and we even sealed the hinges gap for you! The wings are attached with two bolts and nuts and the fin is already pre-installed. The only assembly stage left for you is to glue the stab in place and attach the rudder. Install your motor and radio gear and you are all set.
We have put a lot of time into the design and testing of the Electric Shock. Special attention was given to the proper geometry of the linkages, so no adjustments are required.
In order to achieve the best performance we have tested every possible CG for this plane. We have worked out the most suitable gear, per our specs, and CG requirement, and we offer you a few combo packages that would save you having to experiment and assuring you get the most out of the aircraft.
The Electric Shock is designed to be flown in a very small space, any cricket field, parking lot or even your backyard will do. It is available in three see-through colour schemes (green, red and purple) so a few can be flown at the same field without confusion.
The Electric Shock is a joy to fly. It allows you to significantly improve your 3D skills without risking your larger and more-expensive models.
This plane performs the most gorgeous flat and upright spins that you have ever experienced! Hovering and stall turns are super easy and the nasty rudder and fuselage allows easy Knife Edge loops. High Alfa harriers, upright and inverted, are extremely stable and easy to perform. In fact we had some fun-flights in which we flattened the battery pack on LLOOOONGG harriers.. Spectacular thumbing manoeuvers from all kinds, super fast axle-rolls, and beautiful rolling circles – this model is excellent for practice this complicated manoeuver…
If you want to learn to hover and torque-roll - the Electric Shock is one of easiest planes to get a very stable hovering. Due to its massive ailerons design, you can stop the plane from torque rolling or even reverse the direction at ease.
The Electric Shock with its large wing area, low flight weight (=very low wing loading), and huge control surfaces allows you a very easy recovery from any manoeuvre at a very low altitude.
Let’s put it this way, if you want to improve your 3D skills the Electric shock will become your best friend! and if you are already an experienced 3D flyer it will be your show off aircraft. In any case, this plane will make you smile.
Go to their website for more:
I think this has to be the coolest looking plane in that size!!!! when i look at it, it makes me wanna listen to metallica
Can't wait to get my hands on one
What do you guys think about it??? I'm very impressed it looks to be the most Rock N' Roll plane i have seen
Daniel_Sim
08-09-2008 06:21 PM
Hose A
02-17-2006 02:53 AM
