WattFlyer Scratchbuild Contest Number Two
Old 10-17-2008, 06:44 AM
  #101
The Don
Balsa Butcher
The Don's Avatar
Just foud this thread sounds interesting. I was going to start a scratch build model for indoor season. So I do have a quick question about using balsa in this contest. Do my wings and tail have to be all solid sheetwood? Or can I build up a wing with spars and cover it with an iron on material like solite? Don
The Don is offline
Old 10-17-2008, 07:05 AM
  #102
Larry3215
Look out for that tree!!!
Larry3215's Avatar
We'll have to see what the 'boss' has to say but I think that should be fine Don.
Balsa is listed as one material thats allowed and if you were doing an all balsa model it would have to be covered in an iron on material of some type.
You've got my vote for what thats worth
Larry3215 is offline
Old 10-17-2008, 07:10 AM
  #103
The Don
Balsa Butcher
The Don's Avatar
I am planing on making a sub one ounce model so solid sheet construction will not fly for me (no pun intended ). If no covering is allowed no big deal really. Just wanted to ask as I am going to build it anhyhow as the cold weather is coming and we have a gym to fly in Don
The Don is offline
Old 10-17-2008, 12:00 PM
  #104
smokejohnson
smokejohnson's Avatar
I sure hope it can be built up and covered, otherwise I'm in trouble .
Name:	DSCN2708 (Medium)_edited.JPG
smokejohnson is offline
Old 10-17-2008, 05:56 PM
  #105
pburt1975
Hotel California
pburt1975's Avatar
Default 2nd entry
http://www.wattflyer.com/forums/showthread.php?t=40199
something a little different...
James Bonds BD-5 from Octopassy! Now, it wont be an EDF (unless theres a soul out there willing to donate the proper gear for that, lol) but will have a 2408 in pusher configuration where the motor should be.
Last edited by pburt1975; 10-17-2008 at 05:57 PM. Reason: octo what??? insert a U for the A, lol
pburt1975 is offline
Old 10-17-2008, 06:28 PM
  #106
Rabbitcreekok
Rabbitcreekok's Avatar
Don, built up models from balsa and covered with whatever you choose are fine. They may or may not have foam involved, your choice.
Glad to have you in the contest. I look forward to seeing a small, indoor model, since I fly indoors a lot.
Just start a build thread, preferably using "Scratchbuild Contest # 2" in the thread title and post a link here in this thread.
Good building.
Rabbitcreekok is online now
Old 10-23-2008, 02:40 AM
  #107
pburt1975
Hotel California
pburt1975's Avatar
Yak 50
ID:	81536   Click image for larger version
Old 10-23-2008, 03:38 AM
  #108
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
Ill be building this one pretty soon.
Name:	Joining halves.jpg
ID:	81553   Click image for larger version
Name:	Skid-X Taadaa!!.jpg
ID:	81554   Click image for larger version
Name:	Skid-x painting.jpg
GreenAce92 is offline
Old 10-23-2008, 03:52 AM
  #109
Castor
Castor
Castor's Avatar
Default Blue Core Build Up
Thought i'd post some photos of my scratch built. Haven't had the guts to fly it yet. But soon. This is a blue core and balsa build up. The wing is a solid core. The Fuse is laminated blue core. And the hole thing is covered in econokote. You judge!
ID:	81558   Click image for larger version
ID:	81559   Click image for larger version
ID:	81560   Click image for larger version
Castor is offline
Old 10-23-2008, 03:54 AM
  #110
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
Thats nice! why do you build something you cant fly? comon i think you can do it. nice job! looks sleek!
Old 10-23-2008, 03:58 AM
  #111
pburt1975
Hotel California
pburt1975's Avatar
I like the bay doors, looks like a fast one!
That looks cool Ace. Maybe try using the Stuka wing as a reference for CG and angles?
Old 10-23-2008, 03:59 AM
  #112
Wrench66
Ya' need to use mo rudda!
Wrench66's Avatar
Hey now, that hasta be flown! Castor, I am diggin on the way the spinner, cowl and the front of the fuse all come as one angle.....much kudos there my friend
What was your inspiration for this build? Please post your build log photos
---Ray
Wrench66 is offline
Old 10-23-2008, 04:43 AM
  #113
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
thanks for the tips Pburt!
Old 10-23-2008, 08:27 PM
  #114
Crashalott
Crashalott's Avatar
Very nice there Castor, hope she flys good for ya.
Crashalott is offline
Old 10-24-2008, 06:16 AM
  #115
Castor
Castor
Castor's Avatar
Sorry Ray, No build photos. She was just an inspiration that came while i was standing at the work bench. I sketched out some templates and started building. I didn't record the process. I usually don't think to do it while i'm in the building mood. The only reason i haven't flown it yet is that i've had several crashes with planes that use more than 3 servos on the ESC equipped BEC. I'm pretty sure that the BEC is over heating and shutting down. Crashed my mini ultra Stick that way last friday. So i'm looking at UBEC units for my 3+ servo planes.
Castor is offline
Old 10-24-2008, 06:46 AM
  #116
Hi Castor Look at the turnigy 40 amp esc, they have a 3 amp bec, dont worry about the higher amp rating, as long as you prop the motor for its max amps, your ok using a larger amp esc, the turnigy esc have a 3 AMP BEC in the ESC up to 80 Amps, that will save you from having to buy a extra UBEC, hope that helps, Chellie
http://www.wattflyer.com/forums/showthread.php?t=39138
Old 10-24-2008, 09:34 PM
  #117
Wrench66
Wrench66's Avatar
Hi Castor,
I've only heard of this happening, the majority of my planes use 3-4 servos and I guess I've been lucky in that I've never given the BEC in my ESC's a second look. I do use the Turnigy ESC's 18a to 40's.....BUT for the most part I am cheap (hi Chellie ! hehe) and I have used the HC super simple's, TowerPro's and even the no name Suppo's.....never a problem.
Now I do use the small 9gr servo's (again from HC) so maybe they don't tax the system too much?
Good luck!
-Ray
Wrench66 is offline
Old 10-30-2008, 12:31 PM
  #118
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
http://www.wattflyer.com/forums/showthread.php?t=39425
Got this bird im workin on now EAS1(Experimental Aircraft Series 1) AKA Skid-x
it has forward swept wings and gulled wings also with a v-tail. a couple current build pics below:
ID:	82127   Click image for larger version
Old 10-30-2008, 12:50 PM
  #119
FlyingMonkey
Flite Test Fan
FlyingMonkey's Avatar
looks like you left the paper on...
FlyingMonkey is offline
Old 10-31-2008, 03:50 AM
  #120
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
Yeah i like the paper on its stronger
well here is the near completed bird, was going to add all the electronics on and what not but im not even going to be home tomorrow for a maiden so im like ahh what the heck.
heres the pics
as you can see this is not the best version nothign is really straight i just did it TLAR method ahh its not bad though gotta see if it flies
ID:	82161   Click image for larger version
ID:	82162   Click image for larger version
Old 10-31-2008, 05:03 AM
  #121
smokejohnson
But it's soooo heavy Looks cool though
Old 10-31-2008, 05:22 AM
  #122
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
hmmm its not too bad i guess, it is a pylon racer after all well kinda anyways
Old 10-31-2008, 06:35 AM
  #123
Rabbitcreekok
Ace, you need to start a build thread for the Skid-X. This contest thread is just for general information concerning the contest.
Old 10-31-2008, 06:50 AM
  #124
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
Well i already do well kinda, its for the first prototype when i build the second one(better planned i will start all over again(post 1)) and then ill post that link here and remove the GeeBee Corsair V-tail mixed plane thread
Old 11-02-2008, 01:31 AM
  #125
Thumbs up Scratch Built Katana Flys Grrrrrreat
Hi Everyone My Big Scratch built Profile Katana Flys Great, I had my Friend Steve fly it while I Video the flight, it has a 3536 1100kv Turnigy motor, 2350mah 3 cell lipo, 40 amp Esc, and a 10x4.7 prop, a 12x6 was to much prop for it, here is a video of the second flight, enjoy, Chellie
[media]http://www.youtube.com/watch?v=lTbir0Uc6Q8[/media]
Quick Reply: WattFlyer Scratchbuild Contest Number Two
Page generated in 0.16676 seconds with 26 queries
