GWS Beater warbird build/repair tip - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 04-05-2007, 02:52 AM
K CLOSE
Huge Member
K CLOSE's Avatar
Default GWS Beater warbird build/repair tip
Hi all,
I'm gonna post over in the build tip fourm, but as I lurk here mostly I thought I'd toss this little tidbit up for your prusal. Some time ago I built up a "Frankinstang" from about 6 crashed PZ airframes I scapped up. Once I made a wing of sorts out of it I wanted to cover it with a REALLY wide clear packing tape. At Staples I found a DUCT tape brand "clear laminate". Hummm --clear, check --sticky on one side, check, --wide enough to cover the wing in one piece, check -- cheap,CHECK! The whole roll was like $5. I did the wing on "Frankinstang" and really liked the results. It lays down easy, sticks but can be lifted for re-positioning (untill its ironed on), is really light but once ironed on at low heat really sticks on there-even in contours. Well, I was out grabbing some air time at a local park with the P-51. Thought I was infront of the tree, wasn't. I was behind it. Full throttle high speed strafeing run dive into the top of a dead tree with a ^ 2 lbs model. Took the top 4 foot off the tree. Section I hit was 4-5 inch round, I thought the plane was done for. I could not belive how little damage the plane took at impact---- that ironed on laminate really held up.:o I had previously ironed it onto the bottom of my GWS Zero beater, and the pic's speak for themselves.
Anybody else useing this stuff? It really works grand on bashers.
ID:	27678   Click image for larger version
ID:	27679   Click image for larger version
ID:	27680   Click image for larger version
K CLOSE is offline
Old 04-05-2007, 03:11 AM
Twizter68
I can't see my plane.....
Twizter68's Avatar
Duct Tape Clear Laminate, huh? Will have to give it a shot!
Twizter68 is offline
Old 04-05-2007, 01:45 PM
alienx
alienx's Avatar
Sounds great. Gonna check it out. I have some really cheap packing tape that sucks for sealing boxes but should be very good for planes because it is so thin and light. But the ability to cover the width of a wing seems hard to ignore! Great tip.
alienx is offline
Old 04-05-2007, 10:49 PM
crxmanpat's Avatar
I've used packing tape to cover wing channels and leading edges on my GWS birds, but I've never heard of this stuff before. I may have to go down and find some this weekend.
How well does paint adhere? Do you have to scuff it up first?
crxmanpat is offline
Old 04-08-2007, 08:40 AM
K CLOSE
Huge Member
K CLOSE's Avatar
CRX,
I have not painted the laminate. I painted the Zero and then added the covering. Belive it or not the photo's are of the paint/details through the lamiate. Leading edges of the wing top (3") and full wing bottom. Frankinstang was "as PZ painted it", ie. 6 shades of O.D.Green. It also made a GREAT hinge for my battery hatch (see photo). I'll be honest I don't think it would paint well at all. Thats why I feel it's more of a "beater" covering, but man it's strong, light and cheap.
ID:	27914   Click image for larger version
K CLOSE is offline
Old 04-08-2007, 04:58 PM
Twmaster
Registered User
Twmaster's Avatar
WooT!
Great tip. How wide is the roll?
Twmaster is offline
Old 04-08-2007, 05:01 PM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
Is this the stuff?
http://www.duckproducts.com/products...id=22&plid=101
Grasshopper is offline
Old 04-09-2007, 05:22 AM
K CLOSE
Huge Member
K CLOSE's Avatar
Hoppy,
Yea, thats the stuff. Twmaster, Hoppers link is the exact stuff--18" x 24'. Try it and let me know what you think guys.
K CLOSE is offline
Old 04-12-2007, 09:11 AM
K CLOSE
Huge Member
K CLOSE's Avatar
Not to beat a dead horse but I just wanted to add a bit of info. I flew the Zero today and noticed the laminate had pulled out of some of the coves. Mind you, the edges and flats were still bang on, but some of the concave areas needed to be pressed down again. Now this covering has been on there for months, but noteworthy. Also noteworthy was how it resisted some runway rash. Rubbed a wingtip on the runway by accident , thought for sure it was gonna be chunked out (lost about 1/8" off the right wing last time). Not a mark. Nothing. FWIW
PS. I want to finsh up a decal post over in the build thread before I post this tip there (if anyone was wondering). I don't want to be a hog.
K CLOSE is offline
Saucerguy2
15
04-17-2013 11:45 AM
racer_dan
11
08-07-2007 03:07 AM
barmonkey
Warbird Electrics
03-29-2007 04:35 PM
rlfgary
Warbird Electrics
12
06-14-2006 06:35 PM
High Plains Thumper
09-05-2005 11:34 PM
Quick Reply: GWS Beater warbird build/repair tip
Page generated in 0.11045 seconds with 20 queries
