TM 1000 Setup
Old 06-28-2016, 04:10 AM
rcpilot134
rcpilot134's Avatar
Default TM 1000 Setup
Trying to get a TM1000 working with an Ar7350 RX. Watched the HH video and a few others but still not working. Just interested in the voltage sensor for now
Here's what I did:
After creating a model with the programming software and setting up AS3X, bound the RX to a fresh model on my TX. Then plugged connector into appropriate port on the TM1000 and then to RX. Bound as directed by the video. What this achieved is screwing up all of my gain settings that I had setup. I can only assume this happened because for the as3x programming, I rebound the RX to an existing model. Not sure
But anyway, set it up all over again (as3x-gains) but this time, I bound RX and Tm1000 with Tx (fresh model) at the same time and still no go. No voltage readout for the flight pack. Not sure I explained this all correctly but any thoughts would be appreciated
rcpilot134 is offline
Old 06-28-2016, 06:58 AM
I've got several TM1000 units fitted to my planes and helis. I think that both the Rx and TM1000 need to be bound simultaneously (at least that's how I always do it). So procedure is:
  • Put the bind plug in the Rx
  • Press in and hold in the bind button on the TM1000
  • Power up the plane.
  • Both Rx and TM1000 should show flashing LED's indicating that they are in bind mode
  • Power up the Tx into bind mode
  • Both Tx and TM1000 should bind to Tx
It helps to have a spare pair of hands!
Old 06-29-2016, 04:28 PM
AndyKunz
Spektrum Dev Team
The AR7350 includes a built-in TM1000. You can't use them together. The sensors plug into the X-Bus port of the AR7350. Save your TM1000 for a receiver that doesn't have built-in telemetry.
Andy
AndyKunz is offline
Old 06-29-2016, 04:30 PM
AndyKunz
Spektrum Dev Team
You can save yourself that extra hand!
Plug a servo Y into the Bind/Data port. Put a bind plug in one side, attach the TM1000 in the other.
Power up (no need to press the button). Both are now blinking quickly.
Put the transmitter in bind mode.
Done.
Note: Depending on the receiver and the failsafe mode you want, you may need to remove the bind plug after the rx and TM1000 start blinking.
Andy
AndyKunz is offline
Old 06-29-2016, 05:30 PM
Great tip, thanks!
Old 06-30-2016, 02:13 PM
rcpilot134
rcpilot134's Avatar
Andy
Well that explains that. First go round with this so thanks much. I'll give it a try tonight. Thanks Andy!
Old 07-02-2016, 07:10 PM
rcpilot134
rcpilot134's Avatar
I'm not the smartest guy in the room but not the dumbest either. All I'd like to do is get flight pack voltage to work on this and eventually on all my models (ar636's). The AR7350 has ports built in for VOLTS - TEMP - RPM. Etc. All of these have a little 3 pin female port and since the inline voltage sensor has a 3 pin male connector, I'd think it goes in volts port. However I get nothing. A post above suggest it goes in x-bus - no joy there either.
There is a 4 pin port also labeled sensors? The only thing I see online with 4 pin males are the extension leads. I guess I can extend this question even further as to why there is absolutely nothing in the ar7350 manual touching on anything about getting telemetry working - nothing.
Old 07-02-2016, 08:14 PM
AndyKunz
Spektrum Dev Team
X-Bus is a 4-pin port. It's a serial communication bus.
You plug the V sensor into the 3-pin connection, that is correct.
What you probably didn't do is update the code in the receiver. There was a bug in the shipping code. The right stuff is on the web now - version 1.60 I think is the version. Whatever is newest.
Andy
AndyKunz is offline
Old 07-02-2016, 08:22 PM
rcpilot134
rcpilot134's Avatar
I think I did but will double check. Thanks
n3o
12-01-2011 11:58 PM
Fulanito_uk
09-22-2011 06:58 AM
twinbrother2010
07-25-2011 06:15 AM
Alexander
Delta & Flying Wings
9
03-15-2011 02:51 PM
KenSue
9
01-29-2011 02:36 AM
Quick Reply: TM 1000 Setup
Page generated in 0.10828 seconds with 12 queries
