Anderson Power Poles
Old 01-17-2009, 11:23 AM
slipstick
Originally Posted by Cyclops View Post
I changed to them (Fastons) as they come in several sizes and crimp very well with anything. They are color coded. Have complete Nylon anti-shorting hoods on male & females. Dirt cheap @ H D or Lowes. They are the ones used in all appliances for many years.
Yes that's right, they're made for appliances and the like...where they're plugged together once when the unit is built and unplugged 5 years later when a component needs replacing. They are not intended for our sort of use with frequent connection/disconnection.
But good luck with them, hope they work well for you.
slipstick is offline
Old 01-18-2009, 03:26 AM
flybyrc
flybyrc's Avatar
Originally Posted by Rabbitcreekok View Post
I use them and am really pleased. You can buy the crimping tool from West Mountain Radio, as well as the connectors.
The crimping tool from Anderson is very expensive, but is industrial strength for hundreds of thousands of uses. The West Mountain tool will be fine.
Here is a cheaper crimper tool from the site:
http://www.powerwerx.com/product.asp?ProdID=3324&CtgID=
flybyrc is offline
Old 01-18-2009, 03:45 AM
Misread......
Old 01-18-2009, 03:51 AM
crosborne
Chairman of the BORED
crosborne's Avatar
He was talking about the Fastons.
crosborne is offline
Old 01-18-2009, 03:54 AM
crosborne
crosborne's Avatar
That is the tool he was talking about and it is the one that is pictured above. The price dropped $10. When Liquidity bought his it was $49.99. What ever you do, do not by the cheap $12 pliar type crimper. I did and I then bought the more expensive ratcheting crimper.
Old 02-01-2009, 08:28 PM
whitehawk
What does this button do?
whitehawk's Avatar
Hi guys. I also made the switch to PP. Love them! Got the contacts and crimper from Powerwerx. Question: Do any of you use the double prong thingy that I believe is intended to go between two sets of PP, to keep the connection from separating? For anyone not using this thing, have you ever had two sets of PP separate?
Thanks,
Tim
whitehawk is offline
Old 02-01-2009, 09:18 PM
simibill
General Factotum
simibill's Avatar
Thanks,
Tim
No, I don't use them and I have never had two sets separate. I do use the roll pin to maintain alignment of pairs.
simibill is offline
Old 02-01-2009, 09:33 PM
crosborne
crosborne's Avatar
I do not use the roll pin or the prong thing. I have never had the halves slide apart and, in fact, mine are very difficult to slide apart.
Old 02-01-2009, 10:55 PM
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
I used to tape mine for added security, but I guess that was overkill.
Frank
Murocflyer is offline
Old 02-02-2009, 01:38 AM
Liquidity
Combat Vet
Liquidity's Avatar
I dont use either the pin or the locking mechanism. Mine have been fine so far.
Liquidity is offline
Old 02-02-2009, 06:36 AM
BradT
Scale Nut Loves Biplanes!
BradT's Avatar
I've used the PPs since I got into RC in '97, and never had a failure of any sort. I don't use roll pin or locker, and the only seperations I ever had were the result of high impact arrivals (also known as crashes!), where seperation of pack and esc is a GOOD thing, not a problem.
BradT is offline
Old 02-04-2009, 08:50 PM
Balsa Wood
Ochroma pyramidale
Balsa Wood's Avatar
I've been using them for 4 years, after getting rid of all my deans.
I use this crimper, it's a beaut.
http://www.powerwerx.com/product.asp...324&CtgID=3575
ID:	92585   Click image for larger version
Balsa Wood is offline
Old 02-09-2009, 01:37 AM
  #63
whitehawk
whitehawk's Avatar
This is probably in the wrong thread, but anyway...
I bought some general purpose 14 ga. copper stranded wire to use with the AA's. Do you guys think this is okay to use, or is there a better type of wire for general r/c stuff, like charging leads, battery extensions etc.
Tim
Old 02-09-2009, 01:53 AM
  #64
slipstick
Well that sort of depends on what "the AA's" means to you.
Old 02-09-2009, 02:25 AM
  #65
Keith wilson
AMA 6418 New Stanton, Pa.
Care to explane what you ment by that?
...Keith...
Keith wilson is offline
Old 02-09-2009, 03:32 AM
  #66
Larry3215
Look out for that tree!!!
Larry3215's Avatar
I dont know what an 'AA' is either other than a small battery for the remote control for my TV
Still, normal stranded wire - like you get at HomeDepot or RadioShack - isnt the best choice for RC use. It will not hold up well under constant flexing and vibration over time. It has a relatively low strand count and is probably PVC insulated or similar. It will be relatively stiff compared to our stuff.
It will crimp into the appropriately sized Anderson Power pole just fine however if thats what you are asking.
You are much better off using hi-strand count, silicone insulated wire. It is more expensive, but its what works best by far.
You can order it from many sources on-line. I havent found any local non-RC suppliers that carry it in stock in my area but you may have better luck if you live in a large metropolitin area.
Larry3215 is offline
Old 02-09-2009, 04:08 AM
  #67
whitehawk
whitehawk's Avatar
Oops, meant the AP's (powerpoles).
Sorry,
Tim
Old 02-09-2009, 04:14 AM
  #68
crosborne
crosborne's Avatar
Stranded wire is want you want to use, do not use solid copper wire. Larry is correct about using a high strand count wire. PVC coated is good to use as well. It not as flexible as silicon coated wire but it is more nick/cut resistant.
Old 02-09-2009, 04:34 AM
  #69
whitehawk
whitehawk's Avatar
Regarding the high strand count wire, should the packaging say "high strand count" or something to that effect? The wire that I picked up just says copper stranded. Appearance wise, this new wire looks copper in color. I say that because all the r/c wiring that I've seen to date looks silver in color.
Old 02-09-2009, 04:50 AM
  #70
Liquidity
Combat Vet
Liquidity's Avatar
Si
Old 02-09-2009, 05:48 AM
  #71
Larry3215
Larry3215's Avatar
The silvery color means its pre-tinned which is a good thing. The untinned wire is ok but it is far more subject to black wire rot and corrosion in general. Pre tinned is much better as far as corrosion and is of course much easier to solder.
If it just says "stranded" its probably not hi-strand count.
I dont know the exact numbers but regular stranded wire may have say 5 to 10 strands of wire. It may or may not be pre-tinned.
Hi-strand wire will have more like 75 to 200 strands. They are very very thin hair like strands and lots and lots of them.
Deans "Noodle wire" is one brand but you can et the same stuff from most of the US battery sellers or Tower or Aircraft world. Most any place that sells battery making supplies will sell the wire as well.
Old 02-09-2009, 02:23 PM
  #72
whitehawk
whitehawk's Avatar
Thanks, Larry. That was the explanation I was looking for.
Tim
Old 05-09-2009, 02:44 AM
  #73
ministeve2003
Class Clown
ministeve2003's Avatar
Hi Folks.... I've been using Powerpoles on quite a few models... However, I've also been using deans on certain stuff that I deemed that I needed "extra security" (Harder to pull apart) unfortunately, My bad soldering on deans melted the housing inside... everything appeared to be ok, but after a couple flights... I lost a plane due to battery disconnect (it never came out of the houseing).... two battery's that I soldered at the same time have the same problem....
So no... Like I've been telling myself ... I'm going to switch "ALL" my planes over to Power poles... I've tested them thoroughly enough to know they won't disconnect inflight.... which is basically the only problem That I was worried about...
I only have one question.... anyone use them in a heli?
SK
ministeve2003 is offline
Old 05-09-2009, 03:04 AM
  #74
simibill
General Factotum
simibill's Avatar
If you still have worries about them disconnecting, there is a small plastic piece with two pins which engage the paired connectors thus assuring they cannot come apart by themselves.
simibill is offline
Old 05-09-2009, 03:05 AM
  #75
SK yes many use them in helis.
Your battery MUST be fully secured. If you are relying on a connector to secure your battery - you will have bigger issues than soldering!
I have used Anderson/Sermos connectors for about 6 years now - never had a single one disconnect.
Quick Reply: Anderson Power Poles
Page generated in 0.11863 seconds with 13 queries
