Bungee modification to avoid pusher props
Old 07-13-2016, 02:21 PM
Default Bungee modification to avoid pusher props
I have been using my traditional bungee system now for many years and only once as the trigger line fouled a prop. I had lost my heavy ring on the end and tried with a knotted loop in the line. The line failed to drop away and got caught.
Put a new ring on it and all was fine again.
The memory never left my mind though and I was looking for a way to separate the trigger from the working line - well here she is and cost was about $1.
First I set up my gear and did a quick measure. I would need to shorten my trigger line to about 1m and set a separate trigger line of about 2m.
My overall bungee would not change : 10m bungee doubled to 5m and then 4m of strong 2mm line to the joint where model line and release line are.
Here's my sketching for the modification :
OK - what I now have :
Still uses original plywood trigger board well clear of props etc.
As you see ... a line goes forward to the front bottom bar of the ramp system. On there is a hinged pin that line is fixed to.
The trigger and pin are set and then the bungee stretched with release line then slipped onto the pin. This is held in tension by the trigger board.
This shows the line splitting of for release and model ..
So ....
4m of line ...
5m of doubled bungee with my 3 stake anchor system ...
Here is a photo close up of the simple hinge part ... a domestic latch is all that's needed. It's screwed to the plastic frame.
This means that the trigger line stays with the ramp and should never get near to the prop.
Looking fwd to giving her a go ....
iFLYrc_Vic
Scale E-Powered Aircraft
21
05-06-2012 08:43 AM
Pusher Park Jets
04-20-2012 03:17 PM
dumpsterjay
12-31-2011 08:37 PM
iFLYrc_Vic
01-04-2011 11:52 PM
Pusher Park Jets
13
11-02-2009 10:39 PM
Quick Reply: Bungee modification to avoid pusher props
Page generated in 0.07153 seconds with 12 queries
