Axi 2820/10 ripmax spit motor mounting help please
Old 01-28-2008, 03:23 PM
Darkstormphoenix
Darkstormphoenix's Avatar
Default Axi 2820/10 ripmax spit motor mounting help please
Helo guys i have just purchased a ripmax spitfire and a axi 2820/10 motor and the axi motor mount kit
is how do i mount the motor please,
As you can see in the picture do i have to you the black x clamp inside or outside the firewall please,
I have never built a plane before so its quite a big learning curve for me
Any help would be fantastic
many thanks
Darkstormphoenix is offline
Old 01-28-2008, 07:24 PM
skyvolt12
skyvolt12's Avatar
Default Mounting AX1 motor
Hi. I have been searching the web site's for a picture of the mounting no luck so far. Maybe this will help.
1. Mount the so called X- plate on the motor end that the wires are coming out of.
2. Mount the motor on the plane, and check the clearance to the motor Assembly
3. Then mount the prop adapter, check for prop clearance.
I hope this helps somewhat! skyvolt12
skyvolt12 is offline
Old 01-29-2008, 08:24 AM
SCC
The motor is back mounted. You will need one of these.
http://www.e-fliterc.com/Products/De...rodID=EFLM1925
Hope to start my build soon with the same motor.
I asked a similar question recently at RCG. Here are a couple of pics that were posted in response. Note the reinforcement down the sides of the box mount. I will do the same.
http://www.rcgroups.com/forums/showp...postcount=1466
SCC is offline
Epowerreg
03-24-2008 11:20 PM
fezz
Warbird Electrics
52
02-21-2008 01:13 AM
gareth08
11-06-2007 03:15 AM
GLIDERS
06-24-2006 04:37 AM
hoongts
08-30-2005 06:14 AM
Quick Reply: Axi 2820/10 ripmax spit motor mounting help please
Page generated in 0.06376 seconds with 13 queries
