Hangar 9 Tango conversion
Old 04-04-2008, 01:36 AM
pmikeyg
pmikeyg's Avatar
Default Hangar 9 Tango conversion
Thinking about converting my Tango to Brshless! Not sure if anyone has done it, or if there are any recommendations in doing it. It came with the mounts for the motor, so that wont be hard. If anyone out there has done a similar conversion let me know!
pmikeyg is offline
Old 04-04-2008, 07:27 PM
tclaridge
I installed a Power 46. Lots of power, but I wouldn't call it unlimited vertical. AUW came to 5.3 lb with a 4S 5000 mah battery. Jeti Advanced 77 esc with UBec. Clean, easy, drag and drop install. Battery hardly gets warm after 12 min of hard flying. I don't think you even need the cut out on the bottom of the tail.
All hardware was stock from the box for this motor. I built a little battery stop to move the battery forward, as the Power 46 is a little lighter than a gasser.
tclaridge is offline
Old 04-05-2008, 07:06 AM
pmikeyg
pmikeyg's Avatar
Nice...I heard that you should go with the Power 60 for a little more power for the vertical stuff! I think it will be over powered! Who knows. Thanks for the reply!
pmikeyg is offline
Angler-Hi
Warbird Electrics
05-26-2008 01:25 PM
alwyn
02-17-2008 03:38 PM
admin
11-02-2007 02:05 AM
Sniper.308
Warbird Electrics
04-21-2007 04:00 AM
JPHen
09-23-2005 02:33 PM
Quick Reply: Hangar 9 Tango conversion
Page generated in 0.09929 seconds with 12 queries
