Yak-3, scale 1:6, composite build - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-20-2008, 12:28 AM
lz23
Default Yak-3, scale 1:6, composite build
Long time ago I was amazed by this airplane, build few small static models and decide some day to build flying scale model. Now this time come finally, so here it is:
The model will be 1:6 scale. Power 4120 or 4130 depend on the final weight. Optional 0.60 should fit nicely under the cowl too.
Wingspan - 60", length - 55"
Weight hopefully in range of 7-9 Lb.
My build start from fuselage. I have to make positive mold first, so first I build a frame that will be covered with depron and filled with expandable foam. Then will be covered with fiberglass and detailed. Here is build process so far:
lz23 is offline
Old 01-20-2008, 04:24 PM
wilmracer
subscribed
I look forward to seeing this one come together.
wilmracer is offline
Old 01-20-2008, 04:45 PM
Me too! Something different is always nice.
Looks like you are off to a fine start!
Old 01-20-2008, 05:03 PM
lz23
Rare war birds always have a lots of charm for me. Here is a little more:
lz23 is offline
Old 01-20-2008, 05:28 PM
pd1
Still Learning
pd1's Avatar
Looking good, gotta watch this.
Paul
pd1 is offline
Old 01-25-2008, 05:21 PM
lz23
Here is little progress:
Fuse is filled with foam.
Some foam is removed and covered with depron.
lz23 is offline
Old 01-25-2008, 06:17 PM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
Subscribed. Not sure how I missed this one. That's a nice looking plane. Looks like the mated a P-51 and a Spitfire.
Grasshopper is offline
Old 01-28-2008, 03:39 AM
lz23
Here is after rough shaping. Still far from done, but all ready recognizable shape:
lz23 is offline
Old 02-02-2008, 11:57 PM
lz23
I'm always very slow when it comes to filler. Last week was mostly filler and sanding. Now the fin is ready too.
lz23 is offline
Old 02-03-2008, 04:58 AM
lz23
Here is the beginning of the stabilizer. All will be covered with 3/32 balsa and thin fiberglass and epoxy.
lz23 is offline
Old 02-03-2008, 08:15 PM
lz23
Here the stabilizer is ready
Fit in the fuse is tight. Wil need little work i there, but not too much.
lz23 is offline
Old 02-14-2008, 02:35 AM
lz23
Bottom part of the wing is ready. Now have to cover the top.
lz23 is offline
Old 02-14-2008, 12:37 PM
wilmracer
Looks good!
Old 02-14-2008, 03:45 PM
lz23
All shown here is going to be the plugs, not actual flying parts. This model is going to be full composite build.
lz23 is offline
Old 02-16-2008, 10:50 PM
lz23
The wing is covered. Now is time for leading edges and wingtips.
ID:	55992   Click image for larger version
ID:	55993   Click image for larger version
lz23 is offline
Old 02-19-2008, 01:15 AM
lz23
Here is a little more of the wings:
ID:	56309   Click image for larger version
ID:	56310   Click image for larger version
lz23 is offline
Old 02-23-2008, 11:28 PM
lz23
Here is interesting pic - My Bristol on top of Yak's wing. Just for size comparison.
lz23 is offline
Old 02-24-2008, 02:11 AM
lz23
Here is the coolers. It is hard to see, but this is what I can get with the cellphone camera... They are still in very early stage, but start taking shape.
ID:	57191   Click image for larger version
ID:	57192   Click image for larger version
lz23 is offline
Old 02-24-2008, 02:44 AM
haze_b
haze_b's Avatar
Amazing work!!! I look forward to seeing it fly!!
haze_b is offline
Old 02-25-2008, 04:52 PM
lz23
Thanks! Will have a lot more things to do before get her in the air. Here is a little interesting info.
ID:	57422   Click image for larger version
lz23 is offline
Old 02-26-2008, 11:13 AM
mmmdowning
mmmdowning's Avatar
Wow, nice jog. I'll be watching.
mmmdowning is offline
Old 03-18-2008, 05:21 AM
lz23
Slow progress: stabilizer is primed, wing is glassed. Next will be glass for the fuse. And the wing is primed too, now will be lots of sanding...
ID:	59997   Click image for larger version
ID:	59998   Click image for larger version
lz23 is offline
Old 03-18-2008, 11:39 AM
alienx
alienx's Avatar
Wow. Very nice work!!
alienx is offline
Old 03-18-2008, 04:27 PM
lz23
Thanks! Cool part is just coming!
lz23 is offline
Old 04-11-2008, 04:13 AM
lz23
I have little progress on the wing. Top side is almost ready, bottom is still gray, have to go over few more time with sandpaper and paint it.
Here is current status:
ID:	62563   Click image for larger version
lz23 is offline
Quick Reply: Yak-3, scale 1:6, composite build
Page generated in 0.11028 seconds with 30 queries
