Too much power
Old 11-23-2018, 06:13 PM
dusty
Default Too much power
Rage RC vintage stick flies great outdoors, but its way too fast for our gym. I'd prefer to fly it indoors. Need power for take off but only requires about 10% throttle to maintain flight. Receiver is non DSM2. Any ideas on how to slow it down would be appreciated.
dusty is offline
Old 11-23-2018, 06:47 PM
Rabbitcreekok
Rabbitcreekok's Avatar
Not meaning to be a smart alec, but fly it with 10% throttle, if that makes it fly slower.
Rabbitcreekok is offline
Old 11-24-2018, 12:22 AM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Use prop with less pitch.
ron_van_sommeren is offline
Old 11-24-2018, 12:55 AM
Past President of PSSF
Many indoor planes use drag plates to slow them down.
Even my 4-Site bipe moves pretty fast.
Wildflyer is offline
Old 11-24-2018, 06:12 AM
dereckbc
Ditto. In addition if your TX is programmable, you can limit the Throttle or use Expo.
dereckbc is offline
Old 11-24-2018, 11:45 AM
exactly ... pitch down .... use throttle curve ..... D/R etc.
You can never have enough power ... just need to sort controlling or rationing it !
Old 11-24-2018, 06:11 PM
ron_van_sommeren
Current and power drawn are proportional to pitch, and proportional to prop-diameter⁴.
Current drawn is proportional to voltage≤ and Kv≥.
Originally Posted by dereckbc View Post
... In addition if your TX is programmable, you can limit the Throttle or use Expo.
However, if current at wide open throttle is too high for the controller then reducing throttle to get current below ESC max.current is not a good idea. It is even harder on ESC than to keep overamping at full throttle. Better to prop down a bit to reduce current.
See:
Old 11-25-2018, 05:24 AM
pmullen503
I had a similar problem, wanted full power for take off but only needed 10 or 15% for flight. I added a throttle curve that gave me much more stick movement at low levels. 0-75% stick was 0-25% throttle, 75%-100% stick was 25-100% throttle.
pmullen503 is offline
Old 11-25-2018, 08:28 AM
The use of throttle curves is actually a good thing on most models. I think most of us can relate to the lack of fine sensitivity to throttle in certain range for certain models. Particularly in 3D and aerobatics.
Apply a curve to give greater control in the range for manoeuvres and it becomes really sweet.
Curves are not just for Heli flyers !!
Old 12-11-2018, 09:25 PM
ron_van_sommeren
And contrary to engines, e-motors cannot overrev. Rpm can never get higher than Kv ◊ batteryvoltage.
CNY_Dave
18
12-05-2017 07:49 AM
The MacDaddy
Batteries & Chargers
02-08-2017 03:15 AM
01-09-2017 03:23 AM
brnyrbbl
Beginners - Helis
54
12-03-2016 12:08 PM
DannyShadow
10-29-2012 02:17 AM
Quick Reply: Too much power
Page generated in 0.07938 seconds with 12 queries
