World Moedels 63" Spitfire
Old 12-17-2005, 04:08 AM
Stolly
Default World Moedels 63" Spitfire
Hi guys, I have a 63" almost 8lb spitfire ready to go but cannot get the motor to run. This is the setup 9s1p kokams 3 packs of 3200mah 11.1 volt, Phoenix 85hv esc and an Axi 4130/20 up front with a 15*8 3 blade prop.When I go to start the motor all I can get is a short really rough run of about 5 seconds and very slow revs. When I arm the controller I get the long beep followed by a series of short beeps, about 7 then the long beep again.I have tried all sorts of combinations of programming the esc but to no avail.
Hope somebody can help.
Garry Stoll
Euston
Australia.
Stolly is offline
Old 12-19-2005, 01:46 AM
cyclops2
Give Pheonix this problem as long as you are sure your battery voltage stays up during the short motor run.
cyclops2 is offline
Old 12-20-2005, 09:48 AM
Stolly
I have rung Castle Creations and they are going to replace the controller at no cost to me. There have been problems with this model and they are happy to send me a newer model. More power to them I reckon.
Stolly
Stolly is offline
Old 12-20-2005, 01:36 PM
qban_flyer
Guest
Posts: n/a
Lightbulb
Either an improperly programmed controller or a defective one. I'd suggest you contact C/C.
Old 05-05-2009, 08:53 PM
old1940ford
I have this fairly good size Spitfire myself. I was wondering. Are those superglue hinges good enough for this. Also, did this one run with the 9 cells in series, that would be something like 32 Volts? Could 11 volts haul it?
old1940ford is offline
Old 05-14-2009, 02:46 AM
calven
calven's Avatar
I'm putting this one together also, I use the ca hinges, they will be fine. I'm powering with turnegy 50-55 400kv, on 6s 4000 zippy packs. More than enough power, with 14x7 3 blade master airscrew prop. I use the 80 amp turnegy esc. With a bit of work, this should be a decent looking plane, I'll be modeling it after a MkXVI spitfire. I've already added the wing fillets, next chore is to mod the flaps, spitfires just have to be split flaps! Will add cockpit work, a decent looking pilot, and it's gotta have GUNS! Once I'm done, it should be a decent sport scale plane. I'll try to post some pics when I'm finnished.
calven is offline
Old 05-14-2009, 08:10 AM
Biplane Murphy
2 Wings, Twice The Fun
Biplane Murphy's Avatar
I have had this one for a few years.
But mine runs on wet fuel.
My birddog in the photos just happens to be named Spitfire too.
Name:	sunday flying may-20-07 047.jpg
ID:	100928   Click image for larger version
Name:	sunday flying may-20-07 046.jpg
Biplane Murphy is offline
Wrench66
16
09-30-2008 03:19 PM
bassmanh
Warbird Electrics
64
11-01-2007 03:45 PM
Sky Sharkster
12-27-2006 04:33 PM
rahtware
Aerial Photography
09-14-2006 04:18 AM
Stolly
20
12-30-2005 09:00 AM
Quick Reply: World Moedels 63" Spitfire
Page generated in 0.12203 seconds with 17 queries
