Talk about Amazing scratch builds..
Old 01-24-2009, 08:10 AM
Ok Here are 3 motors that I would use for the 10x4.7 prop on 3 cells
http://www.hobbycity.com/hobbycity/s...less_Outrunner
TR 28-30B 14A 1050Kv
Chris Running this motor in a 22oz plane. WO throttle with a fresh Zippy-H 3S 1500mAH battery and a APC 10X5 E pulls 15.8 amps at 200 watts. It does a nice job of pulling the plane around at half throttle.
and the good old 2410-09
http://www.headsuprc.com/servlet/the...lectric/Detail
or the 2830-09
hope that helps, Chellie
Old 01-24-2009, 08:21 AM
if you want to use a smaller prop, there are a lot more motor choices, Take Care, Chellie
Old 01-24-2009, 03:59 PM
Cdr. Instigator
Pimp My Plane
Cdr. Instigator's Avatar
or the 2830-09
Thanks, Chellie
I actually have that motor here waiting on a candidate.. Guesses you found me one!!
Yes it's the profile
3D Batix Extra 330
http://www.rcgroups.com/forums/showthread.php?t=373243
Yesterday I went to the local hobby shop in Nasa Odessy Hobby. I bought the Eflight 370 thinking my 28-30B was too heavy for it.
Now I have 2 choices I guess..
I also bought a new charger because I burned my new Smart charger 2500 by using a 6/2 car battery charger. Ooooppsss !!
So, I bought the Hobbico Quich Field Charger mk2 at 60 dollars. It's a nice one!! You can charge 2 batteries at one time.
I spent 180 dollars on some nesesary field equiptment, I just had to have.
My Extra 330 profile is ready for the electrics.. let's see how the 370 moves it I guess.. Thanks for the input..
Cdr. Instigator is offline
Old 01-24-2009, 07:54 PM
ministeve2003
Class Clown
ministeve2003's Avatar
Originally Posted by Cdr. Instigator View Post
Thanks, Chellie
3D Batix Extra 330
Ouch, I wish you hadn't got the hobbico Mk2, but since you did, after charging 1 lipo battery, check the battery with a multimeter, if it reads less than 4.2volts per cell... take it back and return the charger.... I bought one for my first charger, and found out that it wasn't actually fully charging my batterys.... (the chargeing 2packs at once is a nice gimic that sold me on it) after charging with mine, I would put it on another charger and it would charge another 10-15%
as far as nimh charging goes on that charger... it didn't do a good job on that either....
For lipo's you want a Balance charger....
Here's a very good balance charger... it will do lipo/nimh/nicad
http://www.hobbycity.com/hobbycity/s...lancer/Charger
this lead works with that turnigy charger... and will allow you to charge (2) 3cell packs at once....
http://www.hobbycity.com/hobbycity/s...ead_(2_x_3S)6S_
SK
ministeve2003 is offline
Old 01-25-2009, 02:36 AM
Cdr. Instigator
Pimp My Plane
Shoot !!!
I will return it tomorrow. You can't beat the price of that Turnigy at 30 dollars less than what I payed.
I'm about 80% finished with my Extra 330 profile. i should redo the landing gear. With the 10 x 4.7 slow fly prop, there's only a clearance of about 3/4 of an inch. i know that as soon as the tail lifts off the ground the prop will strike the payment. Yeah, the plans called for a fake landing gear, but I went with real 1 inch wheels and rudder wheel. It looks good.
Tomorrow, I will return the charger and order one on-line. that means i will have to wait on any flying to be had.. Darn!!
I'll post some pictures of my progress on a new thread later tonight..
Thanks.
Old 01-25-2009, 02:42 AM
Shoot !!!
Thanks.
Maybe you can just get some taller front wheels for it
http://www.horizonhobby.com/Products...rodID=DUB250MS
http://www.horizonhobby.com/Products...rodID=DUB300MS
Old 01-25-2009, 06:38 AM
Cdr. Instigator
Pimp My Plane
Yeah, I'm using the 1.5" I think. What I did wrong was throwing away the print out after I had cut all the pattern in the FFF. instead of printing out another plan or even just opening up the pdf file on my lap top, I just eye balled it and they came out too short by about an inch. I just finished undoing one of the wheels and what I'm going to do is add a 2.5in. extension of carbon rod to the landing gear. i will finish it off by adding the pant and skirts. I have started cutting the pieces and I'll finish it of hopefully tomorrow.
I powered it on just to configure my control surfaces and everything is a go.. The only thing I lack is a charger since I will return the new one tomorrow and will have to wait till I receive the one "Ministeve" suggested..
Saucerguy2
Foamies
663
05-15-2009 03:37 PM
SkunkyMagoo
Off Topic Chit Chat
202
03-24-2009 06:24 AM
Jettlagg
02-05-2009 04:13 AM
John Boy
23
04-02-2008 07:57 PM
hookedonflyin
Foamies
03-16-2007 12:18 PM
Quick Reply: Talk about Amazing scratch builds..
Page generated in 0.10767 seconds with 14 queries
