$100 Scratch Build Contest: 30" W/S ( THEE BEAST )
Old 04-08-2011, 03:06 AM
Build Review $100 Scratch Build Contest: 30" W/S ( THEE BEAST )
Hi Everyone, I am going to make a 30" W/S My version of the BEAST, I dont have any plans for it, I am just going to cut and glue Foam together untill it looks like a BEAST I got a little start today, got the wings cut out, I think i will use a AX2308N 1800kv Micro motor and a 7x6 prop, i am thinking a 1300mah 3 cell lipo, and a 20 to 30 Amp esc, I have a bunch of odds and ends laying around, and hopefully when i throw them together, maybe it will look like a Beast Take care and have fun, Chellie
http://www.youtube.com/watch?v=wclRLPcxXLI
http://www.youtube.com/watch?v=k4q1zcBGZWA
Material Used
2- sheets of 13" x 39" 6mm Depron @ $4.50 per sheet = $9.00 http://www.rcfoam.com/cart.php?page=plans
2- packages of epoxy from Harbor frieght tools @ $2.99 each = $5.98
2- misc basswood 3/16" square sticks, best guess @ $1.00 each = $2.00 Hobby people
packing tape part of roll best guess $2.00 Kmart
2-empty bottles @ free Recycled Trash
1-micro motor 1800kv HK, AX2308N $4.99
1- 1300mah 3 cell lipo 20C @ $6.99 Hk
2 wheels from 5 piece bag, $1.00 HK
1- misc. wire for landing gear best guess $1.00 Hobby People
1- misc velcro $1.00 best guess from HK.
1- misc bracing plywood $1.00, Hobby people
2- misc testors spray paint $8.00 Hobby People
4- HXT 9 Grams Servos @ $2.69 ea = $10.76 HK
1- Rear tail wheel & wire approx $5.00 HK
1- Berg Receiver used $20.00 BP Hobbies
1- 30 amp esc mystery E Bay $9.33
1- 7x6 prop $1.00 HK
1- prop adapter 3mm HK $1.22
estimated total so far $91.45
Old 04-08-2011, 03:14 AM
hillbillynamedpossum
Rode the short bus
hillbillynamedpossum's Avatar
Welcome to the contest. Glad to have you!
Possum
hillbillynamedpossum is offline
Old 04-08-2011, 03:41 AM
Stevephoon
Stevephoon's Avatar
Chellie,
I wondered where the foamies were in this contest. I've only built balsa planes so far, so I'm still sticking with that. (For now ) Welcome!
Stevephoon is offline
Old 04-08-2011, 04:23 AM
Possum
Thank you Possum
Originally Posted by Stevephoon View Post
Chellie,
Thank you Steve, I have a lot of foam laying around, and i have not scratch built anything for a while, Soooo, Time to Build Again Take care, Chellie
Old 04-08-2011, 04:37 AM
I was looking for a cowl for this Plane and I Think I found one Its a Gatorade Bottle, I guess the Redemption value will have to be listed for this Bottle about 3 cents LOL
Name:	Copy (1) of IMG_0001_1.jpg
ID:	146117   Click image for larger version
Name:	Copy (1) of IMG_0004_1.JPG
Old 04-08-2011, 06:04 AM
jungmann1
electron deficient
Tropical mango!? Hope you had a couple shots of Pirate rum to go with that. Watching with bated breath. Oh, and how am I going to copy your work if you don't have any plans? Sorry, you gotta do plans. J.
jungmann1 is offline
Old 04-08-2011, 06:09 AM
Hi I will Draw some plans after i finish this plane, and only if it flies well, I dont want to make plans for a dud Just Incase Take care and Have fun, Chellie
Old 04-08-2011, 06:24 AM
Default Fuselage Started
Hi Everyone I Started on the Fuselage, It will be 6mm Depron, that has been scored on the back side, Heated and Rolled to form the Fuselage, I am Pretty good at Rolling Paper but lets see how i do with Foam LOL, After the foam is Rolled, Dont worry, i wont smoke it then i can cut and trim the rear fusalage as needed.
ID:	146121   Click image for larger version
Old 04-08-2011, 08:48 AM
Starting to roll the foam now, its getting there My ZoomBrowser went out on my pic resizer and I am Not Comp. Lit. at all, I just struggled for a couple of hours trying to get it regoing again, Finally, had to delete the program and reboot it, What a Pain, I am lucky just to get on the web and onto forum sites I lucked out this time, normally i need to get my son to fix this Junk hey, I am a Baby Boomer Ok here is what has been done so far, took my tool tote trays and used them to hold the foam, while i took the heat gun to the foam, dang that foam stinks when you get it to hot Take care, Chellie
ID:	146124   Click image for larger version
ID:	146125   Click image for larger version
Old 04-08-2011, 12:22 PM
Its me Again Well my first try did not go so good trying to roll up that 6mm Depron, I know that 3mm would have been better to use, but i did not have any The first foam tube got broke by my youngest son, he was holding the fuselage, as i was applying rubber bands to the fueslage to try to get it together, and then i heard a snap my son squeezed the back part of the fuselage by accident and broke it, i thought i might be able to use it, and went ahead put the fuselage in the oven to preheat it a little more, we had just made some chocolate chip cookies, the oven was cooling down, and i figured the little heat would make the foam easier to work with the rubber bands pulled foam in and folded it up that happened in the back of the oven, where i could not see it very well Oh well, make another one, this time it came out much much better here are the pics, Enjoy, Chellie
ID:	146127   Click image for larger version
ID:	146128   Click image for larger version
ID:	146129   Click image for larger version
ID:	146130   Click image for larger version
Old 04-08-2011, 03:51 PM
jungmann1
electron deficient
MMMMMMmmmmmmm, cookies.
Old 04-08-2011, 03:55 PM
jungmann1
electron deficient
Gatorade rum punch and now weed jokes! We are seeing a whole new side of you, Chellie. The Beast is looking good. That is quite a trick, rolling that fuse without it buckling. You are to be commended. Do you think the 3mm would have the strength you need? I bet that 6mm is pretty stout. Keep up the good work, young miss. J.
Old 04-08-2011, 04:02 PM
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
Hi Chellie
Shes coming along wonderfully, great job
Cant wait to see more
Take care dear friend
Yours Hank
kenchiroalpha is offline
Old 04-08-2011, 05:51 PM
road king 97
old hat
road king 97's Avatar
Ahhh, beauty and the beast ,iam sighned up for the build . joe
road king 97 is offline
Old 04-09-2011, 01:29 AM
Weed I rolled Prince Albert Tobacco
Originally Posted by kenchiroalpha View Post
Hi Chellie
Yours Hank
Hi Guys Its getting there, Forming the Fuselage at the back part might be a little bit of a challange, One step at a time, after that, its all down Hill
Old 04-09-2011, 01:47 AM
HO-229
PROVERBS 27:17 ROGUE!
HO-229's Avatar
Like the use of the Gatorade bottle!
I really like H2O!
Love this scene from the movie!
[media]http://www.youtube.com/watch?v=kN-wG6IsFVw&feature=related[/media]
Watching with interest
Dave
HO-229 is offline
Old 04-09-2011, 05:46 AM
Hi Everyone I made a little more progress, I cut the back section of the fuselage, heated it, and sqished it together and cut out the cockpit area, I think that was the hardest part of this build, it should be down hill from here I Hope, Enjoy the pics, Chellie
ID:	146237   Click image for larger version
ID:	146238   Click image for larger version
ID:	146239   Click image for larger version
Old 04-09-2011, 06:00 AM
cncfoam
cncfoam's Avatar
Default geometry
I like that geometric transition with one piece.
I need to find some sort of cowl like you have but need it to
fit on my profile. I will find something.
nice job.
cncfoam is offline
Old 04-09-2011, 06:29 AM
nice job.
Thank you for the complement Plastic bottles work great and cheap too Take care and have fun, Chellie
Old 04-09-2011, 08:41 AM
max2112
max2112's Avatar
Hi Chellie, Great Build so far!
Do you plan on doing the rigging wires for the wings?
This thread reads like an Abbot and Costello routine!
"Excuse me, do you have Prince Albert in a can? ....."
max2112 is offline
Old 04-09-2011, 09:32 AM
Hi John No I dont think i will need the rigging wires, because i am going to be using 6mm CF tube in the wings, But i might for looks I will see how it goes, Thank you for the complement, Take care, Chellie
Old 04-11-2011, 07:04 PM
road king 97
old hat
Two or three days into your build chellie and you already have a fuse, wings, and cowl .I need to stop building with balsa and start buying foam plates and plastic jars. lol She looks great chellie ! joe
Old 04-12-2011, 03:24 AM
Thank you Joe It should be done tonight minus the power system
Old 04-12-2011, 05:51 AM
Looking great so far!
Old 04-12-2011, 06:41 AM
Hi Everyone I cut out the Tail Feathers tonight, and will get them glued in, its getting there, I am Using the T L A R method to make this plane, That, Looks, About ,Right, Looking for a canopy, i think this window cleaner bottle will work, it looks like a canopy to me Take care, Chellie
ID:	146407   Click image for larger version
Quick Reply: $100 Scratch Build Contest: 30" W/S ( THEE BEAST )
Page generated in 0.15172 seconds with 30 queries
