eneloop charging problems. Anyone has same problem ?
Old 09-26-2010, 03:53 AM
whiskey29
Default eneloop charging problems. Anyone has same problem ?
Hi there,
I have been eneloop users around my house, that is from remote control, clock, wii controller, everything.
Its a very good battery with very slow discharge rate.
I decided to make it into the flight pack,
I am now using eneloop lite (1000 mAh) and series them to make 4.8 volts.
My charger is triton, and I set the charging to nimh charging with auto charge and discharge current. Peak detection was 10mv.
After a few cycle the current that goes into the battery is not consistent.
It goes up tp 1000mah in and 850 out, but more often around 100-250 charged capacity.
Setting the charger to NiCad, also resulted same.
Is it my charger ? or has anyone else experiencing same problem ?
whiskey29 is offline
Old 09-26-2010, 04:32 PM
Rodneh
Make sure your charge leads are not very long, are of adequate gage, and that you have very good connections at all junctions.
Rodneh is offline
Old 09-30-2010, 03:35 AM
whiskey29
Hi,
Charge leads are not long and do you think that matters ?
the current is too small and the cable awg is more than enough, because if it isn't cable would be hot but it doesn't.
Old 09-30-2010, 11:42 AM
Rodneh
Yes it does matter. Just a few millivolts drop (readily occurs especially in the contact resistance at the connections) can create a false "end of charge" signal. Contact resistance is more apt to be a problem than too small a gauge wire but both contribute to detection errors.
Rodneh is offline
Old 09-30-2010, 04:00 PM
whiskey29
Well the plug that goes into rx connected does went to another connector.
I will give it a shot then by shortening the charging lead. THanks
wilder
08-21-2009 08:03 PM
Jizzer8181
9
10-02-2007 08:09 AM
jeffb
08-02-2007 01:23 PM
vaidya_ro
9
03-20-2007 04:59 PM
kc10boom
08-14-2005 05:25 PM
Quick Reply: eneloop charging problems. Anyone has same problem ?
Page generated in 0.10797 seconds with 13 queries
