Standard & Large E-Heli Talk Discuss all standard and large sized electric rc helicopters in here
anyone know DX7 setup on t-rex450XL HDE
Old 05-11-2008, 01:49 AM
theecoop
theecoop's Avatar
Default anyone know DX7 setup on t-rex450XL HDE
I need to set up the HDE ,I think it should be simular as the cppm. but not sure. right now things seem backwords. So before I start making adjustments wanted to advise.
theecoop is offline
Old 05-11-2008, 02:07 AM
HeliG
T-Rex Pilot
HeliG's Avatar
Hey coop,
Shouldn't that be the same as the other Trex 450s? I thought so anyway and if so then Finless' CCPM vids will be perfect!
HeliG is offline
Old 05-11-2008, 03:43 AM
theecoop
theecoop's Avatar
i wasnt sure if it would be ,since pitch control is different... so not sure if tx needs setup as 90 degree or 120 degree
theecoop is offline
Old 05-11-2008, 05:58 AM
RUSH
RUSH's Avatar
For the HDE, you want to use the 1 servo (normal, no CCPM) mode for the swash plate since collective pitch is mixed mechanically on the heli. You probably know this already, but just in case... the servo that connects to the pitch arm connects to the "pitch" channel, the servo that tilts the swash left/right connects to "aileron" and the servo that tilts the swash fore-aft goes to "elevator."
RUSH is offline
Old 05-11-2008, 02:05 PM
theecoop
theecoop's Avatar
actually i didnt know that ,thanks will try this setup
theecoop is offline
Old 05-12-2008, 12:57 PM
theecoop
theecoop's Avatar
That was it, but I have some other issue going on ... So I tries a TX reset and now all controls are working , I still seem to have something going on with the pitch ,whicjh i havent solved yet swash plate leans forward quite abit as I give throttle ,I disconnected motor leads and tested all stick movements and they seem ok... thinking it is in TX setting ,,,but will have to work on it more
theecoop is offline
Old 05-12-2008, 02:03 PM
RUSH
RUSH's Avatar
Does the whole swash plate move up and down when you move throttle as well as tilting forward? Or does it just lean forward? If the latter, then maybe the servo is connected to the wrong channel on the Rx? When throttle is applied, the whole swash should move on the main shaft. If both the pitch and elevator servos are moving at the same time, then maybe there is some mix turned on?
The only other thing I can think of is your Tx a mode 1 version? Those have the throttle on the right stick.
RUSH is offline
Old 05-13-2008, 02:40 AM
theecoop
theecoop's Avatar
i had the two switched,, must have done it before turning TX to single servo mode...Thanks
theecoop is offline
miru
E-Flite Helicopters
09-03-2008 03:30 PM
ACRO-HELI
06-01-2008 10:59 PM
timotsc
02-02-2008 10:54 AM
DeGrey
05-27-2007 09:11 PM
dhotamis
02-23-2006 05:22 AM
Quick Reply: anyone know DX7 setup on t-rex450XL HDE
Page generated in 0.07953 seconds with 13 queries
