Motor Mount - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Motor Mount
Old 08-25-2005, 02:56 AM
altgeld1
Default Motor Mount
If the moter is mounted 1/8 inch of center to the right will that hurt the plane or affect the flight??
altgeld1 is offline
Old 08-25-2005, 12:10 PM
Sky Sharkster
Sky Sharkster's Avatar
Default Offset Motor
To Altgeld1, The short answer is "No, not very much" but it depends on a few other factors.
(1) By "Off center" Do you mean the motor is still pointing straight ahead but is not in the middle of the nose? If so, It won't be a big factor, you've just made the right wing 1/8" shorter than the left, total span difference 1/4" which will cause the model to bank or yaw to the left. Picture a twin engine model, viewed from the top: The left engine quits. The right engine is still pulling, which way does the plane turn? Left! This (in a much smaller way) is what your motor off-center will do.
(2) By "Right" do you mean righthand side of the model as viewed from the rear or top? The top view is also called the "Plan view" and is the standard perspective when describing side thrust alignments. If you are describing the view from the FRONT, it's opposite, plane will turn right.
(3) If the motor is ANGLED to the right (viewed from the top) 1/8", # 1 and 2 don't apply. It will cause a VERY hard right turn and you should fix it before attempting to fly the model. A little right thrust (angle, not off-center) is normal in clockwise turning props (viewed from the rear) but 1/8" is WAY to much. The normal offset is usually measured in degrees and 2-3 degrees is plenty. If you live near a flying site or hobby shop, bring the model there and have an experienced modeler look at it, you will save yourself a lot of trouble.
(4) We're assuming ALL other parts of the plane are in alignment, right? No major warps, twists, angles, etc.
Wish I could give you a more definitive answer, but without seeing the model, size, shape and thrust alignment all I can do is make a guess. Hope some of this helps! Sky Sharkster
Sky Sharkster is offline
Old 08-26-2005, 06:02 PM
flypaper 2
flypaper 2's Avatar
My Shocky is about 1/2 in.to left of centre and flies fine. Batt. is mounted on right side to balance.
flypaper 2 is offline
michael7810
02-07-2008 03:16 AM
autorail1
Brushless Motor Construction
09-26-2007 03:55 AM
diverdon
06-19-2007 12:36 PM
Topdoc
10-23-2006 01:59 PM
alienx
09-04-2006 08:22 PM
Quick Reply: Motor Mount
Page generated in 0.05094 seconds with 12 queries
