Good W/Lb area for 3d flying...
Old 12-12-2008, 03:39 AM
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
Default Good W/Lb area for 3d flying...
Well im looking for good combos from grayson hobby those that are motor and esc paired togethere like this one below:
http://www.graysonhobby.com/catalog/...roducts_id=619
how do i tell how much like thrust it makes?
GreenAce92 is offline
Old 12-12-2008, 03:27 PM
EDFrules
GravesRC enabler d:)
EDFrules's Avatar
Looks like it's for 7-17oz planes. You might assume a 7-10oz plane could 3D with it. Looks like you'll get around 84watts or so according to specs on a 9 x 5/3s. I would try a GWS 9 x 5 DD prop(butter knife blade). Gives you a little better throttle response than a slo-fly prop.
EDFrules is offline
Old 12-12-2008, 11:51 PM
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
Wait let me retittle this thread lol to "how many watts per/lb good for 3D flying"
i know yours would prolly be 250lol
so heres what im thinking, if i have 100wats of power, if my plane is under 10oz or ahh crap im getting that that is around 63w/lb? (did 10/16oz's and then multiplied by 100watts) so maybe if i had 150... dang it...
hmmm
200 watts gives me 125w/lb hows that?
not even sure if how i found it is right
Old 12-13-2008, 12:29 AM
EDFrules
EDFrules's Avatar
We have to use some quesswork as all the pertinent figures are not available. If your plane weighs 10oz(.625lbs) and you're getting 100watts then 100watts div. by .625lbs=160watts/lb. 150watts/lb is considered to be marginal 3D power. I prefer around 200watts/lb. This is not nessicarily because I need all that power, I only have to use 3/4 throttle at most and this puts a lot less stress on the power system than a lower power rating. My packs/motor/ESC usually come down warm. Down here in the sunshine state I find this esecially critical in the warmer months as the system doesn't get nearly as hot as with a lesser powered system. Don't know if that makes sense or not but it works for me. Sort of like you can pull a boat behind your truck with a 6 cylinder engine but it has to work hard to do it but if you put an 8 cylinder engine under the hood it will pull no problem without putting your foot to the floor If you've seen our vids you'll notice the planes have plenty of power yet the power system is not overheated at all. Find that's the key to making the power components last. Hope that helps Of course the watts/lb is a general rule of thumb. Thrust/RPM and amp draw are also important as well as being able to spin the correct sized prop. High KV motors that swing small props are generally not good for 3D. Low pitch and larger diameter are what we look for in a good 3D prop.
Jason
EDFrules is offline
Old 12-13-2008, 12:30 AM
TDisaster
TDisaster's Avatar
hmmm
Um Jake that would actually be around 160 w/lb... I didn't do the math so I know I'm off, but your wayy off on that one. If you have 100watts, and have a plane that weights 10oz (under one pound) how do you get lower than 100 watts/lb?
TDisaster is offline
Old 12-13-2008, 12:31 AM
TDisaster
TDisaster's Avatar
Lol ya beat me EDF .
Old 12-13-2008, 01:04 AM
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
Whoops crap... well im not too good on problems solving yet... lol
Thanks for the info EDF and 3D
Old 01-31-2009, 04:01 PM
Jezmo
If you are going to do any hovering look for something in the 200W/LB range. If you get in trouble punch out is lazy with anything less than that.
Jezmo is offline
jobu
3D Flying
14
10-27-2008 07:36 AM
GreenAce92
3D Flying
25
08-20-2008 12:59 AM
GallopingGhost
16
07-14-2007 08:14 PM
Capt_Cohiba
iTrader talk
03-15-2007 09:04 PM
zooman
General RC E-Heli Talk
03-13-2007 12:27 AM
Quick Reply: Good W/Lb area for 3d flying...
Page generated in 0.08269 seconds with 15 queries
