Composite Warbird Build 1/7th P-40E Warhawk - Page 8 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 04-03-2012, 05:35 AM
  #176
Slow & Low
b1heqh54
Slow & Low's Avatar
moving along...
Slow & Low is offline
Old 04-05-2012, 10:25 PM
  #177
Slow & Low
b1heqh54
Slow & Low's Avatar
Old 04-06-2012, 10:20 PM
  #178
Slow & Low
b1heqh54
Slow & Low's Avatar
...another breadcrumb
Old 04-07-2012, 05:31 AM
  #179
Slow & Low
b1heqh54
Slow & Low's Avatar
Old 04-14-2012, 05:05 AM
  #180
Slow & Low
b1heqh54
Slow & Low's Avatar
These joins are all prepped with 80 grit and alcohol.
Join Rear Lower Fuselage Seam
Insert Ply Dowel Bulkhead
I was having to wait for the ply bulkhead insert to cure so that I could remove the saddle sections for access when joining the firewall chin subassembly.
Cowl mount blocks held in place temporarily with quick 5 minute epoxy
Next time I will have access to allow attaching the firewall chin in the same operation as the lower rear seam and dowel bulkhead.
Old 04-20-2012, 09:38 PM
  #181
Slow & Low
b1heqh54
Slow & Low's Avatar
...not a lot of time today, but I did find the hour and a half to assemble the chin to the main fuselage - now we wait.... I know, I know, what else is new
Old 04-21-2012, 03:08 PM
  #182
Slow & Low
b1heqh54
Slow & Low's Avatar
Canopy Frame Serial 000002
Old 04-21-2012, 07:18 PM
  #183
Slow & Low
b1heqh54
Slow & Low's Avatar
How do you arrive at a unique airplane?? You nique up on it of course!
Slowly, but rest assured, assuredly, I am moving toward something here. lol
Green leaves a lot to be desired in the way of opacity.
Untrimmed Weight - 820 grams or approx. 1.8lbs
Old 04-22-2012, 02:41 PM
  #184
Slow & Low
b1heqh54
Slow & Low's Avatar
I've carved enough hard balsa block and melted enough plastic in my mother's old oven to know that waiting overnight for a canopy frame to set up is almost too good to be true!
Not bad for #2, but canopy #3 will be even better...
Old 04-23-2012, 07:50 AM
  #185
Slow & Low
b1heqh54
Slow & Low's Avatar
I've got something cooking tonight - wanna take a guess??
Old 04-23-2012, 05:14 PM
  #186
Slow & Low
b1heqh54
Slow & Low's Avatar
You guessed it - that's a lower cowl section.
The tool in all rights should have been at least a two piece mould with the forward section pulling straight off the nose.
Don't be fooled by the test part, rather let it convince you of the durability of the materials involved. I stood on the mould and pulled and twisted that thing with all my might.
Pile it into the ground, dust it off, pop out the dings and stick it back on.
Lets see you do that with an ABS cowl - NOT!!
We conquered the opaqueness issue with a couple of coats of automotive paint in the mould.
So the next fuselage will get brown camo followed by green paint.
Old 06-08-2012, 07:31 PM
  #187
Slow & Low
b1heqh54
Slow & Low's Avatar
Old 10-06-2012, 10:29 PM
  #188
Slow & Low
b1heqh54
Slow & Low's Avatar
New shop - new building season
Wing Mould - Section #2
Flooring Laminate
Old Lamp (tubing)
Furniture Sliders
1/4-20 thread inserts
Aluminum T-slot Extrusion
Carnauba Wax
Hold on....here we go again
Old 10-06-2012, 10:52 PM
  #189
pd1
Still Learning
pd1's Avatar
Glad you're back at it. Looks great so far.
Looking forward to seeing how this comes out.
Paul
pd1 is offline
Old 10-06-2012, 10:53 PM
  #190
Slow & Low
b1heqh54
Slow & Low's Avatar
Paul
hey thanks Paul - me too
Old 10-09-2012, 06:11 PM
  #191
Slow & Low
b1heqh54
Slow & Low's Avatar
These air fittings will be filled with clay and cast in place along with the o-rings. I'll rough up the OD's with a file first to ensure adhesion.
Inexpensive, yes; effective, time will tell.
Old 10-10-2012, 07:18 AM
  #192
Slow & Low
b1heqh54
Slow & Low's Avatar
Clay holds O-ring flat to face. (8 places)
Barbed part ejector port also included in saddle area.
Old 10-16-2012, 06:27 AM
  #193
Slow & Low
b1heqh54
Slow & Low's Avatar
well, it better be right 'cause it's kinda permanent...
Old 10-16-2012, 07:32 AM
  #194
Slow & Low
b1heqh54
Slow & Low's Avatar
surface veil to prevent the heavier weaves from showing through over time
Old 10-16-2012, 05:44 PM
  #195
Slow & Low
b1heqh54
Slow & Low's Avatar
6 Oz Tape - Outer Flange Support
9 Oz Cloth - 1st Layer
Old 10-17-2012, 06:35 AM
  #196
Slow & Low
b1heqh54
Slow & Low's Avatar
no point in throwing another $100 in epoxy and cloth at reinforcing this section until I've seen the cavity - if all turns out well, I can always rough it up with a cup wheel on the grinder and lay down a few more layers of heavy cloth
hopefully this will set up enough to remove the forms tomorrow - now we wait....lol
Old 10-18-2012, 12:11 AM
  #197
Slow & Low
b1heqh54
Slow & Low's Avatar
These flanges are 2 layers of 9 Oz cloth over the tool coat.
It works well. The flange is firm, but still somewhat moveable.
Old 10-18-2012, 01:59 AM
  #198
Slow & Low
b1heqh54
Slow & Low's Avatar
Still have some clay to clean, and my registration pads didn't release again, but all in all not bad for a disabled guy in his basement I suppose.
Old 10-18-2012, 02:07 AM
  #199
earthsciteach
Unreal. Thank you for sharing your work. It is incredible!
earthsciteach is offline
Old 10-20-2012, 03:35 AM
  #200
Slow & Low
b1heqh54
Slow & Low's Avatar
and now we wait...any and all laminating resin donations will be accepted with open arms and the greatest of gratitude at the following address...lol
Two Bulldog P40 Headquarters
94B Henry Street
Brantford, ON
Canada
N3S 7J5
Quick Reply: Composite Warbird Build 1/7th P-40E Warhawk
Page generated in 0.09351 seconds with 11 queries
