Guillows SE5 conversion
Old 10-14-2008, 04:22 AM
dbcisco
Like to build 'em
dbcisco's Avatar
Default Guillows SE5 conversion
I am putting together a vintage (die crushed parts) Guillow's SE5. Besides the vague and scrambled instructions/plans, I want to convert it to electric powered RC (no ailerons though). Anyone been there-done that. Help and tips needed. I have their DR1, Camel and Bristol still in boxes. I thought I would start with this one first because I have built a rubber powers "easy-built" SE before. The Easy-built crumpled when I tried to coverite it, the guillow's at least will handle the coverite, not sure about the conversion. I was planning on using a GWS 400 w/gearbox and electronics in the Guillows.
I will take pics as I go along, maybe others can learn from my mistakes, this is a definite R&D project.
dbcisco is offline
Old 10-14-2008, 04:28 AM
Biplane Murphy
2 Wings, Twice The Fun
Biplane Murphy's Avatar
Hi dbcisco,
Look here for a build on a similar plane going on right now (Camel).....
http://www.wattflyer.com/forums/showthread.php?t=39480
Bill does a lot of this type of building, so I am sure he could help out with a few pointers.
He has an SE5a and a DR1 conversions flying right now too.
Good luck with your project,
Murph.
Biplane Murphy is offline
Old 10-14-2008, 06:05 AM
Bill G
Super Contrubutor
Bill G's Avatar
I did one on RCGoofs starting at post #44.
http://www.rcgroups.com/forums/showt...highlight=se5a
Nice little flyer. Been flying it and the DR1 a good bit lately.
Bill G is offline
Old 10-14-2008, 06:34 AM
barmonkey
barmonkey's Avatar
Good to see yet another build thread here! Bring those pics...your post and pics will not only help others, but will help you help yourself!
BTW...a GWS 400 w/gearox? That would be way too heavy and large.....
barmonkey is offline
Old 10-14-2008, 07:29 AM
dbcisco
Like to build 'em
dbcisco's Avatar
I was going to use an IPS but all I have is EPS's. I thought that the set up from my Wattage Camel and J-3 (EPSes) would work since this will be a bit heavier than my PicoMoth (IPS driven). I don't want to go brushless, I have to many brushed motors and ESC laying around looking for homes
I have the EPS set in and it fits nicely in the nose. I read that getting weight in the nose of the balsa models is difficult and that some people had to put lead weight in the nose. I would rather have something more useful than lead. It is easier to keep throttle low than to be underpowered too. (I think)
dbcisco is offline
Old 10-14-2008, 02:31 PM
degreen60
Flying Fish
degreen60's Avatar
What is the wing span on the SE5A? I have a Sterling SE5A I built years ago and never flew. I been thinking about trying to put brushless and RC into it. It has a 24 inch span.
degreen60 is offline
Old 10-14-2008, 02:41 PM
dbcisco
Like to build 'em
dbcisco's Avatar
The wingspan is 24" on the Guillows SE5
dbcisco is offline
Old 10-14-2008, 04:29 PM
degreen60
Flying Fish
degreen60's Avatar
I am planning on using a small brushless motor. I have a couple of tape drive motors that I am going to rewind but not change the magnets. I will try 6 to 8 inch props. I am flying an Eflight Jenny on a 7 inch prop brushless using 2s lipo so I think the SE5a should do ok on about the same setup. The SE5a I don't think will have a tail heavy problem cause it does not have the short nose like the Camel. I will be using pull-pull for controls to save tail weight.
Old 10-14-2008, 05:22 PM
7car7
7car7's Avatar
I might sugguest the GWS 350, instead of the 400. That is what I use in my Tiger Moths, and I've been real happy. Certainly heavier than the IPS, but much more powerful.
I've seen others call it a 300, so I'm not really sure what the real name is.
7car7 is offline
Old 10-14-2008, 09:05 PM
degreen60
Flying Fish
degreen60's Avatar
Here is another thread on this plane. http://www.wattflyer.com/forums/show...t=19016&page=3
Old 10-16-2008, 03:42 AM
dbcisco
Like to build 'em
dbcisco's Avatar
The motor in mine is a 370. I am thinking of putting in a 180 though.
The nomenclature for motors about drives me crazy. Just got the Heli motor nonsense down and now airplanes are driving me crazy
dbcisco is offline
Old 10-16-2008, 05:24 AM
Bill G
Super Contrubutor
Bill G's Avatar
If you use any of those motors, you probably will not do well unless they are geared. The small props that they use DD are not well suited to these planes. I have flown planes as large as a GP Hellcat with a geared 180, although not extremely powerful. I had done conversions with the brushed motors in the past, and had some success. My Guillows Spitfire flys well on a geared GWS350. Still, at this point I've been convinced to go with smaller outrunners or geared 12mm bl motors, due to space constraints and ease of mounting. Fitting a strong stick mount in these planes is a lot more work than simply gluing on a thin ply firewall for an outrunner mount.
The other problem is that some of the brushed setups I have in higher wing load conversions are pushed so hard to get the power out of them, that they are generally unreliable.
Bill G is offline
Old 10-16-2008, 05:56 AM
dbcisco
Like to build 'em
dbcisco's Avatar
I guess the gearbox (approx. 6:1) with a 180 is more likely to die than the 370. I would to love to throw away all my brushed motors and ESC's and put in brushless. Sadly, I have a box full of brushed motors and ESC's and little in my wallet
I am not really worried about over all weight, what I am worried about is getting the CG right. The gearbox and motor are 1.5 oz. Quite a bit in the nose when I only have electronics and a battery to offset it in the body.
Maybe putting the battery as far in the tail as far as I can.
dbcisco is offline
Old 10-16-2008, 07:15 PM
degreen60
Flying Fish
degreen60's Avatar
Here is a lot of links to Guillows R/C builds. http://www.rcgroups.com/forums/showt...61#post9275360
Old 10-17-2008, 02:00 AM
Bill G
Super Contrubutor
Bill G's Avatar
I have a bag of brushed ESCs and motors too. Know the feeling.
Those little 180 motors have proven quite tough for me. I had one bashed onto a GWS IPS-A gearbox, and ran it on 3s for many flights in a GP Hellcat with both 2 and 3 blade 9x7 props. I thought it would burn up immediatley. I still have the 180 geared setup in working order after maybe 30 good flights, although I put a bl motor in the Hellcat.
The 370 is simply more weight than you need to set CG, making the plane heavier. The beauty of the SE5A is that it has a long nose, allowing it to balance with less nose weight than other WWI bipes.
If you used a 370 motor, the batt would probably only need to be moved back to under the wing, but I would try to do anything to talk you out of that, and use a 180, if you go brushed. IPS is questionable for power, unless you build really light, which is tough to do with Guillows. I stole a 5866kv Feigao bl IPS size motor from my Guillows DR1 for a micro jet, and it would not fly on a brushed IPS. It now has a 4100kv Feigao IPS which flys fine. The 5866kv was ballistic in it.
The IPS brushed dual is a good underutilzed setup. I had one in a Guillows Zero with A gearing and 9070 3-blader on 3s. Flew with power. Eventually burned a motor, but would have done fine if propped down to 8". I've since replaced the bad motor to use it again someday, as the Zero now has a bl setup.
Bill G is offline
Old 10-21-2008, 02:46 PM
dbcisco
Like to build 'em
dbcisco's Avatar
I put a 180 motor in the gearbox and used some RTV to get better support and vibration damping. The gearbox is epoxied in with a couplke degrees down and right offset.
dbcisco is offline
Old 10-21-2008, 06:05 PM
Bill G
Super Contrubutor
Bill G's Avatar
180 should do the job. I ended up putting a bit of lead to add noseweight to my SE5A with short can 12mm Feigao, so the 180 should be ample weight, without being too much noseweight. Just some thoughts on the batt/gear access which worked well:
ID:	81228   Click image for larger version
ID:	81229   Click image for larger version
Bill G is offline
Old 10-25-2008, 05:56 AM
dbcisco
Like to build 'em
dbcisco's Avatar
Well, I have the servos in and am starting to cover up the fuselage. I am using some fine sheet balsa on the places where the original used wood or metal. I was thinking of using silk for the rest of the fuselage. I will use coverlite on the wings though. I am also considering using depron for the tail feathers because I just need some foam for my psyche. The foam could be easily replaced in the future if I want. After looking at some restored S.E.5's I think it will look pretty close to the original.
I also am simply making cotton padded compartments under the wing opening for the RX, ESC and battery.
dbcisco is offline
Old 10-25-2008, 06:01 AM
Bill G
Super Contrubutor
Bill G's Avatar
You could also put a steerable tailwheel in, as some restored SE5As have. I incorporated mine in with the tailskid with a tiny 3/8" plastic Dubro tailwheel, which is hardly noticable. The taiskid has thin brass tubing inside it, with a steering arm that goes into the rudder. The steerable tailwheel has worked well for ROG takeoff.
Bill G is offline
Old 10-25-2008, 06:38 AM
dbcisco
Like to build 'em
dbcisco's Avatar
Do you know what the Dubro part number is, or a picture? If you have ever been to my LHS you would know why I ask
dbcisco is offline
Old 10-25-2008, 07:06 AM
Bill G
Super Contrubutor
Bill G's Avatar
Here's a picture of what they are, although I get them from my LHS:
http://www.rcdude.com/servlet/the-69...ro-Tail/Detail
They have 3/8" and 1/2" sizes available in small plastic tailwheels
Bill G is offline
Old 11-01-2008, 07:03 AM
reuben199
reuben199's Avatar
Hey,
Well, I've decided to bite the bullet and build a 3 channel S.E.5.a. rudder/elevator, its an old die-cut kit 24" wing span and I was a bit concerned with the quality but maybe the die's were sharp that day the wood quality appears ok aswell.
I'm planning on using a waypoint W-E2205-36 motor 28 grams 1770kv, waypoint W-EBLESC-15 esc 17grams, APC SF 6x4 prop, 3s 800mah lipo's, spektrum AR6100e receiver, 2x micro servo's.
My main concerns are -covering it?
-Dihedral? scale or the 1" recommended for flight?
-Tail surfaces... as per plan or flat sheet?
Any tips would be great.
Thanks Reuben
reuben199 is offline
Old 11-01-2008, 07:27 AM
Bill G
Super Contrubutor
Bill G's Avatar
Originally Posted by reuben199 View Post
Hey,
Thanks Reuben
Somebody's online at this time of night.
I built tail per plan, but I tend to like strong heavy stringer wood, which weighs more than some think. The Guillows perimeter frame wood is often heavy, in addition to being fairly thick, at over 1/16". They seem to use some off size that's a bit over standard 1/16" sheet for those parts. If you can find some really light 1/32" sheet balsa, you can cover with Coverlite or tissue and end up at the same weight.
I gave mine (just walked out to the living room to check it out where it's hanging) a good 1" of dihedral for rud/elev flying. From flight, I would say it could be reduced a bit and still have good stability. If anything, mine may have a bit much, as the dihedral helps induce roll from the rudder yaw, which makes it "swing" a bit excessively on turns.
Weight wise, if you can get everything up front, the slightly heavier ESC and motor will be fine. I used a geared 12mm Feigao, but progressively added lead to enhance stability. I probably have a total of roughly 1-1/2 ounces, between motor/gearbox/lead weight up front. Maybe more. I can get you a CG measurement also when needed.
Battery wise, I cannot fit larger than a TP 3s-730 in the compartment, as I have it. You could go a bit taller, but would have to trim the top fuse keel down, and laminate the sides of that area with stringers to replace strength lost, if I remember the area correctly. As I have the batt mounted, it does not require any rework of the airframe for it's compartment space.
Bill G is offline
Old 11-01-2008, 07:49 AM
reuben199
reuben199's Avatar
Hey Bill,
Its 6pm on this side of the world
I've just started the fuselarge, I'm thinking I will build the one side then make a servo tray and work out a battery compartment before I add the othersides formers. I think I will build the wing and add the 1" dihedral they recommend. -Reuben
Old 11-03-2008, 09:45 AM
reuben199
reuben199's Avatar
Hi,
So far I have built the left side fuse and the lower wing (dihedral yet to be added).
I'm looking for tips regarding placement of my gear, I'm thinking either to stand the battery vertically in the compartment in front of the wing.... or lay it flat infront of the wing with the esc mounted above it? and have a full length tray that the servo's will be mounted in to, for servo placement I'm thinking above the lower wing with an access panel in the lower wing, however I have seen some with the servo's in the cockpit area? this is where I would like to put the receiver as it will be easier to see its light (its a spektrum ar6100e) also are light pushrods ok or do I attempt a pull/pull system?
Any pointers and photo's would be greatly appreciated
-Thanks Reuben
ID:	82514   Click image for larger version
Quick Reply: Guillows SE5 conversion
Page generated in 0.13084 seconds with 18 queries
