Servo Replacement Help Please
Old 08-03-2014, 08:53 PM
dereckbc
Default Servo Replacement Help Please
I have a PZ Visionaire 3D plane that uses 13 gram digital servo's (part# EFLR7155) that is stripped and needs replaced.
Other than the original how can I find a suitable replacement. No offense to E-Flite fans but th eservos seem cheap and I am looking for a little higher quality and less expense. HH wants $18 for a replacement and my gut tells me that is too much for quality level.
dereckbc is offline
Old 08-03-2014, 09:14 PM
Hitec digital same size would be fine. Might want to get the programmer also and there is a chance you will need to either program the servo for reverse or use the reverse function of the transmitter.
ALWAYS check control directions when changing servo brand.
Old 08-03-2014, 09:35 PM
Check these out....:
http://hitecrcd.com/products/servos/...nd-mini-servos
Some are little pricey....however, without bias, HiTec serves many very well......German, Japan and Korean made.....not Hong Kong.......
Old 08-03-2014, 09:42 PM
dereckbc
THX after some research, the VA servos appear to be known for high failure rates like mine. Mine Oscillates/Flutters violently when on the ground. Problem follows the servo when I switch from rudder to elevator on the RX.
dereckbc is offline
Old 08-04-2014, 06:23 PM
dereckbc
OK guys help me out here. How do I know the physical size wil fit the hole in my plane? Unfortunately the Visionaire spec does not list one single spec for this servo, most notable the physical size dimensions. Only thing it gives is the weight or 13 grams.
Are servo case dimensions standardized? I do not know what I am looking for.
dereckbc is offline
Old 08-04-2014, 06:28 PM
servocity.com... and a ruler.
Servocity has the dimensions of the servos they sell listed on their website. A ruler and measuring the old servos will let you compare.
Note that the dimensions of all 9 gram servos are almost the same. Small enough difference that you can make them fit. 13 to 17 gram servos aren't quite as good about having similar case shapes.
There is no official standardization of servo case size. There are shapes that tend to work and thus the "standard" (appx 45 in-oz servos that for a long time were just about all you ever saw) size servos by all brands were very close tot he same size, but even then the spacing of the mounting holes proved they were off just a bit.
Old 08-04-2014, 08:42 PM
dereckbc
OK my problem is solved for now.
Hats-Off my fellow enthusiast to HH Warranty & Tech Support policies.
I did something really dumb and stupid. It is just plain ole embarrassing to admit this. I called Horizon Hobby Tech Support, told them I bought a Visionaire at a local Hobby Shop about 6 weeks ago, and the issue with the servo.
Rep looked up my name from the REGISTRATION CARD, past Account History, and then advised me: HH would send out replacement Free-Of-Charge.
Now here is the kick in the pants which I did not expect. The Rep said: "If for some reason I was at a swap meet and found some HS 5065MG servos cheap would make an OK replacement in a pinch"
dereckbc is offline
Old 08-06-2014, 06:13 AM
Personally - because supply is not so easy for me - I use :
Turnigy
Bluebird
HXT
Hobby King own
from Hobby King ... and they do the job very well ...
I will not use Corona ! Every one I've bought of theirs have been awful ...
Just my 2c's worth ...
Old 08-06-2014, 06:49 AM
As an alternative (and better IMHO) option to the HS-5065 you might try these, they are excellent servos: http://www.hobbyking.com/hobbyking/s...10sec_16g.html
An other option is the Savox SH-0255 or 0257 which again are very good servos (0255 -= high torque, 0257 = high speed)
Old 08-06-2014, 09:59 AM
Horizon is known for their great customer support. Glad they're sorting this out for you.
Old 09-04-2014, 12:14 PM
Karnsy
I wondered if someone could tell me the difference in terms of better or not between digital servos and servos that are not digital and also a reversing servo ?
Karnsy is offline
Old 09-05-2014, 10:01 AM
Lots of people see to like this digital metal gear 18 gram servo, and at $10.58 its a great deal.
http://www.hobbyking.com/hobbyking/s...sec_18_8g.html
Overall Rating
Victor Chauvet
likes ValueUNRATED QualityUNRATED 47 thumbs up!
You get more than what you paid....this servo can easily replace all your H81mg without problems.
Overall Rating
Keith
151 likes ValueUNRATED QualityUNRATED 39 thumbs up!
They work, center well, quiet, no jitter.
Overall Rating
Ervin Pabbo
likes ValueUNRATED QualityUNRATED 30 thumbs up!
I use this servos on 3M electric glider - very good !
Strong construction,maybe too robust,but working good.
I recomend to use this servos even a bigger models !
Overall Rating
Mufit
likes ValueUNRATED QualityUNRATED 29 thumbs up!
Ok it is twice as much heavy than 9gm servo, but it is much powerfull, digital, metal gear, and very fast. What else you want? At that price with that holding power, it is certainly a good deal. I bought 5, and will buy more. No annoying buzzing at all!
Overall Rating
D-MG16 Metal Gear
42 likes ValueUNRATED QualityUNRATED 26 thumbs up!
I buy 7 these servo.They work perfect.I have no problem with them.
needlenoses
ParkFlyers
8
04-18-2014 02:55 PM
k-vette
9
02-06-2012 02:13 PM
RCFlyer44
22
03-29-2011 05:55 AM
Quick Reply: Servo Replacement Help Please
Page generated in 0.10377 seconds with 12 queries
