Good Economy setup for EasyStar & Minimag
Old 11-15-2008, 01:06 AM
userrc
Default Good Economy setup for EasyStar & Minimag
Hello,
I'm looking for good economy setup which can be used for BOTH Multiplex EasyStar and Minimag.
(MiniMag/Easy Star Power Pack works with both but is more expensive and has only 17A ESC)
I'm looking for good inexpensive BL motor, ESC, sevos which can be used with both EasyStar & Minimag with minimum modifications. (MiniMag/Easy Star Power Pack is more expensive and has only 17A ESC)
BL motor & ESC should be in a range with surplus power & rating & allow different propellors.
Is "HXT 2835 (380S) 2200kv Brushless Inrunner" as good as "Himax 2815-2000 Brushless Motor" ? Is it suitable for both EasyStar & Minimag and can fit either without any mounting modifications ?
(Himax 2815-2000 weighs lesser & has more power, but cost 3 times more)
Better than "Suppo 2212/6 with a Suppo 30A ESC" ?
Which inexpensive Brushless Outrunner is recommended for MiniMag & EasyStar ?
How much mod will be required ?
Which servos can be used for both EasyStar & Minimag ?
I read "HXT900 9g/1.6kg/.12sec Micro Servo" and "HXT500 5g/.8kg/10sec Micro Servo" from Hobby City are as good as Hitec HS-55 ?
RTF versions of EasyStar & Minimag include Tiny S servo.
Which one should I buy to use on both EasyStar and Minimag ?
Is "TURNIGY Plush 25amp Speed Controller" OK for both EasyStar & Minimag ?
Better than "Suppo 2212/6 with a Suppo 50A ESC" or "Hextronic 36Amp ESC" ?
Better Choice ?
Thank You.
userrc is offline
Old 11-18-2008, 03:23 PM
userrc
I plan to use 3S 2200mAh Lipo only.
Is this the prop which comes with MiniMag/Easy Star Power Pack: APC 5.5 x 4.5 Speed 400 Electric Propeller - LP05545
Is it the best choice for HXT 2835 (380S) 2200kv Inrunner + TURNIGY Plush 25amp ESC combo ?
Or should I use any other prop like APC 6x4 or APC 6x5 ?
For build, can I use Loctite Super Glue OR Loctite Super Glue Gel ?
userrc is offline
Old 11-18-2008, 06:03 PM
Leadchucker
Curmudgeon
Leadchucker's Avatar
Check out Heads Up R/C's lineup of motors and ESC's. I use them exclusively in all my planes and they have been nothing but good stuff. Jeff runs a top shelf operation and ships both fast and cheap.
Link:http://www.headsuprc.com/servlet/StoreFront
Leadchucker is offline
Flyer 1
Aerial Photography
33
10-05-2008 09:34 PM
celticflyer
Foamies
10-04-2008 03:30 PM
CaptinApple
9
06-09-2008 06:17 PM
Crash N Burn
12-06-2006 11:42 PM
Quick Reply: Good Economy setup for EasyStar & Minimag
Page generated in 0.07309 seconds with 14 queries
