Harmon Rocket Conversion
Old 06-07-2007, 07:26 AM
Bonefisher
Default Harmon Rocket Conversion
Hello everyone...
Been working on my first e-conversion after flying park stuff for a while and wanted to get opinions... I saw this kit and my brother got me her as a gift...
Summary as follows:
  • Harmon Rocket (50 inch / 558 sq in wing)
  • E-Flight Power 46
  • Castle 60
  • Master Airscrew 13X8.5
  • Flight Power 14.8v 5000 mah
  • Spektrum DX7
  • JR Digital 821 all around
  • Static pull of 65 amps max & 960 Watts
  • Approx flying 56 amps & 830 Watts
  • 6.6 lbs vs 6.4 for Gas
  • Approx 120 watts / lb
Major Mods included
  • Battery Tray creation (all forward for cg)
  • Cooling holes throughout and cowl
  • Exit air holes in back
  • Support rods for Horiz stab
I flew her once last weekend with a XOAR 14X7 electric prop, and while ok, did not have quite the speed I was looking for, so I hope the 13X8.5 will do the trick.
Anyway, first one of these so I would truly appreciate feedback and comments...
Many thanks!
ID:	32955   Click image for larger version
ID:	32956   Click image for larger version
ID:	32957   Click image for larger version
Bonefisher is offline
Old 06-21-2007, 04:20 AM
angrycookieman
Did you get it sorted out yet? If you want more speed, going to a 5 cell lipo should help a lot. How do you like the power 46? I just bought one, just don't have a plane picked out yet. I want to put it on something that really spanks the glow version for the guys at the field.
angrycookieman is offline
Old 06-27-2007, 06:34 AM
Bonefisher
Hello..... I am looking good with it now.... I got a Masterscrew 13X8.5 and the plane is flying great... very quick.... almost 10 minutes of flying time... and this is at almost 7 lbs... I switched out the spinner to a small tru-turn aluminum and it helped a great deal in effeciency as well...
Love the power 46.... i might go to 5 cells, but i am already pulling 65 amps static!
Old 10-03-2007, 10:32 AM
Aussie E-Flite
VH 22897
Aussie E-Flite's Avatar
Default Harmon E-Rocket
Hello Bonefisher,
How goes the Harmon Rocket? I am looking at adding this one to my hanger. Probably use the the E-46 as well with 5s LiPo.
Did you make a battery hatch or just access by removing the wings?
Thanks.
Keith.
Aussie E-Flite is offline
Old 10-14-2007, 06:49 AM
Bonefisher
Default Sorry for the delay
I remove the wing and built a cradle for the battery...
Let me know how it goes on 5S!
Old 10-26-2007, 08:10 PM
YOHH
Hi..Ia'm useing two 3s lipos in series,cut a small hatch just behind the cowl,slide batteries in on velcro.works well. HH
YOHH is offline
Old 01-12-2009, 03:23 PM
JonC45
Fyby
Hi Bonefisher,
How is the Harmon Rocket going. Are you still flying it?
I'm currently putting one together using an Extreme RC 3520 Motor, 5Cell Lipo, 13 x 8 prop. 80amp ESC. Will also be using Spectrum DX7.. When I get to pick it up.
This is my first conversion, I have some concerns with the engine mount. Did you extend the fuselage or shorten the cowl to accomadate the motor. Did the rear mounted servos cause you to add much weight to the front end. It would be cool to see a couple more photos of construction if you have any.
JonC45 is offline
WaldoXerxes
03-17-2011 05:45 AM
Kosh
Delta & Flying Wings
51
10-22-2008 12:46 AM
Sky Sharkster
Off Topic Chit Chat
05-20-2008 06:54 PM
jobu
05-18-2008 05:56 PM
32tudor
03-26-2006 01:49 AM
Quick Reply: Harmon Rocket Conversion
Page generated in 0.10121 seconds with 18 queries
