T-Rex V2 35X ESC low lipo cut-off voltage protection
I have a 2 months old T-Rex 450SE v2:
I can't program my Align 35x ESC to low lipo cut-off. For some reason it will only accept mid lipo cut-off. I tried at least 10 times without success. I can set any other mode to high level without problem.
The lipo cut-off is the 3rd mode in the programming sequence and low cut-off voltage is the high setting (3 bip).
As I am using 4s a123 batteries most of the time and the esc battery protection mode cut-off too soon at mid setting.
Can anyone here his ESC to low cut-off voltage protection? or am I the only one that can't get this. The manual does not say anything about this set-up not being available.
I read a reply from Finless Bob on another forum that it looks like the latest Align ESC will not allow you to program low lipo cut-off anymore. This option has been removed from Align on all their new 450 and 500 helicopters sold recently
As my A123 batteries are 3.3v 4s instead of 3.7v 3s, and that the ESC somehow recongnize these as being a 4 cells battery, it is normal that I get early cut-off.
What I don't understand is why my 2-3 first flights were OK for 7 minutes without any cut-off when now the ESC cuts off after 1 minutes. Did the ESC got smarter all of a sudden
I am quite sure my batteries are not damages and still like new
Does anyone have a solution for this? I would like to be able to use these A123 batteries in my T-Rex as you can fly 10 minutes and recharge in 15 minutes. Basically you can fly all day on 2 A123 batteries and get over 1000 cycles on each of them.
