84 in. Cessna 182 EP conversion
Old 10-21-2005, 01:13 PM
shauntot
Question 84 in. Cessna 182 EP conversion
Fellow flyers..need your inputs on this please.
I'm planning to buy a built up 84 inch Cessna 182 from a fellow flier back here in the Philippines, it's currently running a .90 Thunder Tiger engine. Made of balsa and some fiberglass, AUW is around 13.5 lbs. (incl. the .90 engine, 7 servos, etc.)
Prob is, the engine is already slapped on and guy selling it doens't know how much the engine weighs. I'm planning to buy it to convert to EP which would be a nice project, I would like to request some details and help from you if possible.
What would be a nice power pack for this plane for it to do scale-flying? Some are suggesting around 400watts would do it, but I would like to get your opinion as well. If possible, what would be the cheapest motor from these- AXI, MEC, Hacker, etc? Or if there are any others available on the net, I would really appreciate your input.
I'm planning to run it on 12 or 14 cell NIMH 3300 GPs.
ESC recommendation would be great as well sirs.
And to wrap it all up, if you could also post how much the parts will run and where available online, that would be very much appreciated.
Here are some pics of the plane.
ID:	2910   Click image for larger version
ID:	2911   Click image for larger version
ID:	2912   Click image for larger version
ID:	2913   Click image for larger version
shauntot is offline
Old 10-21-2005, 03:28 PM
jonnyjetprop
I think that you are thinking of a power system that is far, far too small for the plane.
At 13.5 pounds with a glow and assuming that you stay with Nimh batteries, you will be looking at least 2 lbs. more than this weight. Lets say 15 lbs. ou then want a power system that will put out a minimum of 1200 watts. That's 30 volts at 40 amps. In other words, you need 30 cells or a 9s lipo battery. Even if you go with a more expensive setup using lipo batteries, I think that you would be hard pressed to get much below the original weight of 13.5 lbs. Then you are looking at something closer to 1000 to 1100 watts. Your still looking at least a 6s lipo system pulling 50 amps.
The cost of a AXI 4130-16 is about $150, speed control is going to run about $120, and for a lipo battery figure about $250. This could be a little more or a little less depending on the manufactor. Figure $120 for a lipo charger also.
I hope this helps.
John
jonnyjetprop is offline
Old 10-21-2005, 05:29 PM
shauntot
I hope this helps.
John
Hi Johnny, thanks for replying.
Whoa, I'm not quite sure, but do forgive me if I'm wrong, but isn't that a lot extra power? I mean, it's good to have lots of power, but if it won't be used, it might just go to waste (and the money for the big motor as well). I was only hoping to get the plane for scale-flying, that's it. It's just what I'm after, can't find any Cessna's of the same size for it's price. (Guy is selling to me for $180 built and covered (plane only). Additional $145 if I want to include the .90 engine, but that would be defeating my purpose of converting it to EP. He's only flown it twice on the glow engine, guy is selling it because he had to sell his SUV and has no way of transporting it to the field now.
The 13.5 lbs weight is with the Thunder Tiger .90 engine, I'm not quite sure how heavy that engine is though, so the plane is definitely less than 13.5lbs. I don't have experience in glow, maybe you have, you can probably have a rough estimate of how heavy a .90 engine is and subtract that from 13.5lbs.
Appreciate your response, thanks!
Shaun
shauntot is offline
Old 10-21-2005, 07:34 PM
Matt Kirsch
Matt Kirsch's Avatar
Agreed. 400 Watts is enough to taxi on grass... Maybe enough to get it rolling on a smooth runway. Maybe even enough to get it going just fast enough to lift off, tip stall, and smash itself to pieces on the runway...
My personal recommendation for scale glow conversions is to shoot for 100 Watts per pound, especially if you're used to horsing the plane around with a glow engine. For a 13.5lb plane, that's 1350 Watts. With 14 cells, that would mean close to 100 Amps, which is totally ridiculous. Most motors in this power range are limited to around 50 Amps if you want them to last very long. Plus, super-high-current equipment is quite expensive.
It's NOT "extra" power. 400 Watts is enough perhaps to maintain level flight, but as I said, you need much more than that to get the plane off the ground. You want adequate power to get out of trouble when necessary. Also, even though you're not using all that power all the time, the advantage is that the power system is not being stressed to the maximum all the time either.
Matt Kirsch is offline
Old 10-21-2005, 11:38 PM
jonnyjetprop
Tower Hobbies list an OS 91 at 24.3 oz. with muffler.
Hobby People lists the Magnum 91 at 25 oz. with muffler.
John
Old 10-22-2005, 04:58 PM
Nitro Blast
Nitro Blast's Avatar
On mine:
Phasor 45 with Castle 60amp controller. 4s2p Batteries. Running 14.8 volts at 8000mah I have plenty in this bird.
Loops rolls, inverted flight... yeah you know.. all that scale stuff too.
Upon closer inspection, I think your bird is a tad bit heavier and bigger than mine! Hmm.... nevermind!
Nitro Blast is offline
Old 10-23-2005, 07:23 AM
shauntot
Hi Matt, thanks for the insight. Sounds right, it won't be good to just have enough power,better to have extra to avoid taxing the power system.
1000 watts would be great, sorry if I'm a bother, but could I bother you for some motor and esc combo recommendations that would give that power output? And about the NIMH batts - how many 3000mah cells would suffice? Thanks again
Shaun
shauntot is offline
Old 10-23-2005, 02:43 PM
jonnyjetprop
With a power system running at 40 amps,
20 cells = 800 watts
30 cells = 1200 watts
With apower system running at 50 amps,
20 cells = 1000 watts
30 cells = 1500 watts
Battery weight
20 cells:
3300 mah nimh 40 oz.
3700 mah nimh 46 oz.
30 cells:
3300 mah nimh 60 oz.
3700 mah nihm 69 oz.
ESC:
20 cell Castle Creations Phoenix 80,
30 cell Castle 45HV, 85HV, Jeti 77o, Jeti 90 (these can work at 20 cells also)
Motors:
AXI 4130-16 on 20 cells, AXI 5320-28 on 30-32 cells, AXI 5330-18 on 30-32 cells
Astroflight 40G brushless on 20 cells
Hacker C50 series -10L on 20 cells, XL on 30 cells
Kontronic has motors in that range
Neu Motors
John
Old 10-24-2005, 04:52 PM
shauntot
Hi John,
Thanks for the various recommendations. As per your chart, I'm planning to run it on 20 cells, on 50 amps. Which then brings me to 20 cells of 3300mah and AXI 4130-16 on the Jeti 77 ESC.
Got this from the hobbylobby site:
"AXI 4130 Series External Rotor Brushless Motors
Very high torque motors capable of spinning very large props in sport aerobatic models of 10-12 lbs. and sailplanes up to 16 lbs. "
Cells Prop RPM Current Watts
20 14x10 7140 39A 685w
24 14x10 8030 49.1A 975w
Is 685 watts on 20 cells good enough or do I need the 975 watts on 24 cells?
Thanks again
Shaun
shauntot is offline
Old 10-24-2005, 10:27 PM
jonnyjetprop
Take this with a grain of salt since I've been all lipo for a couple of years, but I'd go with the 24 cell pack as I'm sure at that current draw, you'll see some voltage depression. I'd personally look into the 3700 mah cells if you can get them.
John
Old 10-25-2005, 05:29 AM
shauntot
Yup, 3700 mahs can be had. 10 cells/2 packs = 20 cells?
shauntot is offline
Old 10-28-2005, 09:44 PM
Jollyroger
Jollyroger
Intelligent Batteries has a 3800mah that's less expensive and produces even more power. Check out Cheap Battery Packs website.http://www.unipros.com/battpacks/mai...ssion_id=19127
Jollyroger is offline
Old 10-29-2005, 08:18 AM
shauntot
thanks for the tip jollyroger, it's ok, batteries back here in the phils are pretty reasonable, a 6pc 3000mah costs only $25..add about $2 for every cell u want to add
shauntot is offline
Old 11-08-2005, 01:49 PM
shauntot
Hey johnnyjet,
I went ahead and took it a bit further to be safe, got myself an Axi 5320/28 which (on paper) will push out 1498watts on 10s lipos or 30cells nimh.
CellCount Prop RPM Current Watts
10S LiPo 18x12 6160 61.9A 1494
Now for the esc. You think the Jeti Advance PLUS 77 Amp Opto be enough for this motor? Or should I get a Castle Phoenix 85a High voltage?
Should I also be looking at a UBEC?
Thanks in advance,
Shaun
shauntot is offline
Old 11-09-2005, 06:04 PM
jonnyjetprop
I'd go with the Castle esc and I use a seperate receiver pack in my planes.
John
Old 11-10-2005, 08:52 AM
shauntot
Cool, thanks John
shauntot is offline
Loti Bob
ParkFlyers
10-10-2008 12:10 AM
help me
ParkFlyers
01-31-2008 08:43 PM
cessna337
10-15-2007 05:51 PM
stanlazi
12
04-16-2007 06:56 PM
ernest harvey
Scale E-Powered Aircraft
08-07-2006 08:57 AM
Quick Reply: 84 in. Cessna 182 EP conversion
Page generated in 0.12281 seconds with 19 queries
