Composite Warbird Build 1/7th P-40E Warhawk - Page 9 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 10-20-2012, 09:42 PM
  #201
Slow & Low
b1heqh54
Slow & Low's Avatar
many thanks to all of you that offered to move the project forward...and awwaaay we go...
Slow & Low is offline
Old 10-21-2012, 09:40 PM
  #202
Slow & Low
b1heqh54
Slow & Low's Avatar
If you drop by the shop for a coffee, I'll put you to work... lol
Next, the lower centre section will be cast separate from the remaining two leading edge sections.
Old 10-22-2012, 12:58 AM
  #203
Slow & Low
b1heqh54
Slow & Low's Avatar
Someone who no longer needed it, shipped me one of these today. Top Flite Part Number TOPA1774
I promise to give it a good home and I can't wait to have a look.
Old 11-25-2012, 02:30 AM
  #204
Slow & Low
b1heqh54
Slow & Low's Avatar
Spent some time organizing my new work area and got a good jump on the next mould section today. The rest of the basement is clear and I hope to put some work stations along the walls to support kit production, should the project ever evolve that far.
Old 12-01-2012, 03:14 AM
  #205
Slow & Low
b1heqh54
Slow & Low's Avatar
Lower Wing Centre Section - Ready To Mould
Fear not my fine flying friends, we march ever closer….
Old 12-01-2012, 07:02 AM
  #206
Slow & Low
b1heqh54
Slow & Low's Avatar
High Wear Resistance Room Temp Surface Coat (150g)
Old 12-02-2012, 01:27 AM
  #207
Slow & Low
b1heqh54
Slow & Low's Avatar
I like pictures - hopefully you do to...if not, close your eyes, right....now
Continuous Strand Surface Veil
6 Oz Tape
9 Oz Cloth
West Systems 105 w/slow hardener
Old 12-02-2012, 04:16 AM
  #208
Slow & Low
b1heqh54
Slow & Low's Avatar
coming along....
Old 12-02-2012, 09:15 AM
  #209
Slow & Low
b1heqh54
Slow & Low's Avatar
I’ll let this set up overnight and tomorrow we’ll have just the leading edge sections to go.
Old 12-03-2012, 02:26 AM
  #210
Slow & Low
b1heqh54
Slow & Low's Avatar
Removed the clay and formers.
Next it's leading edge sections.
Got a hand flipping the mould - GTG again
Old 12-07-2012, 05:20 AM
  #211
Slow & Low
b1heqh54
Slow & Low's Avatar
hmmmm - is that a light at the end of the tunnel that I see ??
Note that I've overlapped the upper and lower sections to ensure that there is a guaranteed alignment along the leading edge. If you look even closer you might notice that the inboard overlap is on the upper section while the outboard overlap is on the lower section...if you look even closer you might also notice that the flanges have draft in two planes...if you look still closer you just get bug-eyed (like me)
Old 12-09-2012, 06:19 AM
  #212
Slow & Low
b1heqh54
Slow & Low's Avatar
Wings
Now more nights than I remember,
Did I bow to Glory’s charms.
Tonight My Lady smiles on me,
With bread in open arms.
Lo my world breaks open,
Dawning stairs that weren’t there,
Each step built with hand forged nails,
And dirty, unkempt hair.
Now steely arms spread open:
I have earned the right to fly.
The embers glow a quiet orange
As Glory casts my shadow on an ever sun filled sky.
- b1heqh54
...don't know how long this wing mould has taken me, but tonight it no longer matters...
Old 12-10-2012, 10:58 AM
  #213
Slow & Low
b1heqh54
Slow & Low's Avatar
Merry Christmas to me...
Tomorrow we look inside.
Old 12-10-2012, 08:51 PM
  #214
pd1
Still Learning
pd1's Avatar
Looking forward to the unveiling.
pd1 is offline
Old 12-11-2012, 02:09 AM
  #215
Slow & Low
b1heqh54
Slow & Low's Avatar
I’ll fix the broken flange pretty quickly, but what you see is what you get. (prying with a screw still in place)
Everything worked out great !! (but I have some new ideas for next time…)
Enjoy the video.
[media]http://www.youtube.com/watch?v=GXUW5eBjwJA&feature=g-crec-u[/media]
Old 12-19-2012, 06:02 PM
  #216
Slow & Low
b1heqh54
Slow & Low's Avatar
All trimmed up, clean and waxed.
Here's a tip - keep your bench waxed up good.
Old 12-21-2012, 02:07 PM
  #217
Slow & Low
b1heqh54
Slow & Low's Avatar
A little dusty and a little worse for wear, I think I might just keep this plug hanging around like the hero it is....what a brave little soul
Old 12-22-2012, 04:02 AM
  #218
Slow & Low
b1heqh54
Slow & Low's Avatar
This is the intended configuration of the lower tool during layup. As you can see, the leading edge will be integral with the lower skin. I will try one with a spar that straddles the joint between the upper skin and the leading edge. This may just be enough to make things nice and easy. If not, then I may later make joggle flanges to bolt to the lower section that would form a glue lip when the joggle flanges were removed prior to final assembly and I will move the spar rearward in the chord. I expect that I may have to vacuum bag the lower skin just to hold the cloth on the inverted mould face of the upper leading edges. Worst case they can always be layed up separately and joined to the lower skin while still a little green. If you look very closely you might see the LED's that I moulded into pockets recessed into the trailing edges at the ailerons. They are embedded proud of the tool face in a pocket designed to give the pushrod for the ailerons a place to exit the wing. This should provide nice lighting inside the tool during final assembly - cool or what...lol
Old 01-07-2013, 11:25 PM
  #219
Slow & Low
b1heqh54
Slow & Low's Avatar
Happy New Year Everyone !!
...and this year should prove to be an exceptional one
The most common question I get is how much detail do you lose.
My standard answer is don't breath on your plug while you brush on your tool coat.
Here's a few quik pics of the top of the wing mould.
This should ease your fears about losing any detail, but be warned I don't use PVA, only a thorough coat of pure carnauba wax.
Too many pictures you say - too bad
Old 01-08-2013, 04:38 AM
  #220
Slow & Low
b1heqh54
Slow & Low's Avatar
Here's a new idea...
Old 01-08-2013, 06:09 PM
  #221
Slow & Low
b1heqh54
Slow & Low's Avatar
Upper Wing Skin #1
I wonder if I could introduce a two part pourable closed cell urethane foam into the brass fittings and get it to react slowly enough to avoid voids...maybe at a 2lb/ft^3 density. I've tried before with limited success, but first we'll try a simpler approach to see where we stand.
Old 01-10-2013, 08:32 AM
  #222
Slow & Low
b1heqh54
Slow & Low's Avatar
550 grams or 19.4 ounces or 1.2 lbs - room for improvement
Old 01-10-2013, 07:21 PM
  #223
Slow & Low
b1heqh54
Slow & Low's Avatar
Old 01-11-2013, 05:05 AM
  #224
Slow & Low
b1heqh54
Slow & Low's Avatar
Old 01-13-2013, 05:19 AM
  #225
Slow & Low
b1heqh54
Slow & Low's Avatar
These leading edges should be nice and light.
All they have to do is deflect air over the spar.
Quick Reply: Composite Warbird Build 1/7th P-40E Warhawk
Page generated in 0.09693 seconds with 11 queries
