Digital Servos
Old 04-08-2011, 02:10 PM
Big Johnny
Master Of The Crash
Big Johnny's Avatar
Default Digital Servos
Ok fellas and Chellie
I'm have a Hanger 9 100" Cub, the fabric covered one. The Manual say's use JR 531 servos or equavilent. I want to use digital servos or super good analog servo. I don't want to break the bank using $200.00 apiece servos. Do ya'll think these might do the trick.
Hitec HS805MG Analog
HS5645MG Digital
Big Johnny is offline
Old 04-08-2011, 03:13 PM
constantCrash
prefectionist
constantCrash's Avatar
JR 531's are good servos why not use them? they are only $40.00 each
http://www.servodatabase.com/servo/jr/531
It's a cub, do you really need ultra fast ultra strong servos?
the HS805MG has 5 times as much torque as the JR's
and are significantly bigger. so I wouldn't use that one as it would require structure modification.
http://www.servodatabase.com/servo/hitec/hs-805mg
the HS5645 is about the right size and $20.00 more each.
http://www.servodatabase.com/servo/hitec/hs-5645mg
I'd use the JR's but if you want digitial the HS5645's should work.
constantCrash is offline
Old 04-08-2011, 05:00 PM
texasclouds
texasclouds's Avatar
i'm not going to respond until you post pics of that 100" Cub
texasclouds is offline
Old 04-08-2011, 05:18 PM
Old Fart
Lost at LAX
Old Fart's Avatar
I had that same Cub. Don't consider anything for the tail servos that doesn't have metal gears....
Old Fart is offline
Old 04-08-2011, 06:32 PM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
Yup, metal gears are good for the rudder for sure.
On that model Id recommend going with double what the mfg recommends for torque. The plane will fly better with controls that respond well.
Id recommend using the Hyperion digitals. The price is excellent - close to the analogue price of Hytecs - and the quality is excellent. Plus, they are programmable with a cheep programmer if you ever need that.
One of the DS-16's would probably be fine or the DS-20's if they would fit.
They have several combinations of speed, torque and metal gears. Like CC said, you shouldnt use the ultra fast ones like the the ones with a 'G' in the suffix ie GMD.
Id consider the DS-16 FMD or the DS-20 TMD
http://www.allerc.com/servos-hyperion-c-40_259.html
Larry3215 is offline
Old 04-08-2011, 06:36 PM
HS5645MG Digital
And if you use metal geared servos, be sure to put removeable locktite in the servo arm screws
Old 04-08-2011, 09:43 PM
Old Fart
Lost at LAX
Old Fart's Avatar
If I were to have another 1/4 scale Cub, I'd run the same servos I'm running in my warbirds that size - non digital HS645MG's
Old Fart is offline
Old 04-08-2011, 10:31 PM
That's what I've got in my 17 pound Extra 330 with 2600 watt power. Four '645MG's in the ailerons, two 645MG's for the elevator, and one digital 5625 in the rudder.
So far, so good.
Old 04-08-2011, 10:39 PM
Old Fart
Lost at LAX
Old Fart's Avatar
Unless money is no object (and in that case - send it to ME), never really saw the need to go digital unless it's a 3D bird - and you're skillful enough to notice the difference.
I have 645MG's on my 25% Ultimate - buddy of mine has (at least) 4X the $$ in digitals on his otherwise identical Ultimate. I can't tell the difference (but he can)
Old Fart is offline
Old 04-09-2011, 02:50 AM
Larry3215
Larry3215's Avatar
In this case, you can get the Hyperion digitals for about the same price as the Hitec analog servos - so why not go for the better option?
Same price, more torque, better centering, better "feel", more positive control.
You dont have to spend any more money and you will look like a better pilot.
Not only that, but digitals on large birds will help you become a better pilot because the plane flys better under more solid control.
Sniperp
04-07-2011 04:40 AM
RCFlyer44
22
03-29-2011 05:55 AM
terrynshed
02-04-2011 09:33 AM
terrynshed
11-19-2010 08:48 PM
All American
07-02-2010 05:47 PM
Quick Reply: Digital Servos
Page generated in 0.14162 seconds with 13 queries
