Go Back  WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Scale E-Powered Aircraft
Reload this Page >
Gnome 9-B2 Monosoupape rotary engine assembly animation (11min.)
Old 06-16-2020, 07:58 PM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Default Gnome 9-B2 Monosoupape rotary engine assembly animation (11min.)
Rotary engines and Sopwith Camel info by Pierre Janssen
www.PJvision.nl
More rotary engine animations and videos by Pierre Janssen, Clerget, Bentley, Gnome, Le Rhône:
www.youtube.com/channel/UCbyGXbMxmWfH8XsXzmmddhQ/videos
ron_van_sommeren is offline
Old 06-22-2020, 10:25 PM
Wow, They had Roller Lifters and Rocker Arms way back then Hmmm where does the exhaust go, into the crank case where does the exhaust Exit, the valve is for fresh air and the cylinders have exhaust ports on the bottom.
Old 06-25-2020, 12:03 AM
Chellie
The single valve was the exhaust but it also let in air.
The monosoupape (single valve) cycle although a 4 stroke has elements of a 2 stoke included in that the petrol was injected directly into the hollow but stationary crank shaft and cylinder transfer ports were used to get the very rich mixture above the piston. The exhaust valve stayed open well past TDC on the exhaust stroke so it introduced air into the cylinder to create a combustible (hopefully) mixture. Drawing air in via the exhaust valve also helped to cool it. Without high temperature steels burning exhaust valves was a real problem.
The monosoupape cycle was inefficient with a relatively high fuel consumption but the resulting engine was simple, light and for the time pretty reliable. It helped that Société Des Moteurs Gnome were excellent machinists making the entire engine from solid steel billets. .
quorneng is offline
Old 06-25-2020, 07:06 PM
ron_van_sommeren
Merci
Another Nederlander, building two works of art:
translate...Nieuport 28 C1, schaal 1:3 met scratchbuild 475cc Gnome Monosoupape
Page generated in 0.05726 seconds with 10 queries
