Own design F8F Bearcat
Old 09-09-2008, 08:07 AM
SkyeHighRC
SkyeHighRC's Avatar
Default Own design F8F Bearcat
Here are some pics of my scratchbuilt Bearcat. It has a 30" wingspan, balsa sheeted blue foam wing. Hot wire cut hollow blue foam fuselage with light ply reinforcements. Covering is yellow econocoat. AUW is 16oz. I used a color laser printer and some clear polypropylene adhesive label material to create all of the panel lines, rivets and insignia. Chrome vinyl adhesive label stock on the LE of all surfaces to add some more scale realism. This is really a semiscale version as the tailgroup was modified with some counterbalance ends to help the micro servos. In retrospect, not needed AT ALL since I have very little throw in the elevator after its first flight today. With such a short tail moment it is amazing how easily over controlled it could be. I will reduce the servo's control horn mounting hole and link up closer to the center of the servo for better response. I flew at 40% Dual rates on the elevator and 80% on the ailerons and had still alot of control.
The power setup is a 9x6 apc on a E-flite park 370 brushless outrunner. 3S 1320mah Thunder Power lipo (13C). From the limited amp reading tool that I have the max amp drawn was less than 10 but I am using an E-Flite 20 amp esc.
Hand launches were done at 1/4 throttle or less. Less than 1/2 throttle for most of the early stages of the first flight. NO TRIM NECESSARY at all once the rates were dialed in. A THING OF BEAUTY.
I flew today in gusty winds of up to 15mph. It got tossed around a good bit but penetrated the wind with no problem. WOT was crazy fast for me and this little ship. It is all relative speed but I would guess on a calm day, 50-60mph on a low pass is not unrealistic. With wind in the mix that makes for some solid stick management.
Anyways, if you wanna know anything about her let me know. I will link the video of the maiden and first couple flights shortly.
ID:	77635   Click image for larger version
ID:	77636   Click image for larger version
ID:	77637   Click image for larger version
ID:	77638   Click image for larger version
SkyeHighRC is offline
Old 09-09-2008, 08:37 AM
Wow very Nice plane, Good job, Take care, Chellie
Old 09-10-2008, 09:22 PM
wilmracer
Beautiful!
wilmracer is offline
Old 09-10-2008, 10:13 PM
SkyeHighRC
SkyeHighRC's Avatar
Video coming this Friday.
Old 09-10-2008, 10:32 PM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
Great job!
Grasshopper is offline
Old 09-10-2008, 10:40 PM
gfdengine204
gfdengine204's Avatar
That is fantabulous. Was yellow used on the Bearcat? I think I have only seen the blue.....your color scheme is amazing!
gfdengine204 is offline
Old 09-10-2008, 10:48 PM
alienx
alienx's Avatar
Really nice bird. I love the Bearcat. Looks good in yllow too.
alienx is offline
Old 09-10-2008, 10:52 PM
SkyeHighRC
SkyeHighRC's Avatar
Here are some links of interest. This is where the idea came from:
http://www.modelingmadness.com/revie...ean/cazf8f.htm
http://www.rcgroups.com/forums/showthread.php?t=89280
Old 09-10-2008, 10:53 PM
SkyeHighRC
SkyeHighRC's Avatar
I will try to get some Photos of the inside for you guys, it is roomy.
Old 09-10-2008, 10:58 PM
gfdengine204
Very cool, thanks for sharing!
Old 09-11-2008, 03:56 PM
RickAvery
Nice JOB!!
Rick
RickAvery is offline
Old 09-13-2008, 02:44 AM
SkyeHighRC
SkyeHighRC's Avatar
Default Here is the video
<object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/NkQo9EFBuDE"> </param> <embed src="http://www.youtube.com/v/NkQo9EFBuDE" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
thunder1
Warbird Electrics
07-04-2008 06:31 AM
RCFlybry
Foamies
11-19-2007 03:18 AM
thunder1
11-21-2006 01:24 AM
JohnVH
Warbird Electrics
10-22-2006 07:46 PM
edge540T3
Warbird Electrics
04-07-2006 04:30 PM
Quick Reply: Own design F8F Bearcat
Page generated in 0.12976 seconds with 20 queries
