PBY Conversion to electric
Old 12-11-2008, 08:36 PM
donjiskra
WAA-08 Pilot
donjiskra's Avatar
Default PBY Conversion to electric
Now that winter is here I'm back at work on this conversion.
The previous owner had two .40 size glow engines and said it was too fast, and was going to give it away. I offered to take it as an electric conversion project.
Progress has been fun, with lot's of research as to what motors to use.
Settled on two .35 size, Turnigy 42-40A, 1050KV and two Hextronik 80A ESC's, each powered by an HXT 4s 2100mah lipo.
Finally have both motors installed and wired. Each motor has its own ESC and are "Y" connected to the receiver throttle channel. Each motor has its own battery. The BEC has been disconnected and the receiver is powered by a seperate battery.
I checked one motor with the Wattmeter and discovered that with the Master Screw 9x7 3 blade prop, and a 4s2100mah fully charged, it drew 25 amps and produced 325 watts at full throttle.
ID:	86488   Click image for larger version
donjiskra is offline
Old 12-12-2008, 08:49 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
Cool project! Whats your projected all up weight going to be?
Larry3215 is offline
Old 12-12-2008, 02:00 PM
donjiskra
WAA-08 Pilot
donjiskra's Avatar
Proposed weight right now around 7 pounds.
Here's the E-calc specs using a TP2100 4s li-po since I don;t have the HXT battery data. My Wattmeter test indicated 325 watts at 25 amps with a freshly charged battery. I've never done a conversion & this has been.
Thanks for asking,
Don
Name:	RAYS PBY 1 MOTOR ECALC.jpg
Old 12-12-2008, 06:51 PM
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
A Turnigy 3542 1250 with a 7" prop on 4 cells flys my 3lb. parkjet almost verticle. So those motors should really power that thing.
Alpea42 is offline
Old 12-13-2008, 02:05 AM
Larry3215
Larry3215's Avatar
That should be plenty of power for a 7 pound scale model. That works out to 92 watts per pound.
You wont be doing any 3D but thats ok
Old 12-13-2008, 06:12 AM
Bill G
Super Contrubutor
Bill G's Avatar
Nice PBY Donjiskra. Maybe if you get it flying it will motivate me. I converted a Guillows PBY some years back with DD brushed 400 motors and small 3 blade props. I'm a bit leery about the power system, and have thought about a bl conversion, but should at least give it a try as is.
I wish they had reasonably priced decent bl stuff like the Turnigy gear you're using, back when I setup mine.
Bill G is offline
Old 12-13-2008, 01:42 PM
donjiskra
WAA-08 Pilot
donjiskra's Avatar
Bill,
Thanks!
I too started with DD brushed motors, but now it's a lot different.
Cheap BL motors up the wazoo and lipo batteries are much lighter.
I bet you wouldn't have any problem nowadays making your PBY airworthy.
Good luck,
Don
Old 05-23-2009, 01:32 AM
donjiskra
WAA-08 Pilot
donjiskra's Avatar
Default Here's the maiden flight video
[media]http://www.youtube.com/watch?v=iJoDibl7Y0w[/media]
donjiskra
Seaplanes E-Powered
07-15-2008 03:57 PM
donjiskra
07-13-2008 10:10 PM
s-10promod
14
06-16-2007 11:30 PM
RSS Feed
RCU RSS Feed
10-03-2006 11:10 AM
BeaverBob
07-21-2006 03:45 PM
Quick Reply: PBY Conversion to electric
Page generated in 0.10532 seconds with 18 queries
