Any 3DHS 49" Sukhoi Owners Out There?
Old 07-16-2009, 02:01 AM
groundrushesup
groundrushesup's Avatar
Default Any 3DHS 49" Sukhoi Owners Out There?
Just picked up one from Ben at 3DHS - it was a display model he had left over in his shop already built, and I got it for a steal.
Just looking to see if there are any other owners out there, tips, tricks, etc.
Thanks!
GRU
groundrushesup is offline
Old 07-16-2009, 02:02 AM
dogsheep
Banned
Well, I have one living in a box, if that counts!
dogsheep is offline
Old 07-16-2009, 02:04 AM
groundrushesup
LOL oh man this is such a beautiful plane. Is yours the red or the silver/blue?
Old 07-17-2009, 06:32 PM
EDFrules
GravesRC enabler d:)
EDFrules's Avatar
Here's the RCG link:
http://www.rcgroups.com/forums/showt...3DHS+49+Sukhoi
EDFrules is offline
Old 07-17-2009, 06:45 PM
groundrushesup
Originally Posted by EDFrules View Post
Yessir, I've read that thread front to back
Old 07-17-2009, 08:46 PM
dogsheep
Banned
It's the Shell Oil scheme: that tells you how long it has lived in the box!
dogsheep is offline
Old 07-19-2009, 10:24 PM
losifanatic
RC Addict
losifanatic's Avatar
trying to figure out HOW IN THE WORLD you can have such a great plane in a box for so long. I have bought 5 3dhs planes and had to tear them open the day I got them
losifanatic is offline
Old 07-21-2009, 08:27 AM
drewpyfz6
Trainee Ground Teaser
drewpyfz6's Avatar
Got any pictures of the new aircraft?
Cant wait to see it in action
Drew
drewpyfz6 is offline
Old 07-21-2009, 06:43 PM
groundrushesup
Drew
Yeah I'll snap a few shots this afternoon - I still have to build a battery tray and mount the cowl, but I'm off today so hopefully I'll get it done so I can maiden it on Friday or Saturday. (woot)
It is a beautiful plane, man. I can't wait to get it up to air it out!
Josh
Old 07-23-2009, 12:47 AM
groundrushesup
Red face Sukhoi Blues
Well, I took it out yesterday for a maiden - things did not go as well as they should have.
I got it up and it was acting VERY tail-heavy even though I set the CG to be slightly nose-heavy at 10cm.
It had plenty of power, but as I brought it down to the ground for an emergency landing, it stalled sharply and the wheel pants cause on the grass and snapped out the rather flimsy bit where the gear mounts. The wheel pant also punched a hole in the covering on the bottom of the wing.
It was not cool. Worst part is I checked and double checked everything - tightened all the screws, set the control surface deflection to EXACTLY what is recommended.... Oh well, live and learn. I shall repair this damage and soldier on.
Viva la Guerre! She will fly again!
Old 07-23-2009, 02:31 AM
Rolling Thunder
Keep the sunny side up
Rolling Thunder's Avatar
sorry to hear that Gru.I have the smaller 44" version sukhoi
I hear what you're saying about the cg.I hot glued two AA batterys & a 9 volt battery to the motor mount of mine
I dont know where they get these crazy cg's from
get her fixed up & the cg straightened out & you will have a great flying plane
Rolling Thunder is offline
Old 07-27-2009, 07:23 PM
drewpyfz6
drewpyfz6's Avatar
Really sorry to hear about your misfortune.
And am sure you will fix her up, better than before, then have a smooth flight.
Old 07-27-2009, 07:48 PM
groundrushesup
Yeah it was a bummer for sure but its almost already repaired - just waiting for the gear in the mail.
Old 08-03-2009, 03:06 PM
flashburn
Dump the wheel pants and wrap the gear legs with thread (I use spectra 15 lb test fishing line) secured with flex CA.
Balance is critical with these planes, make a balance stand and take your time to get it right. I used modeling clay pressed into the back of the cowl nose ring.
Check your elevator throw with a guage, the plane will snap with around 30-35 degree throw depending on finished weight. Your low rate throw should be 25 degree max. High (3D) rate must be 40 degreee min. Use your radio's expo settings. Mine are -12 on low -45 on high (Futaba)
Also check lateral balance as a heavy wing will make the snap deeper.
Keep some throttle on during landing it's not a glow motor so pulling the stick all the way down kills all power.
Good luck on the re-maiden.
flashburn is offline
guapoman2000
Warbird Electrics
242
10-11-2021 12:59 PM
HeadMaster
ParkFlyers
59
02-05-2010 02:28 AM
pvtzemerak
3D Flying
9
04-15-2009 05:10 AM
ClioRc
Video Parking lot
04-07-2009 09:35 PM
Paraprop
09-11-2006 03:47 PM
Quick Reply: Any 3DHS 49" Sukhoi Owners Out There?
Page generated in 0.09967 seconds with 13 queries
