Maiden of the Rambler - Gas-to-Electric Conversion
Old 09-23-2008, 07:15 AM
gzsfrk
gzsfrk's Avatar
Default Maiden of the Rambler - Gas-to-Electric Conversion
Well, I finally got my chance to maiden the Rambler gas-electric conversion that I've been working on for a while, and MAN what an awesome flying bird it turned out to be. And by FAR my favorite part about this plane is the way it sounds in flight--AWESOME.
Here's the video of the initial flight. I apologize for the fixed camera angle, but I didn't want my wife and little girl to be out in the field with me, just in case something went wrong while flying the plane. (Plus, it also worked out good for getting some good speed runs to doppler):
[media]http://www.vimeo.com/1791692[/media]
Here's the configuration I went with, and my costs:
  • I bought the Rambler used off craigslist for $50 with all servos, a receiver battery pack, and a Hi-tec dual-conversion receiver.
  • I wanted to fly with a 6S lipo pack, so I assembled a 6S 4400mah pack using 4 ABF 20C 2200mah 3S lipo packs from HobbyCity for $20 each.
  • For the motor, I went with a Turnigy 50-55 600kv from HobbyCity for $43
  • I picked up a Flying 70A ESC from DealExtreme.com for $24 shipped. (That ESC doesn't have a built-in BEC, but since the plane came with a receiver pack, it wasn't an issue.)
And that was it--for about $200, I have an absolutely fantastic flying plane. Now, so long as I don't get cocky and crater it before I get my money's worth out of her, I'll be one happy camper.
gzsfrk is offline
Old 09-23-2008, 08:39 AM
Hi, Nice plane, try a 12x9 APC prop on it cut down to a 11x9 or 10.5 X 9 and go for the 125MPH Award , Just My 2 cents worth, Take Care, Chellie
Old 09-23-2008, 08:43 AM
gzsfrk
gzsfrk's Avatar
Thanks, CHELLIE! I actually have a 12x9 APC that I ordered with this motor. But the shaft hole in the APC prop is too small for me to even get the smallest part of my prop reamer started into so that I can make it big enough to fit on the 50-55's shaft. I guess I need to find a smaller reamer and start with that one.
Once I do, I'll probably try out your suggestion about cutting it down and seeing if I can get a bit more speed out of her and earn another badge.
gzsfrk is offline
Old 09-23-2008, 09:48 AM
your hobby shop should have a prop reamer, if not, order one on line, Take care, Chellie
Also, I use a little thin CA, and kicker to glue the adapter in the prop, before reaming it, so it does not spin on me. also, make your own CA kicker, 1 tablespoon Baking soda to 1 ounce of water, shake well, and spray on, works great and no fumes, try it.
http://www.hobbypeople.net/gallery/237950.asp
Old 09-23-2008, 03:47 PM
gzsfrk
gzsfrk's Avatar
Yeah, I have a larger reamer already (5mm to 10mm), but I need to pick up a smaller one to auger out my props with smaller diameter shaft holes.
My goodness, you're just brimming over with helpful information, aren't you? I had no idea you could make kicker that way. So you just mix it up then place the concotion into an atomizing sprayer and then apply to your CA?
gzsfrk is offline
Old 09-24-2008, 05:18 AM
Hi Gzsfrk Yes just put it in a small spray bottle, shake the bottle before using, it works great, I learned here on Wattflyers that water acts as a kicker, and so does baking soda, Soooo I mixed them both together, sprayed it on some CA, and it works just as good if not better than the store bought stuff, and No fumes, pass on the info, Take care, Chellie
Old 09-24-2008, 12:51 PM
Slowjohn
Passed on
Slowjohn's Avatar
Lightbulb Photos Please
Howdy gzsfrk,
How about some photos of your conversion please. That Vemeo player thing & my old computer running windoze 98 just doesn't do it. The video & sound skips so bad that I've got to where I don't even attempt to watch anything on Vemeo anymore. One of these days I'll break down and get a newer computer as this one has done it's job of teaching us how to use one. Didn't want to spend a bundle right off the git go only to determine I couldn't operate one so we bought a older refurbished Dell almost 5 yrs. ago and it's still going as you can see
The homemade kicker like the wonderful, informative, talented Chellie is telling you about works great, just be sure to wipe up the over spray especially on covered & painted areas or you'll get a white residue that can be tough to remove.
Standing By,
SJ
Slowjohn is offline
Old 09-24-2008, 04:53 PM
gzsfrk
gzsfrk's Avatar
Sure!
Here's some pictures of the plane as I first bought it, sans gas motor:
ID:	79083Click image for larger version
ID:	79084Click image for larger version
And here's a picture inside the nose after I installed the Turnigy 50-55 600 motor:
Here's a couple pictures of the Rambler ready to hit the skies:
ID:	79086Click image for larger version
And finally, here's an in-flight shot my lovely wife took for me:
Hope that covers it.
gzsfrk is offline
Old 09-24-2008, 07:59 PM
Slowjohn
Passed on
Slowjohn's Avatar
Thanks gzsfrk,
Those photos covered it real nice.
Nice conversion too. Hope you enjoy it for a long time.
Standing By,
SJ
Slowjohn is offline
pezzer2003
10
10-17-2007 12:13 PM
Ralph V
07-26-2007 11:36 PM
LeeU
3D Flying
03-25-2007 06:23 PM
hookedonflyin
18
03-07-2007 10:19 AM
admin
25
10-24-2005 01:08 AM
Quick Reply: Maiden of the Rambler - Gas-to-Electric Conversion
Page generated in 0.10838 seconds with 14 queries
