DX7 Spektrum yaw control setup
Old 01-27-2008, 09:55 AM
timotsc
Default DX7 Spektrum yaw control setup
I'm new to the DX7 and wanting help to setup what may be an unusual configuration, well something I can't figure out anyway.
The aircraft is a P38 so has 2 brushless speed controllers/motors, 2 lipo batteries, AR6200 receiver and controlled by ailerons, elevator & throttle.
The 2 speed controllers are connected together with a Y lead so I can only power both motors together. What I was hoping to achieve is yaw control using motor differential.
Is it possible to set the DX7 up so a motor will slow down/speed up relative to each other, controlled by transmitter rudder input but also the throttle stick work for both motors as per normal? (and still retrain aileron and elevator controls as well) I guess this is much like the cheap park flyers that have no moveable control surfaces relying on the twin engines for height and differential for yaw control.
I'm currently flying a mini Slinger using the radio gear from a Esky Lama 4 heli and figure I could use this radio much the same way if I wanted to go with 2 motors. The Lama has 2 contra rotating props which the speed of both are altered using the rudder stick so I figure this could also be configured in a twin engine fixed wing aircraft as well to, in effect have yaw control. (but not this P38 as the inbuilt speed controllers would handle the power I need)
timotsc is offline
Old 01-27-2008, 04:31 PM
Pinecone
Yes, you have to do some mixes to get it to work.
Over and RCG there is info on teh exact mixes you need to set up.
Pinecone is offline
Old 01-28-2008, 10:02 AM
timotsc
I'm not sure what you mean by RCG. Can you supply a link?
timotsc is offline
Old 01-28-2008, 02:00 PM
Pinecone
RCGroups.com
When I am over there, I will do a search for it.
Pinecone is offline
Old 02-01-2008, 12:09 AM
Pinecone
Feb 2008 issue of Model Aviation tells how to do this. Page 89.
You have to set up 3 mixes.
One throttle in the throttle slot (1 on JR/Spektrum), the other in Ch 6. Mix 1 (master) to 6 (slave ) at 100%. Mix rudder (master) to each 1 and 6 at about 30% with opposite signs (+30% 4 -> 1 and -30% 4 -> 6). If the wrong side speeds up (yaws wrong way) reverse the sign of the two rudder to throttle mixes or swap the connectors.
Pinecone is offline
Old 02-02-2008, 10:54 AM
timotsc
Thanks Pinecone - I'll try that out.
BTW this is a pic of the aircraft in Qn purchased from WattsupRC
timotsc is offline
GreenAce92
Aerodynamics
03-08-2009 08:14 AM
TheDustyPagan
11-12-2008 10:38 PM
rycomm
07-06-2008 04:24 AM
John-NYC
05-25-2007 10:23 PM
Sniper.308
04-17-2007 09:40 PM
Quick Reply: DX7 Spektrum yaw control setup
Page generated in 0.08624 seconds with 15 queries
