Will my field battery charger work for my motorcycle battery? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 09-06-2006, 10:21 PM
vax6335
Crazy 'bout Bees
vax6335's Avatar
Default Will my field battery charger work for my motorcycle battery?
This is for all you glow flyers that use engine starters and drive motorcycles too. :p I have one of those Hobbico (I think that's who it is) wall chargers for a 12 volt field box battery, and was wondering if it would work fine for keeping my motorcycle battery up this winter.
vax6335 is offline
Old 09-06-2006, 10:59 PM
Don't know why it wouldn't Andy but I use these on the bugs and I have never had one drain out over the winter.
http://www.jcwhitney.com/autoparts/P...010093/c-10107
It disconnects the battery from the system enabling it to maintain it's power longer.
Old 09-06-2006, 11:00 PM
ForestCam
Bad Influence
ForestCam's Avatar
What's the amp output? As a rule I'd never leave anything hooked to a battery for an extended period that put out any more then 500ma.
You can pick up wall wart battery maintainers for about $10 and they even come with the quick connect leads so you can just leave one end attached to the battery.
ForestCam is offline
Old 09-07-2006, 12:35 AM
Crash Test Dummy
Crash Test Dummy's Avatar
I have a battery tender for my Valkyrie, It turns itself off until it detect low voltage then it trickle charges it until it is fully charged. Your wall wart could over charge your battery.
It's better to be safe and pop for 10 to 20 bucks that is designed to do the job.
CTD
Crash Test Dummy is offline
Old 09-07-2006, 12:40 AM
good advice CTD!
Old 09-07-2006, 01:10 AM
Andy, Andy, Andy.... ride the bike all winter then you won't have to worry about charging your battery!!! They have snowplows up there don't they :p
Old 09-07-2006, 01:20 AM
ForestCam
Bad Influence
ForestCam's Avatar
Dad used to work with a guy that rode his Harley to work year round. When the snow started to fly he'd put on the sidecar that contained 4 car batteries (more for ballast then starting but they were all wired up) and as soon as spring hit the sidecar came off.
Cool thing was watching him put it in reverse, back it out of his stall in the garage, drop it in first and take off, all without the sidecar and with his feet on the pegs!
Old 09-07-2006, 01:49 AM
N3CLI
Retired Pharmacist
N3CLI's Avatar
Move to Florida and ride all year!
Battery Tender is the way to go. It actually turns off when the battery is full to avoid overcharge.
Try it you will like it.
N3CLI is offline
Old 09-07-2006, 01:54 AM
ForestCam
Bad Influence
ForestCam's Avatar
JC Whitney has 'em for $30
Old 09-07-2006, 02:48 AM
Crash Test Dummy
Thats funny, I also knew a guy that rode with a sidecar in the winter. I think he was nuts!! I love to ride as much as I love to fly, however I don't like to freese. At crusin speed 45 feels like sub 0 When the temps drop to 45 thats when I won't attempt a ride longer than around the hood a couple of times just to get my bike fix. Got to watch out for the salt in the corners, it will put you on your butt in a hurry.
Raynet11 and I fly every Sunday morning, even in freesing weather. But then again the planes are the only part thats going 40+mph in the cold temps.
Battery Tender, yup....thats the way to go.
CTD
Old 09-07-2006, 04:59 AM
vax6335
Crazy 'bout Bees
vax6335's Avatar
LOL, I would, but it's a 26 year old bike, it doesn't need any more chances for rust to develop. Plus, I'm gonna use this winter as the downtime to fix all the oil leaks it's got.
I guess I'll go with trickle charger meant for bike batteries, I didn't realize they could be had for cheap.
vax6335 is offline
Old 09-07-2006, 06:17 AM
airmail wf
airmail wf's Avatar
There not oil leaks. It's just marking it's spot.
Battery Tender. Also take the battery out and keep it in a warm place.
airmail wf is offline
Old 09-07-2006, 03:34 PM
Matt Kirsch
Matt Kirsch's Avatar
If you have a Harbor Freight in your area, they sell a "Float Charger" that is often on sale for $4.99 or $6.99. I have several of these for maintaining my field box, tractor, and trailer batteries over the winter. They work great.
Matt Kirsch is offline
Old 09-07-2006, 07:07 PM
N3CLI
Retired Pharmacist
N3CLI's Avatar
I have one of these and it does the job on my 17 amp sealed battery.
N3CLI is offline
Old 09-08-2006, 05:39 AM
Crash Test Dummy
Wow, i have a Habor Freight near by, I'll have to check it out.
CTD
Old 09-08-2006, 01:13 PM
vax6335
Crazy 'bout Bees
vax6335's Avatar
I bought one last night, but haven't messed with it yet. It was normally $10, on sale for about half.
Thanks for the suggestion!
-Andy
vax6335 is offline
Old 09-09-2006, 12:49 PM
kohned
A word about Battery Tender Jr. Don't buy one. The battery on my BMW was low so I hooked up Jr. and went to both jobs for a couple of weeks. When I thought to check the battery it was boiled dry and smoking.
kohned is offline
Old 09-19-2006, 03:50 AM
Bub Steve
Bub Steve's Avatar
Lightbulb
I use my 12 volt 7Ah batt, Hobbico torqmaster LC to charge mine all the time, never had any prob's what-so-ever, you can carry out in your field box, charg'in one fly'In one ,Dry cells have a mind of there own and the best way to tell their over charg'in is when they start worp'in round the middle good tread guy's!your bub. steve
Last edited by Bub Steve; 09-19-2006 at 04:01 AM. Reason: forgeot the pix's ( again)
Bub Steve is offline
Old 09-19-2006, 04:01 PM
Matt Kirsch
Two possibilities here:
1. Faulty charger. That happens, and shouldn't be used as criteria to condemn an entire product line.
2. "Float" chargers are meant to keep an already-topped-off battery charged. They're not meant to be used as battery chargers, and the long period at full capacity may have caused the unit to malfunction.
rckowal
20
10-03-2008 05:53 AM
groundparrot
07-12-2008 02:26 PM
neilg.
General RC E-Heli Talk
04-02-2008 12:29 AM
weathervane
01-02-2008 11:28 AM
rx20040
23
02-08-2007 04:23 AM
Quick Reply: Will my field battery charger work for my motorcycle battery?
Page generated in 0.08933 seconds with 15 queries
