Advice on CX2 Heli Please - Batteries Question
Old 01-21-2007, 04:11 PM
Crash N Burn
Default Advice on CX2 Heli Please - Batteries Question
I'm new to heli's & am loving my Blade CX2. I have a question about the Lipo Battery. It's a 7.4 800mAh. I am wondering if I can use a higher mAh, like a 7.4 1100mAh without causing any problems? Will the charger, charge that battery? Any other battery info would be good also. I plan on calling Horizon Hobby tomorrow just to see what they have to say also. Thanks, CnB
Crash N Burn is offline
Old 02-14-2007, 03:14 AM
mssample
Same question here. I would love to know what higher mAh batteries work with the CX2, if any. Would the motors overheat with the increased flight time?
mssample is offline
Old 05-10-2007, 10:39 PM
Tibroc
I am sure Horizon will tell you not to use anything higher than 800mAh.
I sell a battery that I had made just for the cx or cx2 heli it fits perfect and you get a little more power out of it. it is 7.4V 850 mAh 15c We have tested it over 3 month now and it works great. You also use your stock cx or cx2 charger. I would not use any other charger. And the price is far less than the stock battery. There is also a lot of info on Li-Po batteries that you should know. www.cx2parts.com
Happy flying,
Tibroc is offline
Old 05-11-2007, 03:11 PM
redgiki
redgiki's Avatar
You can also find what seems to be an identical battery at: http://www.xushobby.com/servlet/Detail?no=227
I have no affiliation with them other than picking up a couple of these batteries a few months ago. The E-Flite batteries are really very marginal for the CX2 and tend to die after only 30-50 flights. These batteries seem to last much better. And no, the heli gets no hotter from the better batteries; the main effect on flight characteristics is that you can hold a hover with a lower throttle setting, and climb rates are much improved.
My CX2 charger, though, would not correctly balance-charge the batteries. One was always low. Be sure to check your batteries from time to time with a multimeter to make sure the charger is doing its job. I threw away the E-Flite charger because it led to such large imbalances.
redgiki is offline
Old 10-24-2007, 02:51 PM
Darian
On the xushohhy.com site it shows these batteries for the CX2. Does the CX and CX2 use the same batteries?
Darian is offline
Old 10-24-2007, 03:13 PM
constantCrash
prefectionist
constantCrash's Avatar
CX and CX2 use the same batteries. the DNpower 900mah 10C batteries supposedly work very well as do the DNpower 850mah 15C. 1100 is probably to big and will weigh to much.
constantCrash is offline
phupper
Standard & Large E-Heli Talk
8
09-29-2009 04:16 AM
airmail wf
Beginners - Helis
09-09-2008 05:35 AM
rb8720
General RC E-Heli Talk
11
05-03-2007 05:59 AM
wfisher11
02-27-2007 08:02 PM
RSS Feed
RCU RSS Feed
08-18-2006 12:10 PM
Quick Reply: Advice on CX2 Heli Please - Batteries Question
Page generated in 0.10509 seconds with 12 queries
