Castle Creations discussion All things Castle
HV-85 esc help needed
Old 11-22-2006, 06:37 PM
adwb
Default HV-85 esc help needed
Please can any one suggest what settings on the castlelink software for the following equipment.
Z-power 50t kv-600 motor with a Phoenix HV-85 esc and a 10s A123 battery pack fitted to a Raptor 30.
or
supply a contact for Phoenix as they don't answer emails sent via the support link on their web site.
thank you
adwb
adwb is offline
Old 11-22-2006, 07:28 PM
Joe Ford
Castle Creations Tech
Joe Ford's Avatar
adwb...I answer 99% of the emails here at "the castle"...haven't received one from you for some reason??? Load up the 1.54 software. Settings should be as follows:
soft cutoff
heli fixed or governor high
brake functions are disabled when you choose a heli mode
motor start power med
throttle response low
low timing advance
PWM 13KHz
current limiting disabled
gov gain and spool up speed you'll have to test...start w/factory and adjust as needed/desired
Make SURE you read the instructions on how to setup your transmitter (you should have printed this when you downloaded the new software...it's on the 2nd page that pops up when you download the Castle Link 2.20 software)
Joe Ford is offline
Old 11-23-2006, 08:04 AM
adwb
Wink
Joe thank you for he information.
FYI I have emailed this query 3 times to your support email address from your website the last time being at the same time as this query was logged.
Maybe there is a problem somewhere?
many thanks
Alistair
adwb is offline
Old 11-23-2006, 12:52 PM
Motions
Motions's Avatar
I highly suggest you use standard timing for this motor.
Motions is offline
Old 11-23-2006, 01:21 PM
adwb
Scott,
why do you suggets that it seems to be different form suggestions else where?
Alistair
adwb is offline
Old 11-23-2006, 02:41 PM
Motions
Motions's Avatar
I was told by Gary at TPPacks. I tried low timing when I set mine up but on the Z-power motor it loses quite a bit of power and doesn't run very well. Standard timing is what this motor needs to be optimum.
Motions is offline
Old 11-23-2006, 05:38 PM
adwb
Ok thank you for the advice.
Alistair
adwb is offline
Old 12-02-2006, 12:00 AM
berniew
Castle Creations
berniew's Avatar
Be sure to read the heli software set up page before the download page. It says 'Print This Page for Reference' and goes throught the steps for heli set up with any software above 1.50.
http://www.castlecreations.com/downl...beta_info.html
Bernie
berniew is offline
Old 12-03-2006, 04:43 PM
Rugar
FAA# OUTLAW!
Rugar's Avatar
Hi Bernie,
Good to see that you signed up and are posting here.
Welcome to WattFlyer!
Rugar is offline
jimweda
10-01-2008 07:35 AM
rickmartinez
9
06-17-2008 10:50 PM
adwb
12-27-2007 05:13 PM
rz22g
12-10-2007 12:25 AM
Don McCullough
01-05-2007 02:06 AM
Quick Reply: HV-85 esc help needed
Page generated in 0.11173 seconds with 13 queries
