Bobcat ducted fan conversion
Old 01-31-2008, 08:15 PM
glider pilot 1111
Default Bobcat ducted fan conversion
I have a new project on the table. It's a Bobcat 52 from Nitro Planes.
It's designed for a 50 size nitro. Those silly guys. I'm putting a 4.5" ducted fan and 12 cells on it. If it holds together it will put the nitro boys to shame. Moto Calc est. is 168 mph. Not bad for a $100 ARF.
Pictures and setup info to come.
Name:	Bobcat-08 (Large).jpg
glider pilot 1111 is offline
Old 02-01-2008, 06:59 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
Sounds like fun!
larry
Larry3215 is offline
Old 02-01-2008, 08:52 AM
Shing Kan Zen
more info & photo pls.
Shing Kan Zen is offline
Old 02-11-2008, 01:30 PM
kp647
you may want to look at this thread on ezone, my brother is working on a similar project
http://www.rcgroups.com/forums/showt...ghlight=bobcat
kp647 is offline
Old 02-14-2008, 07:06 AM
glider pilot 1111
Default Bobcat mods
I've been working on my Bobcat and have ended up highly modifying it. One of my good friends has a c n c router, so we decided to get some use out of it. He machined up an aluminum heat sink for the motor and is now working on a carbon fan mount.
I plan on using a cradle to takeoff, so this takes over a pound of wood and retracts out of the plane. So far on the Bobcat I've removed all the unnecessary wood in the fuse. To add strength back in I placed a strip of carbon fiber on the bottom of the fuse. Since I'll be belly sliding in I needed to put the aileron servos on top , so I placed them inside the booms. I needed to cut a notch out of the boom , so I fiberglassed the inside of the boom to strengthen it. This will also help with drag.
Final mod so far. We decided it needed a removable canopy, so today I wrapped the inside of the canopy opening with balsa and glassed that in.
It's coming along!
Name:	Bobcat-15 (Large).jpg
ID:	55715   Click image for larger version
Name:	Bobcat-04 (Large).jpg
ID:	55716   Click image for larger version
Name:	Bobcat-09 (Large).jpg
ID:	55717   Click image for larger version
Name:	Bobcat-16 (Large).jpg
ID:	55718   Click image for larger version
Name:	Bobcat-17 (Large).jpg
Old 02-14-2008, 07:27 AM
glider pilot 1111
Default Bobcat set up
To power this Cat I'm using a 4.5" fan and a KB45-17XL from www.hobbycity.com . I'm also using their low profile mg aileron servos on ailerons and rudders. On the elevator I needed a small high torque servo, so my bud helping me with this project gave a small JR digital. O ya.... I also modified the elevator and put the servo inside the horizontal stab.
The only exposed servos are the rudders and I think I'm going to mold covers for them. Erasing as much drag as possible. Batteries are from www.maxamps.com 2- 6s 4000mah in series.
This Bobcat should move !!
Name:	Bobcat-14 (Large).jpg
Old 02-14-2008, 07:30 AM
glider pilot 1111
Thanks for your bros link. I'd link his opinion on my mods.
Old 02-14-2008, 04:37 PM
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
Nitro Models are so darn cheap you can't buy the material and glue and covering and build anything as cheaply.That looks as good or flys so well .My flying buddie has the foamy Me 109.And I've seen Chellies Funtanna.12 cells on a edf "good golly miss molley" hope it holds together
Alpea42 is offline
Old 02-15-2008, 07:40 PM
glider pilot 1111
This is my 3rd nitro plane and I've seen others and they all look nice and fly great. Like you said , the price can't be beat. I picked up the Bobcat off one of their sales for $99.
I'm building this plane on the cheap. Most of the gear is from hobby city,
also amazing prices and the quality has been top notch.
Old 02-15-2008, 09:56 PM
Larry3215
Larry3215's Avatar
How are you going to mount the fan? Pod or pylon or?
Interesting project!
Larry
Old 02-16-2008, 04:58 AM
glider pilot 1111
We'll be cutting the mount next week. I'll post pictures asap.
Old 03-02-2008, 04:39 AM
glider pilot 1111
Default DF mount
We finally got around to cutting the fan mount. We wanted to make sure it was perfect before cutting it out of carbon plate. We used plywood for our test mounts and came out with a really nice mount. I still need to trim the bolt ends off, but over all that's it.
It's in the final steps now. Just need to finish the servo extensions and
canopy. Which is about time enough for the snow to melt.
Name:	bobcat-1 (Large).jpg
ID:	58033   Click image for larger version
Name:	bobcat-2 (Large).jpg
ID:	58034   Click image for larger version
Name:	bobcat-3 (Large).jpg
Old 03-02-2008, 06:40 AM
Larry3215
Larry3215's Avatar
That looks wicked!
Larry
Old 03-02-2008, 07:13 PM
Bill G
Super Contrubutor
Bill G's Avatar
Here's my idea. Radically rework the hell out of it too look like this:
ID:	58117   Click image for larger version
Bill G is offline
Old 03-02-2008, 08:49 PM
glider pilot 1111
WOW,is that a Bobcat?? What's your power plant? How's the speed?
Even after cleaning mine up, I still think it has enough drag to keep me way below the est. speed. Still should be an Adrenalin pumper.
Old 03-04-2008, 04:49 AM
Bill G
Super Contrubutor
Bill G's Avatar
Its not a Bobcat, actually a bash made from GWS A10 nacelles and a GWS ME109 fuse. Fast and beautifully performing plane. Definitely turned me on to the performance of the twin boom Bobcat type design though. I've thought that some of the Bobcat type foamies could be bashed into one of these. Couldn't be any more difficult than making the fuse out of GWS A10 nacelles.
The plane has an EDF55 with Himax 2025-5300. Almost wish I had built it with an EDF64, but its fast enough.
Bill G is offline
Old 08-29-2008, 09:31 AM
hopiimp
Default conversion to edf
Please let me know whar edf system you made conversion with and where to buy. I am from South Africa and must buy things from overseas sometimes cause it is not always available here.
hopiimp is offline
Old 08-29-2008, 06:10 PM
glider pilot 1111
I purchased the fan and motor from www.hobbycity.com
It's under " Parts & accs. " then " props, EDF ". If your looking
for cheep packs to run it. I've bought a few large Zippy-R LiPo's
from hobby city and they are running really strong. The Zippy-H
has even more power.
I'm running mine on 12s, I think they recommend 10s. My competition
season is almost over, so I'm looking forward to getting back on this project.
Old 12-17-2008, 08:53 PM
glider pilot 1111
Default Bobcat flys !!!!
I started this project almost a year ago. Then life got in the way.The
Bobcat sat doing a fine job of collecting dust. Well, I finally got a
chance to finish it. Still has a few bugs, but here's the video of it's
first flight.
[media]http://www.youtube.com/watch?v=Smll-fmpQo4[/media]
Enjoy
Old 12-18-2008, 01:32 AM
Larry3215
Larry3215's Avatar
I did a dopplar of your one low pass and it reads around 89mph or so. Not bad for 1/2 throttle!
Congrats!!
Old 12-18-2008, 01:59 AM
wilmracer
Nice! Now get it dialed in and see what it can really do!!!
wilmracer is offline
Old 12-18-2008, 06:05 PM
Alpea42
Alpea42's Avatar
Congrats on the maiden. Mini Steve flew a Falcon 25 at 4lbs. 10 oz with a Turnigy SK series 40 sized motor on 4 cells. Can't believe yours flys that well at 10 lbs. It was Stryker kinda fast 70 mph ish. in a 1/10 mi. sq. field which was too small and he had to land at about 45 mph which ended up knocking the gear off . And he says it's fixed but he hasn't tried it again yet. The camera man only got the take off cuz he had to help with the torque rolling issue. I think this is the same plane , his is called a Falcon 25 so maybe it's smaller. Yeah I guess it is the little brother to yours. But here's the take off. http://www.vimeo.com/2190890
Alpea42 is offline
Old 01-26-2009, 10:07 PM
glider pilot 1111
Congrats!!
We were guessing around 80 to 90 mph. Now the big ???
How the heck did you figure the speed from the video.
Old 01-27-2009, 03:11 AM
Larry3215
Larry3215's Avatar
There are a couple of different free programs available that will let you capture the audio portion of the video.
You can calculate the speed based on the dopplar shift in the frequency of the sound coming from the fan unit or prop. The software does most of the work on that for you automatically.
Its pretty nifty actually
I use a free version of WaveoScope:
http://www.sprut.de/electronic/soft/scope.htm#download
There is also an english language version if I can find the link....
http://www.happykillmore.com/downloads/WOS.zip
The english link does not seem to be working at the moment - sorry!
Old 01-27-2009, 03:32 AM
rcshirt
I converted the falcon 120(big bobcat) to an byron fan setup. i have sence sold the nitro engine and researching to convert it to electric.
The plane are great flyers. so i didn't want to give it up.
i have video of the nitro setup.
another flyer at my feild is doing large EDF and i am watching closely
rcshirt is offline
Quick Reply: Bobcat ducted fan conversion
Page generated in 0.13864 seconds with 24 queries
