New Product Announcements Vendors post their latest and greatest products here to let the world know about them
Xmotor 400B 950 kV Outrunner 177 Watts under $60!
Old 08-25-2005, 10:44 PM
2dogrc
2Dogrc's RC Warehouse
2dogrc's Avatar
Default Xmotor 400B 950 kV Outrunner 177 Watts under $60!
I am introducing a POWERFUL outrunner, the Xmotor 400B. This smooth running outrunner has a Kv rating of 950 and a max efficiency of 79%. The 12 poles help create MASSIVE TORQUE on a 3.27 mm shaft and weighing only 55 grams. The shaft can be replaced by removing a simple lock nut!
I flight tested this motor to determine actual thrust on different propellers. On 2 cells a GWS 1260 will yield 20 oz, and 3 cells yields 26 oz of thrust! This motor will handle planes from 10-20 oz! This motor is similar to a Hacker A20-20L that retails for $70!
This powerful motor also include:
  • Firewall Mount
  • 3D Wobble Prop Saver
  • 2 O Rings
  • Hardend Steel Prop Adapter
  • 3.5 mm Female plugs for ESC
  • Mounting Screws
This motor is an exceptional value and quality! I offer full support for the motors including extra firewall mounts, shafts, and prop adapters!
This motor comes in a smaller size also, the 300B, 1220 kv!
For More Information Check them out at 2dogrc.com!
2dogrc is offline
Old 08-26-2005, 12:45 AM
kaz1104
Hey 2dogrc,
Could you give me a little more info. about this motor .... current load on different prop sizes etc. Sounds like good value !!
Thanks,
Mark
kaz1104 is offline
Old 08-26-2005, 04:21 AM
2dogrc
2dogrc's Avatar
I sure can!
These results were all done using GWS props, TowerPro ESC and a 1350 8C Dualsky battery. The power might be a little better with APC props and a Higher C rating battery! To obtain this data we mounted the motor on a device similar to this:
2dogrc is offline
wattflyer6161
06-19-2007 05:25 PM
UncleBob
05-11-2007 01:20 AM
danny.act
04-18-2007 07:46 PM
Thot
05-29-2006 05:53 AM
ron_van_sommeren
10-13-2005 11:51 PM
Quick Reply: Xmotor 400B 950 kV Outrunner 177 Watts under $60!
Page generated in 0.11663 seconds with 13 queries
