Telemaster senior won't taxi
Old 02-22-2015, 03:10 PM
mikeweber3
Default Telemaster senior won't taxi
If you have read any of my previous threads you will see I recently converted an old TMS to electric. It flys great, the rudder and ailerons trim out to center, but on taxi it turns sharp right and even with full left rudder I can't go straight.
Any suggestions or questions?
mikeweber3 is offline
Old 02-22-2015, 03:43 PM
Check that the right hand wheel turns freely and all wheels are pointing straight.
Old 02-22-2015, 04:12 PM
Wheel alignment and freely turning wheels.
And apply throttle more slowly.
Old 02-22-2015, 07:36 PM
Rodneh
Telemasters could be built as either trike gear or tail draggers, which is yours?
Rodneh is offline
Old 02-22-2015, 08:29 PM
Usually a sticky wheel ....
I get it quite often from the grass areas I fly. Grass gets caught in the gap between wheel and
leg, result : ground loop !
Old 02-22-2015, 09:42 PM
Good point, i thought they were all tail draggers.
If it's a trike, and if it's got a steerable front wheel, then double check that the wheel turn left when the rudder turns left
Old 02-23-2015, 12:33 AM
mikeweber3
Thanks guys. It is a tail dragger. I'll check wheels
Old 02-23-2015, 11:58 AM
Rodneh
For tail draggers, make sure that you have a bit of toe-in on the wheels. Any toe-out will almost guarantee a bad taxi experience.
Rodneh is offline
Old 02-23-2015, 12:02 PM
Given my usual landings - toe in or out doesn't last more than one take-off !!
Old 02-23-2015, 02:41 PM
Tepid Pilot
Tepid Pilot's Avatar
The late Bill Skipper, full-scale air show pilot, RC enthusiast, and RC Report magazine columnist strongly advocated toe-out on conventional gear planes.
I have had toe out on my taildraggers since about the mid-nineties and have no problem taxiing.
A flyin' buddy had a Great Planes .20 size J-3 cub that was a ground looping fool until I bent in a smidge of toe-out. Toe-in usually works too, but on that airplane the toe-out cured the ground looping tendency.
TP
Tepid Pilot is offline
Old 02-23-2015, 04:02 PM
My models have whatever the design dictates ... To be honest to try and keep Toe In or Out with landings, rough fields, etc. is pretty impossible.
Old 02-25-2015, 01:34 AM
mikeweber3
I checked and wheels are good. I might have gotten too much right incidence in motor offset. I think I'll try adding two washers to the right side.
Old 02-25-2015, 07:19 AM
Thrust line should be set based on how the airplane flies, not how it taxis.
Be careful playing with the thrust line you can make the aircraft very unpleasant to fly.
Old 02-25-2015, 07:48 AM
It would take a shed load of right thrust to make a plane turn right even when applying full left rudder.
On a plane like the Telemaster you should have around 3 degrees of right thrust, give or take. Unless you have MUCH more than that I dont think it could explain your issues as described.
Old 02-25-2015, 02:10 PM
mikeweber3
Another theory I have is that my little 46 oz/in servo is stalling out not able to overcome the tail wheel. I ordered a 130 oz in that fits the same footprint.
I'll let you know.
mikeweber3
01-16-2015 10:12 PM
shane.c.barton
10-06-2014 04:55 AM
KeninAZ
10-11-2013 08:41 PM
Jlbrad1
04-20-2011 02:00 AM
2manyhobbies
02-20-2011 12:09 AM
Quick Reply: Telemaster senior won't taxi
Page generated in 0.09352 seconds with 11 queries
