wing attachment to fuselage
Old 12-21-2008, 10:47 AM
sprinterXL
Default wing attachment to fuselage
I am a first time builder building a balsa glider. I have a one piece wing which i want to attach to the fuselage using rubber bands. Can you please tell me a good way to do this because i am drawing a blank. I have a hardwood dowel thay came with the kit. thanks.
sprinterXL is offline
Old 12-21-2008, 11:14 AM
xuzme720
c'mere Monkey
xuzme720's Avatar
you should have 2 dowels. one at the front of the wing saddle and one just behind. Usually they are mounted in the fuse parallel to the wing so you can run your rubber bands from front to back on both sides and also cross to form an "x" over the wing.
If you need, I can try to find a picture...
xuzme720 is offline
Old 12-21-2008, 01:19 PM
Default Got the picture
Like this. A friend of mine buys cheap bags of rubberbands and when he is done flying he just cuts them off. resolves the question of "how many times" and makes breakdown a cinch.
mikerenz66
Aerodynamics
07-25-2008 03:18 PM
diverdon
ParkFlyers
01-01-2008 06:31 AM
Spencer J
05-20-2007 07:18 AM
CustomCougar
Pattern aircraft
14
04-03-2007 04:48 PM
elbreeden
03-25-2007 04:54 PM
Quick Reply: wing attachment to fuselage
Page generated in 0.07530 seconds with 15 queries
