New Lipo setup - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
View Poll Results: Best brand of lipo battery?
thunderpower
33.33%
flight power
66.67%
Common sense rc
66.67%
electrifly
0%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
New Lipo setup
Old 06-10-2009, 03:53 AM
Mike-145
Default New Lipo setup
I have a Airfoilz edge 540 and i want to get a new lipo battery that will last longer in the air. I was thinking about a Triton jr charger and i would charge the battery thought the deans connector and use the astro flight blinky to ballance the battery.
My motor is a Turnigy 2217 16turn 1050kv 23A Outrunner my esc is a
TURNIGY Plush 25amp Speed Controller.
Will i be able to put either of theses thunder power lipo battery in my plane
11.1V 1320mAh 3-Cell
11.1V 2000mAh 3-Cell
11.1V 2100mAh 3-Cell
will either of these setups fry my motor or speedcontroler
and how long of flight time do you think i will get with these batteries
Thanks for all your help
Mike-145 is offline
Old 06-10-2009, 04:17 AM
Nitro Blast
Nitro Blast's Avatar
Hi Mike,
In reply to your question, yes, any of those choices will be just fine.
But, I prefer the Hyperion's. The new G3's are real killer.
HYPERION G3 CX 1600 MAH 3S 11.1V 25C/45C LIPOLY PACK
Click here for Specs
But how much flight time do you want? I find my Airfoilz Edge flys best with the 1200's on it. Super light, and I can afford 2 of those just as easy as 1 2100. I get 10 plus minutes per flight easy. You can get 15~18 minutes with the 2100, but the weight is the bummer. With the 1320's you can get 8~12 minutes, less weight more flight. Do 1200's , buy 2, and get more flight time than just one 2100.
Nitro Blast is offline
Old 06-10-2009, 04:41 AM
ministeve2003
Class Clown
ministeve2003's Avatar
What the heck is up with that poll, chose between two Hi priced (good batterys) or two mediocre packs?
The best seem to be Outrage packs, however, they are only used for heli's or edf usage, all other applications don't require better stuff....
HC Rhino's are the way to go for me....
SK
ministeve2003 is offline
Old 06-10-2009, 04:52 AM
ministeve2003
Class Clown
Bad Idea, the longer it's in the air, the more weight your putting on it... and then it flys worse... (try the 1300 at very most)
Blinkie is not the way to go... get a good charger that balance charges also... This one works great...
http://www.hobbycity.com/hobbycity/s...idProduct=7028
short answer No, Long answer, your battery's can't fry anything... overproping the motor, or overamping the esc does...
The motor is spec'd for 23amps, actuall usage on that has been about 22amps on 11x4.7sf or 10x4.7sf (can't remember exactly so check amp draw)
11.1V 1320mAh 3-Cell 1.3 x 60 / 22a = 3.5 min full throttle
11.1V 2000mAh 3-Cell 2.0 x 60 / 22a = 5.45 min full throttle
11.1V 2100mAh 3-Cell 2.1 x 60 / 22a = 5.72 min full throttle
SK
Old 06-10-2009, 07:12 PM
Mike-145
You said you airfoilz edge flys best with the 1200, what brand of lipos are they.
And Would the HYPERION G3 CX 1600 MAH 3S 11.1V 25C/45C LIPOLY PACK also work with my setup
Thanks Mike
Mike-145 is offline
Old 06-10-2009, 09:25 PM
Nitro Blast
Thanks Mike
Whenever possible, I'm using Hyperion.
That battery you specify will work fine.
night_life
05-11-2009 12:19 AM
ahahum
Batteries & Chargers
07-13-2008 06:40 AM
Angler-Hi
05-15-2008 02:00 PM
zoott
10-30-2006 01:37 AM
stafphoto
04-05-2006 05:08 AM
Quick Reply: New Lipo setup
Page generated in 0.05815 seconds with 12 queries
