Newbie question: How to set up multi-engine electrical system?
Old 12-18-2008, 06:22 PM
RedBhudda
RedBhudda's Avatar
Default Newbie question: How to set up multi-engine electrical system?
Hi, I've been thinking of scratchbuilding a small twin-engine electric plane (maybe a mini-B25 or something) and I was wondering how to set up a multi-engine electrical system...i.e., can I just splice together the radio leads on 2 ESCs and have the plane run on a single throttle, or do I need an additional "black box" between my radio and my ESCs, etc? Any help is greatly appreciated.
Also, since I'll be 2x the power with 2 motors, is it possible to connect 2 LiPo packs in parallel? This should give me the same voltage as one pack, but with 2x the amp-hours, right?
RedBhudda is offline
Old 12-18-2008, 09:26 PM
Dr Kiwi
http://www.westbourne-models.com/ima...Esc-nicad.html
This diagram is for brushed motors but the principle is the same.
For parallel Lipo packs (same voltage, twice the capacity) you can get a Deans plug Y set-up from BP Hobbies or some other store. http://www.bphobbies.com/view.asp?id...1&pid=B1858542
Name:	Twin motor Wiring diagram.jpg
Dr Kiwi is offline
Old 12-18-2008, 10:12 PM
RedBhudda
RedBhudda's Avatar
Thanks! This is very clear now, and just as simple as I hoped for.
Old 05-11-2009, 09:01 PM
hproy
does it matter which motor is counterclockwise?
hproy is offline
Old 05-11-2009, 09:04 PM
hproy
also what if you have two batteries and can't hook it up parallel.
My motors are turning somewhere between 100 and 150 RPM different
hproy is offline
sparky
Warbird Electrics
17
08-13-2007 10:04 PM
trooper8
11-05-2006 03:56 PM
RSS Feed
RCU RSS Feed
08-12-2006 12:11 PM
Sky Sharkster
Warbird Electrics
05-30-2006 03:02 AM
Kahu
04-21-2006 04:01 PM
Quick Reply: Newbie question: How to set up multi-engine electrical system?
Page generated in 0.11037 seconds with 14 queries
