Corona receiver problem
Old 09-12-2008, 06:27 PM
Stormovic
Default Corona receiver problem
Cannot get this 4 ch synthesized receiver to work with a Futaba 3 ch fm transmitter. Works fine with a futaba 6 ch.
Stormovic is offline
Old 09-12-2008, 07:36 PM
Bub Steve
Bub Steve's Avatar
StormovicSometimes you have to hold the "littleREDbutton" down a bit longer than two Sec's and keep the ant. down and not to close as they can be a might touch'ie about gett'in real close, your bub, steve
Name:	petty an red 390.jpg
Bub Steve is offline
Old 09-12-2008, 08:20 PM
Stormovic
Will try again and report.
Old 09-12-2008, 08:26 PM
Stormovic
Still will not bind to this 3 ch transmitter.
Old 09-12-2008, 10:27 PM
Rodneh
Are you sure that the 3ch is FM? If AM it won't bind.
Rodneh is offline
Old 09-13-2008, 12:49 AM
Stormovic
Radio is FM.
Old 09-13-2008, 01:10 AM
Originally Posted by Stormovic View Post
Radio is FM.
what radio are you using some radio are POS shift and some are NEG shift, if your receiver is NEG shift it wont work with a POS shift transmitter, hope that helps, Chellie
PS. Berg receivers are POS and NEG shift, AUTO SHIFT, they will work with any FM radio, and they are the best receiver on the market for FM, they will lock onto your transmitter, its almost like having a 2.4 and glitch FREE, I like the 4 channel 4L receiver.
http://b-p-p.com/home.php?cat=18
http://www.castlecreations.com/suppo...user_guide.pdf
Old 09-13-2008, 01:16 AM
http://www.wattflyer.com/forums/showthread.php?t=29202
some good information on pos and neg shift
Futaba & Hitec is a NEG shift transmitter
JR are a POS shift transmitters
Old 09-13-2008, 01:24 AM
Fly Time
Ask me how I know
Fly Time's Avatar
Do you know what the modulation type of your Tx is? If it is PCM (pulse code modulation), it will probably not work with the Corona. Most basic radios are PPM (pulse position modulation, commonly referered to as FM). AM is an obsolete modulation type for 72mHz, so unless it is very old it is probably not an AM radio. I think you already stated it was not.
Fly Time is offline
Old 09-13-2008, 01:45 AM
Bub Steve
Bub Steve's Avatar
Stormovic::The Corona 4 ch synthesized receiver is and auto-detect and will be ok for you neg shift, I'm gonna try one on my 3 ch hitech and see if she binds.also It will NOT work with an electronic control mixer, bub, steve PS I've got a mess of um but have been real lucky I guess
Old 09-13-2008, 03:22 AM
Bub Steve
Bub Steve's Avatar
Stormovic::my 3 ch hitech won't bind so far!! Darn!! bub, steve
Old 09-13-2008, 11:13 AM
it looks like the receiver does not like the Cheapy 3 channel radios, TAKE A BIG HAMMER and smash that corona receiver, and get a Berg receiver Ok Just kidding, Take care, Chellie
Old 09-13-2008, 12:18 PM
Stormovic
I think it's the three channel transmitter. I do have a few Berg receivers and they bind with no problems. No mention of this in the online instruction for the Corona.
Old 09-13-2008, 09:29 PM
I think that corona receiver may need to see 4+ channels to bind and work right, Oh well, that corona receiver just wont work with a 3 channel, I have gotten rid of all of my other receivers, and just use the Bergs, I have had a lot of problems with glitching, and have lost a plane due to receiver problems, after using the berg receivers, no more problems, they are almost like having a 2.4 radio, as the receiver will bond with the transmitter, I am very happy with my Berg receivers, I am starting to use 2.4 now, I have a DX6i radio, but it will be a while before I have my planes on 2.4, as the receivers are expensive, but for now, the JR Transmitter and a Berg receiver, have been a very very solid combination, Take care, Chellie
Old 09-13-2008, 11:33 PM
Stormovic
Agree. Corona should mention this in their instructions though. I also have a few Bergs and they work fine. I'm sticking with 72 mhz.
Old 01-08-2009, 07:34 PM
dnkehl
Can someone please tell me what to plug into what plug 1 thru 6 on my rp6s1 synthesized receiver. I did read that different receivers use different numbers for different things. For instance some might use plug 1 for throttle and another might use plug 1 for batt/acc. I have done a couple of searches and can't find what I'm looking for. Hope I am explaining this correctly.
Thanks,
dnkehl is offline
Old 01-08-2009, 08:30 PM
VamPower
Urban R/C
VamPower's Avatar
Is someone here sponsored by Castle?
The Corona receiver is also AUTO SHIFT, but the synthesized version of their receiver will not work with a 3ch Hitec radio. Our receivers use the same technology, but our web site does state you must use a 4 or more channel radio.
http://www.vampowerpro.com/store/Receivers.htm
VamPower is offline
Old 01-08-2009, 08:32 PM
VamPower
Urban R/C
VamPower's Avatar
Hi,
Thank you for purchasing our 6 channel synthesized receiver.
The Channel selection is controlled by the transmitter, not the receiver. If Ch. 1 is your ailerons with your futaba receiver, it will also be on our rp6s1 receiver.
VamPower is offline
Old 01-08-2009, 09:12 PM
dnkehl
Thanks,
Why didn't I think of that? Must have been too easy.
dnkehl is offline
Doc Pete
18
08-20-2009 08:35 PM
gsmena
California
03-25-2008 06:17 AM
RCairplane.pilot
12-15-2007 02:00 PM
maguro
09-04-2007 08:59 PM
alpenaflyer
10
03-03-2007 07:46 AM
Quick Reply: Corona receiver problem
Page generated in 0.12597 seconds with 14 queries
