PZ Spit-giving up on aileron cables
E-Pilot
I have been working on getting a little more throw out of the cables on my PZ Spit ailerons. The darn things are just too stiff, I even bought a higher torque servo and it still won't center without protesting.
I'm giving up and going with dual servos in the wings. I was thinking of mounting them on the top of the wing since it's a belly flopper, and running the wires through the wing to the bottom and using the slots for the cable to run the wires.
Any advice?
Any advice?
try jamming a bunch of dry graphite lubricant into the cable tubes. really work the stuff in there. also, make sure the cable ends are well-connected to the servo arms. i straightened the ends near the servo ans used a proper control-rod connector (rather than simply wrapping the cable around the arms)
i almost got rid of that single servo setup as well. but this gives my spit plenty aileron throw.
the HET Typhoon motor and 2200 mah pac doesn't hurt either
E-Pilot
Obviously the cables work for some people, but I think it is a weak system. There are a couple of factors against it. Somewhat stiff hinges and lots of drag on the cables.
I'm not saying it can't work, I think its just for me its less hassle and more adjustable to go dual servo. I have a Super Cub that runs dual aileron servos, and I'm fooling around with spoilers and flaperons.
I'm noticing all the new RTF stuff from ParkZone and ARF from E-flight have gone to dual servo. I'm wondering if thats because its cheaper to produce or they do it because it works better or is more reliable?
