tower pro 2409-12 brushless motor help - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 11-07-2009, 11:42 PM
Mike-145
Default tower pro 2409-12 brushless motor help
Can you please help me i have a tower pro 2409-12 brushless motor and it keeps vibrating and wobbling
I have about 20 flight on it and it has never done that
here are some videos
http://www.rcuvideos.com/video/tower-pro-2409-12-2
Thanks for the help in advanced
Mike-145 is offline
Old 11-07-2009, 11:53 PM
smokejohnson
smokejohnson's Avatar
Looks like a bent shaft to me. You can check it by pulling it out and rolling it across a flat surface.
http://www.headsuprc.com/servlet/the...for-the/Detail
smokejohnson is offline
Old 11-08-2009, 12:18 AM
Rolling Thunder
Keep the sunny side up
Rolling Thunder's Avatar
yowzzy I'll say so too.Check the little grub screws on the side of the shaft for any looseness as well
I've since upgraded to a stronger shaft motor myself http://stores.ebay.com/A1-Hobby-Group_Motors__W0QQ_fsubZ522244011QQ_sidZ864734591Q Q_trksidZp4634Q2ec0Q2em322
Rolling Thunder is offline
Old 11-08-2009, 03:37 AM
MustangMan
MustangMan's Avatar
Default Another problem with these motors...
I've had occasional problems with these motors. In an effort to keep the motor from working loose in the mount I sometimes over-tighten the grub screws and distort the bearing which is at the open end of the stator tube. The result is that some or all of the little balls fall out of the bearing and then it gets really sloppy and runs the risk that the shaft could pull out of the motor. Thus far I haven't actually had one come completely apart but I consider myself just lucky.
MustangMan is offline
Old 11-10-2009, 01:16 AM
Mike-145
Here is the link to the motor
http://www.hobbycity.com/hobbycity/s...idProduct=2046
I am looking for a better motor that has the same power setup but a little more durable and is still available at hobby city
Thanks Mike
Mike-145 is offline
Old 11-10-2009, 03:07 AM
Rolling Thunder
Runs cooler,quiter,has a stronger motor shaft.I know you said h.c. but with free shipping it all comes out even steven.Might even be a little cheaper -http://cgi.ebay.com/New-2826-10-1400Rpm-V-Outrunner-Brushless-Motor_W0QQitemZ170332343570QQcmdZViewItemQQptZRadi o_Control_Parts_Accessories?hash=item27a8994d12
Old 11-10-2009, 12:26 PM
wingnutt
Will work for foam
wingnutt's Avatar
I would upgrade to a stronger shaft. You can get a 'free' one if you have an old CD-ROM drive laying around. The stainless pin that the laser eye slides on is a perfect 3mm shaft replacement.
Once you upgrade the shaft and get it installed, it would be wise to ballance the bell/shaft assembly together. I find that most of the bells on these types of motors are out of ballance. Use that cut-and-kneed type of epoxy putty to ballance the assembly by placing dabs of it on the back ends of the magnets between the magnets and the lip of the bell. Just be sure that no putty sticks up higher than the magnets! I use two razor blades (held vertically with small clamps) as rails sitting on a FLAT table to roll the shaft along.
wingnutt is offline
adnan012
09-30-2009 07:47 AM
rcproptester
04-11-2008 10:06 AM
diverdon
01-13-2008 05:47 PM
adnan012
12-30-2007 11:44 PM
stampede_dude
11-23-2007 09:53 PM
Quick Reply: tower pro 2409-12 brushless motor help
Page generated in 0.06390 seconds with 15 queries
